Home » Modeling » GMF (Graphical Modeling Framework) » How to enable drag and drop from palette
How to enable drag and drop from palette [message #60624] Tue, 10 October 2006 09:35 Go to next message
Originally posted by: contact.noelios.com
It seems that the only way to create nodes using the palette is by first
clicking on the tool from the palette, releasing the button, then moving
the mouse to the creation point on the canvas (a "+" sign is displayed
with the mouse cursor) then clicking again to actually create a new node.
I have a user request for "traditional" drag&drop where you would
left-click on a palette tool, move the mouse to the drop point (keeping
the mouse button pressed) and release the mouse button in order to
create the node.
I've found two bug reports that claim that drag&drop is available
(resolved/fixed):
"Can not add elements to diagram doing drag and drop from palette"
https://bugs.eclipse.org/bugs/show_bug.cgi?id=113580
"[req] Support drag-n-drop"
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114224
Is this possible in GMF 1.0.1? Is this a behavior inherited from GEF
that can't be changed?
Jerome Louvel
http://www.noelios.com
Re: How to enable drag and drop from palette [message #60626 is a reply to message #60624] Tue, 10 October 2006 10:14 Go to previous messageGo to next message
Jerome,
This works in the GMF Geoshapes Example, but not in the generated Taipan
Example so it looks like the GMF generation capabilities does not
support this yet. Take a look at PaletteToolTransferDropTargetListener
to see how this is implemented in the GMF Runtime.
Cherie
> create the node.
> (resolved/fixed):
Re: How to enable drag and drop from palette [message #80198 is a reply to message #60626] Wed, 22 November 2006 10:42 Go to previous message
Thanks Cherie for the reply, it indeed works fine at the runtime level.
I don't know why it's not working for generated diagrams. I've entered a
bug report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=165452
Jerome
Cherie Revells :
> Jerome,
> Cherie
>> first clicking on the tool from the palette, releasing the button,
>> then moving the mouse to the creation point on the canvas (a "+" sign
>> is displayed with the mouse cursor) then clicking again to actually
>> create a new node.
>> (keeping the mouse button pressed) and release the mouse button in
>> order to create the node.
>> (resolved/fixed):
>> Thanks,
Jerome Louvel
Previous Topic:"Guide GMFMap Creation"-Wizard Source?
Next Topic:properties tabsheet
Current Time: Fri Jul 11 22:13:29 EDT 2025
Powered by FUDForum. Page generated in 0.03415 seconds
