Home » Modeling » GMF (Graphical Modeling Framework) » UML2 associations, again
UML2 associations, again [message #60612] |
Mon, 09 October 2006 17:03  |
Originally posted by: alexander.schwartzonline.de
I am working on a tiny UML2 Use Case Editor using the
UML2 model (yes, I know about the MDT project)
-- and I have problems to create a link for an Association.
I know I'm not the first one asking about it, but unfortunately
I was not able to find a solution in the previous discussion
threads.
I tried to reproduce the solution in the the old UML clazz example by
Alex Shatlin, but I assume catched up only a small portion of it.
I modelled the link in my gmfmap as follows:
<links>
<domainMetaElement
href=" ../../../plugin/org.eclipse.uml2.uml/model/UML.ecore#//Assoc iation "/>
<labelMappings
readOnly="true"
viewPattern=""
editPattern="">
<diagramLabel
href="usecase.gmfgraph#ExtendLabel"/>
</labelMappings>
<containmentFeature
href=" ../../../plugin/org.eclipse.uml2.uml/model/UML.ecore#//Packa ge/packagedElement "/>
<tool
xsi:type="gmftool:CreationTool"
href="usecase.gmftool#//@palette/@tools.1/@tools.1"/>
<diagramLink
href="usecase.gmfgraph#Association"/>
<sourceMetaFeature
xsi:type="ecore:EReference"
href=" ../../../plugin/org.eclipse.uml2.uml/model/UML.ecore#//Names pace/ownedMember "/>
<linkMetaFeature
</links>
The generated diagram code is customized:
A custom creation command creates the memberEnds of the Association:
protected static abstract class CreateAssociationCommand extends
CreateRelationshipCommand {
public CreateAssociationCommand(CreateRelationshipRequest request) {
super(request);
protected EObject doDefaultElementCreation() {
Association newElement = (Association) super
.doDefaultElementCreation();
if (newElement != null) {
Property sourceEnd = UMLFactory.eINSTANCE.createProperty();
sourceEnd.setName("src");
sourceEnd.setType((Type) getSource());
newElement.getOwnedEnds().add(sourceEnd);
Property targetEnd = UMLFactory.eINSTANCE.createProperty();
targetEnd.setName("dst");
targetEnd.setType((Type) getTarget());
newElement.getOwnedEnds().add(targetEnd);
return newElement;
Every CreateIncomingAssociation4004Command uses the custom creation
command as follows:
* @generated NOT
private static class CreateIncomingAssociation4004Command extends
CreateAssociationCommand {
* @generated
public CreateIncomingAssociation4004Command(
CreateRelationshipRequest req) {
super(req);
* @generated
protected EClass getEClassToEdit() {
return UMLPackage.eINSTANCE.getPackage();
* @generated
protected void setElementToEdit(EObject element) {
throw new UnsupportedOperationException();
* @generated NOT
return super.doDefaultElementCreation();
With these changes an Association can be created in the diagramm editor,
but an NullPointerException is raised
Caused by: java.lang.NullPointerException
at org.eclipse.draw2d.Figure.add(Figure.java:146)
at org.eclipse.draw2d.Figure.add(Figure.java:179)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addChild Visual(AbstractGraphicalEditPart.java:198)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:197)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.gef.editparts.AbstractConnectionEditPart.refresh (AbstractConnectionEditPart.java:221)
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art.access$1(ConnectionEditPart.java:1)
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art$5.run(ConnectionEditPart.java:915)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:258)
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art.refresh(ConnectionEditPart.java:912)
org.eclipse.gef.editparts.AbstractConnectionEditPart.setTarg et(AbstractConnectionEditPart.java:295)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addTarge tConnection(AbstractGraphicalEditPart.java:261)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshT argetConnections(AbstractGraphicalEditPart.java:657)
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPa rt.handleNotificationEvent(ShapeNodeEditPart.java:218)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.notifyChanged(GraphicalEditPart.java:1217)
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.fireNotification(DiagramEventBroker.java:347)
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.handleElementEvent(DiagramEventBroker.java:673)
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.resourceSetChanged(DiagramEventBroker.java:305)
org.eclipse.gmf.runtime.diagram.ui.internal.DiagramEventBrok erThreadSafe.resourceSetChanged(DiagramEventBrokerThreadSafe .java:72)
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain.postcommit(DiagramEditingDomainFac tory.java:193)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.deactivate(TransactionalEditingDomainImpl.java:471)
org.eclipse.emf.transaction.impl.TransactionImpl.close(Trans actionImpl.java:524)
org.eclipse.emf.transaction.impl.TransactionImpl.commit(Tran sactionImpl.java:365)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:133)
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:400)
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:129)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
... 34 more
The created model file looks alright:
<uml:Package xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_epGAcFfYEdux36m_D9W2Kw">
<packagedElement xmi:type="uml:Actor" xmi:id="_e08EEFfYEdux36m_D9W2Kw"/>
<packagedElement xmi:type="uml:UseCase"
xmi:id="_fE4kkFfYEdux36m_D9W2Kw"/>
<packagedElement xmi:type="uml:Association"
xmi:id="_fYp1IFfYEdux36m_D9W2Kw" memberEnd="_fYp1IVfYEdux36m_D9W2Kw
_fYp1IlfYEdux36m_D9W2Kw">
<ownedEnd xmi:id="_fYp1IVfYEdux36m_D9W2Kw" name="src"
type="_e08EEFfYEdux36m_D9W2Kw" association="_fYp1IFfYEdux36m_D9W2Kw"/>
<ownedEnd xmi:id="_fYp1IlfYEdux36m_D9W2Kw" name="dst"
type="_fE4kkFfYEdux36m_D9W2Kw" association="_fYp1IFfYEdux36m_D9W2Kw"/>
</packagedElement>
</uml:Package>
Here is the corresponding section in the notation model:
<edges xmi:type="notation:Edge" xmi:id="_fYp1I1fYEdux36m_D9W2Kw"
type="4004" source="_e08EEVfYEdux36m_D9W2Kw"
target="_fE4kkVfYEdux36m_D9W2Kw">
<children xmi:type="notation:Node" xmi:id="_fYp1KFfYEdux36m_D9W2Kw"
type="6003">
<layoutConstraint xmi:type="notation:Location"
xmi:id="_fYp1KVfYEdux36m_D9W2Kw" y="40"/>
</children>
<styles xmi:type="notation:RoutingStyle"
xmi:id="_fYp1JFfYEdux36m_D9W2Kw"/>
<styles xmi:type="notation:FontStyle"
xmi:id="_fYp1JVfYEdux36m_D9W2Kw"/>
<styles xmi:type="notation:LineStyle"
xmi:id="_fYp1JlfYEdux36m_D9W2Kw"/>
<element xmi:type="uml:Association"
href="default3.uml#_fYp1IFfYEdux36m_D9W2Kw"/>
<bendpoints xmi:type="notation:RelativeBendpoints"
xmi:id="_fYp1J1fYEdux36m_D9W2Kw" points="[0, 0, 0, 0]$[0, 0, 0, 0]"/>
</edges>
Has anyone a working solution?
Thanks any hints in advance,
Alex
Re: UML2 associations, again [message #60618 is a reply to message #60612] |
Tue, 10 October 2006 02:53   |
I am successor of Alexander Shatalin in the UML diagrams implementation and
I have recently added almost complete UML2 association notation into the
editor class diagram (the only difference is that it in actually does not
include "dots" to denote owners of the ends and arrows for navigability).
I am not sure that I comletely understand your sample internals, but I see
some differences in the implementation.
(major one) : I had to change PackageCanonicalEditPolicy to collect
association descriptors in order to be consistent with changes in the
creation code. It looks like your exception is thrown when the creation
command have been already fired, and post-transaction notification is
broadcasted. Thus, I may guess that problem is in the canonical
editpolicy -- in case it is consistent, it should NOT create any new links,
because all edges are already in their places.
(minor one) : In the create command I am creating associations using
Type:createAssociation() uml2 helper method, delegating creation to the
UML2. It allows to setup the owners of association ends based on end
navigability.
Hope this helps,
Michael
//from PackageCanonicalEditPolicy
* @generated NOT
private void storeTypeModelFacetLinks_Association_4005(EObject container,
EClass containerMetaclass) {
if (UMLPackage.eINSTANCE.getPackage().isSuperTypeOf(containerMe taclass)) {
for (Iterator values = ((org.eclipse.uml2.uml.Package)
container).getPackagedElements().iterator(); values.hasNext();) {
EObject nextValue = ((EObject) values.next());
int linkVID = UMLVisualIDRegistry.getLinkWithClassVisualID(nextValue);
if (AssociationEditPart.VISUAL_ID == linkVID) {
Association association = (Association) nextValue;
if (association.isBinary()) {
AssociationEndConvention.getSourceEnd(association);
AssociationEndConvention.getTargetEnd(association);
EObject gmfSource = sourceEnd.getType();
EObject gmfTarget = targetEnd.getType();
myLinkDescriptors.add(new LinkDescriptor(gmfSource, gmfTarget,
association, linkVID));
* @NOT-GENERATED
super(request);
Type sourceType = (Type)getSource();
Type targetType = (Type)getTarget();
//due to association end conventiontions (see AssociationEndConvention)
//we need to have member end of type SourceType to be the first one
created
//thus, we are calling UML2 createAssociation() in opposite order
Association result = targetType.createAssociation(//
false, AggregationKind.NONE_LITERAL, "src", 1, 1, //
sourceType, false, AggregationKind.NONE_LITERAL, "dst", 1, 1);
return result;
public class AssociationEndConvention {
public static Property getMemberEnd(Association association, boolean
sourceNotTarget){
return (Property)association.getMemberEnds().get(sourceNotTarget ? 0 : 1);
public static Property getSourceEnd(Association association){
return getMemberEnd(association, true);
public static Property getTargetEnd(Association association){
return getMemberEnd(association, false);
"Alexander Schwartz" <alexander@schwartzonline.de> wrote in message
news:egede6$47l$1@utils.eclipse.org...
> threads.
> <links>
> <domainMetaElement
> <labelMappings
> readOnly="true"
> viewPattern=""
> editPattern="">
> <diagramLabel
> </labelMappings>
> <containmentFeature
> <tool
> <diagramLink
> <sourceMetaFeature
> <linkMetaFeature
> </links>
> super(request);
> return newElement;
> command as follows:
> * @generated NOT
> * @generated
> super(req);
> * @generated
> * @generated
> * @generated NOT
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
> </packagedElement>
> </uml:Package>
> type="6003">
> </children>
> </edges>
> Alex
Re: UML2 associations, again [message #60640 is a reply to message #60618] |
Tue, 10 October 2006 14:30   |
Hello Michael,
thanks for your help!
> broadcasted.
yes, my debugging session yield that the exception is throw after the
creation of the association.
> navigability.
I tried to use your suggested solution and added
CreateAssociationCommand to PackageCanonicalEditPolicy.
What I not known exactly is how this new CreateAssociationCommand is to
be used. I examined two approaches:
(1) With the following version CreateIncomingAssociation4004Command
I still run into the problem with my exception.
* @generated NOT
* @generated
super(req);
* @generated
* @generated
* @generated NOT
(2) With the following version the diagram cursor permits to insert an
Association link:
* @generated NOT
* @generated
super(req);
How you are using the CreateIncomingAssociation4004Command?
Thanks for help,
Alex
Re: UML2 associations, again [message #63663 is a reply to message #63302] |
Mon, 16 October 2006 17:56  |
Hallo Alex,
> So, what about bugzilla request to handle this situation in validation
> and produce corresponding error? ;-)
I filed this as issue #161149.
Alex Schwartz
Current Time: Thu Jul 17 21:55:44 EDT 2025
Powered by FUDForum. Page generated in 0.55180 seconds
