Home » Modeling » GMF (Graphical Modeling Framework) » Strange behaviour overiding use of tabbedPropertyView in graphical GMF-Editor
Strange behaviour overiding use of tabbedPropertyView in graphical GMF-Editor [message #60653] Wed, 11 October 2006 08:00 Go to next message
I tried to replace the tabbedPropertyView used by a
GMF-generated-graphical-Editor with the 'normal' tablePropertiesView
(Name-Value-Table).
As described in former posts I overrode the getAdapter(y)-method in
xxxxDiagramEditor to return null if y was instanceof IPropertySheetPage.
--> that should disable the use of tabbedPropertiesView and it did so!
After the overriding no properties where shown at all, so I undid the
overriding and tried again and that's where I observed some strange
behaviour:
While running the application in debugmode I started the diagrameditor
with tabbedProperties and closed it just to look if it is alright. Then
I overrode the getAdapter()-method to return null as described above and
started the diagrameditor again. Now it showed some properties (the
properties that are shown in advanced Tab).
Now I wonder if there is some kind of initialisation that is done while
starting the tabbedProperties? Maybe I need to do this initialisation
before I can use 'normal' propertiesview?
Does anyone ever had some similar problems?
Thanks in advance for any help!!
Alex Haag
Re: Strange behaviour overiding use of tabbedPropertyView in graphical GMF-Editor [message #61138 is a reply to message #60653] Wed, 11 October 2006 19:52 Go to previous messageGo to next message
Hi Alex,
Sounds like you are missing a call to setPropertySourceProvider().
If you look at the AdvancedPropertySection, you can see the call to
There is a similar call in the EMF generated editor that creates an
ExtendedPropertySheetPage and initializes the 'normal' tablePropertiesView
when you use the EMF editor.
Cheers...
Anthony
"Alex Haag" <Alexander.Haag@esg.de> wrote in message
news:egimdr$unc$1@utils.eclipse.org...
> (Name-Value-Table).
> IPropertySheetPage. --> that should disable the use of
> behaviour:
> with tabbedProperties and closed it just to look if it is alright. Then I
> Alex Haag
Re: Strange behaviour overiding use of tabbedPropertyView in graphical GMF-Editor [message #61985 is a reply to message #61138] Fri, 13 October 2006 04:32 Go to previous messageGo to next message
Hi Anthony,
thanks for your answer. Your proposal sounds correct, but I'm not sure
where to call this method?
I return 'null' in getAdapter(Class key) when the argument key ==
IPropertySheetPage.class.
If I don't have the Page (because returning null), where should I add
the SourceProvider to?
I tried to create my own PropertySheetPage (as shown in EMF Editor) but
If I use it, there are no entries shown at all
Could you provide further help then??
thanks Alex
Anthony Hunter wrote:
> Hi Alex,
> Cheers...
> Anthony
>> (Name-Value-Table).
>> behaviour:
>> Alex Haag
Re: Strange behaviour overiding use of tabbedPropertyView in graphical GMF-Editor [message #63371 is a reply to message #61985] Mon, 16 October 2006 08:41 Go to previous message
How about trying 2.0 M2, with newly added extended handling of property
sheet (check
http://wiki.eclipse.org/index.php/GMF_GenModel_Hints#Tuning_ property_sheet).
Even if it doesn not fit your needs, you'll get the code that does most of
the initialization stuff for you.
Artem
news:egniu1$b13$1@utils.eclipse.org...
> Hi Anthony,
> If I don't have the Page (because returning null), where should I add the
> SourceProvider to?
> I tried to create my own PropertySheetPage (as shown in EMF Editor) but If
> thanks Alex
>> Hi Alex,
>> tablePropertiesView when you use the EMF editor.
>> Cheers...
>> Anthony
>>> Hi,
>>> (Name-Value-Table).
>>> behaviour:
>>> Alex Haag
Previous Topic:How to create Connection Figure like ...
Next Topic:Problems setting size of figures below 40
Current Time: Thu Jul 17 20:48:20 EDT 2025
Powered by FUDForum. Page generated in 0.27861 seconds
