Home » Modeling » GMF (Graphical Modeling Framework) » Problems setting size of figures below 40
Problems setting size of figures below 40 [message #60633] Tue, 10 October 2006 13:20 Go to next message
Originally posted by: jan.herriger.gmx.de
I tried to create a rectangle with a defined size (width: 10, height: 40).
gmfgraph:
<figures
xsi:type="gmfgraph:Rectangle"
referencingElements="Transition"
name="TransitionFigure">
<layout xsi:type="gmfgraph:XYLayout"/>
<maximumSize dx="10" dy="40"/>
<minimumSize dx="10" dy="40"/>
<preferredSize dx="10" dy="40"/>
<size x="10" y="40"/>
</figures>
This doesn't seem to work. At runtime, the figure shows up having its
standard width of 40. As I set the dimension to 40+, everything works fine.
Defining this rectangle inside a container rectangle would be a workaround:
<figures
outline="false"
fill="false">
<children
name="TransitionFigureBody">
</children>
</figures>
This is't really satisfying, because it results in gaps between nodes
and edges. Any Ideas?
Best regards
Jan
Re: Problems setting size of figures below 40 [message #60635 is a reply to message #60633] Tue, 10 October 2006 13:26 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Add DefaultSizeFacet to your node.
Jan Herriger wrote:
> Hello,
> gmfgraph:
> <figures
> </figures>
> <figures
> outline="false"
> fill="false">
> <children
> </children>
> </figures>
> Best regards
> Jan
Re: Problems setting size of figures below 40 [message #60638 is a reply to message #60635] Tue, 10 October 2006 14:17 Go to previous messageGo to next message
I could't find such a facet, if I try to add a child to the node. Is
there any information about DefaultSizeFacet?
Re: Problems setting size of figures below 40 [message #60639 is a reply to message #60638] Tue, 10 October 2006 14:26 Go to previous messageGo to next message
I've also had this problem. Basically, you have to go into
the EditPart code and reduce the size manually in the
createNodePlate() method.
It is pretty frustrating having to do it this way.
Andy
"Jan Herriger" <jan.herriger@gmx.de> wrote in message
news:eggo4g$3v5$1@utils.eclipse.org...
>I could't find such a facet, if I try to add a child to the node. Is there
Re: Problems setting size of figures below 40 [message #60648 is a reply to message #60639] Wed, 11 October 2006 04:39 Go to previous messageGo to next message
Changing code is not the best option here, using DefaultSizeFacet is
definitely better.
The facet could be added to appropriate DiagramElement, i.e. 'Transition'
node from the initial post
Artem
"ase" <andye@xactium.com> wrote in message
news:eggokf$63o$1@utils.eclipse.org...
> Andy
Re: Problems setting size of figures below 40 [message #61483 is a reply to message #60648] Thu, 12 October 2006 08:57 Go to previous messageGo to next message
Thanks for your responses. Are we talking about different GMF versions?
I'm using 1.0.1 and I just can't find DefaultSizeFacet.
> definitely better.
> Artem
>> Andy
Re: Problems setting size of figures below 40 [message #61608 is a reply to message #61483] Thu, 12 October 2006 09:43 Go to previous messageGo to next message
Well, if "added to diagram element" is not enough... here's the picture
news:egle47$bao$1@utils.eclipse.org...
>> definitely better.
>> Artem
>>> Andy
>>>> there
Re: Problems setting size of figures below 40 [message #62074 is a reply to message #61608] Fri, 13 October 2006 07:25 Go to previous messageGo to next message
Thanks again. I knew where to add the facet. But the facet is
unavailable in version 1.0.1.
I installed Build: 2.0M1. Now, everything works fine.
>>> definitely better.
>>> Artem
>>>> Andy
>>>>> there
Re: Problems setting size of figures below 40 [message #63395 is a reply to message #62074] Mon, 16 October 2006 08:45 Go to previous message
Sorry, overlooked you were using 1.0.1... Too much focused on 2.0 ;)
Artem
news:egnt2m$5fu$1@utils.eclipse.org...
> Thanks again. I knew where to add the facet. But the facet is unavailable
> in version 1.0.1.
>>>> definitely better.
>>>> 'Transition'
>>>> Artem
>>>>> Andy
>>>>>> there
Previous Topic:Strange behaviour overiding use of tabbedPropertyView in graphical GMF-Editor
Next Topic:Missing files after generating the diagram code
Current Time: Tue Jul 22 00:48:37 EDT 2025
Powered by FUDForum. Page generated in 0.05489 seconds
