Re: Printing ecore diagrams does not scale properly [message #60629] |
Tue, 10 October 2006 10:53  |
Michael,
The GMF folks provide this capability, so this might ring a bell for
them. I've added that newsgroup to the list.
Michael Moser wrote:
> I am not sure whether this is an EMF or an eclipse (i.e. platform)
> issue - in case this is the wrong forum please advise!
> Am I trying to print an ecore diagram (from ecore diagram editor) on
> paper. In File => Page setup... I selected Landscape and papersize A3
> (i.e. about 297 mm high x 420 wide).
> I then try to print that page using "Fit to page wide:[1] page
> tall:[1]" to a printer on which I also selected A3 in landscape mode
> as paper to be used.
> When I then print this diagram the result is crammed into the upper
> left corner using about 1/3 of the width and 1/3 of the height of the
> paper (which is unreadable small and completely useless).
> What I don't understand: How does the dimension that one selects in
> "Page setup..." translate into the printer's paper size. If one
> selects both to be the same, why does this then not work properly?
> Any help or explanation welcome!
> Michael
Re: Printing ecore diagrams does not scale properly [message #61190 is a reply to message #61114] |
Thu, 12 October 2006 03:47   |
I am on 2.0M1. But just looking at the download page I saw, that 1.0.1.
is younger than 2.0M1, so I guess 2.0M1 may contain new features but
maybe not all the fixes, yet. And there even is a maintenance build for
1.0.1. that is even younger.
So - esp. since I don't need any specific new features - I guess, I'll
revert to that last one, i.e. the 1.0.1 maintenance build and then try
again.
Thanks for making me aware!
Michael
"Anthony Hunter" <anthonyh@ca.ibm.com> wrote in message
news:egjv9m$2fm$1@utils.eclipse.org...
> Hi Michael,
> What version of GMF are you using? This sounds like
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=134767 which was fixed
> in GMF 1.0.1.
> Cheers...
> Anthony
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:eggc46$65h$2@utils.eclipse.org...
>> Michael,
>>> A3 (i.e. about 297 mm high x 420 wide).
>>> the paper (which is unreadable small and completely useless).
>>> Michael
Re: Printing ecore diagrams does not scale properly [message #61287 is a reply to message #61114] |
Thu, 12 October 2006 04:54  |
Bingo! With the 1.0.1 maintenance release (dated Oct. 5th) the diagram
prints nicely filling the entire sheet as one would expect...
So that's already very usable. Thanks again!
One complaint I still have is, that while geometric figures (esp. boxes)
look nice, slanted lines and esp. all text looks rather rough and jagged
(as if originally created for a lower resolution and then scaled up).
The output obviously does not make use of the printer's actual
resolution (in my case 1200 dpi), rather it looks like this is simply
emiting and scaling up the screen output 1:1 or something similar. Is
this something one can tweak somehow or does one have to live with that?
Michael
> Hi Michael,
> in GMF 1.0.1.
> Cheers...
> Anthony
>> Michael,
>>> Michael
FUDForum. Page generated in 0.05429 seconds
