Home » Modeling » GMF (Graphical Modeling Framework) » Links and subclasses
Links and subclasses [message #60622] Tue, 10 October 2006 09:04 Go to next message
Originally posted by: contact.noelios.com
Let's say that in my ECore model I have 4 classes (see below). A is
abstract, A1, A2 and B correspond to visual nodes.
A B
A1 A2
Now, I want to allow links from A1 or A2 to B. In reality I have many
subclasses of A, so I want to specify one mapping if possible. I created
a Link class with two properties: "source : A" and "target : B".
Now, if I create a mapping in .gmfmap based on this Link class, I can't
draw the links at runtime. It seems that GMF or EMF don't recognize A1
or A2 instances as valid values for the Link's "source" property.
Is this the intended behavior? What are the workarounds?
Jerome Louvel
http://www.noelios.com
Re: Links and subclasses [message #60650 is a reply to message #60622] Wed, 11 October 2006 04:46 Go to previous message
> A B
> A1 A2
It should work (at least it works for me). How did you configure the Link
mapping?
Do A1,A2 or B have Compartents? In that case it's important to aim for the
Node's label and not for the compartment.
Previous Topic:Centering labels
Next Topic:No parser is registered for the "OCL" language
Current Time: Wed Jul 16 02:31:08 EDT 2025
Powered by FUDForum. Page generated in 0.03843 seconds
