Home » Modeling » GMF (Graphical Modeling Framework) » Can't find genFeature for feature 'configuredElements' in class Server
Can't find genFeature for feature 'configuredElements' in class Server [message #60609] Mon, 09 October 2006 13:31 Go to next message
Originally posted by: rbbnjmn.yahoo.com
I get this error trying to create the generator model. All the models
validate and after hours of
eyeballing I can't find anything that looks like it should be a problem.
Has anyone seen something like this problem before?
Thanks!
Roy
java.lang.IllegalStateException: Can't find genFeature for feature
org.eclipse.gmf.internal.bridge.genmodel.GenModelMatcher.fin dGenFeature(GenModelMatcher.java:102)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.findGenFeature(DiagramGenModelTransformer.java:646)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.setupModelFacet(DiagramGenModelTransformer.java:700)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.createModelFacet(DiagramGenModelTransformer.java:658 )
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.createGenChildNode(DiagramGenModelTransformer.java:3 48)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.process(DiagramGenModelTransformer.java:277)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.processAbstractNode(DiagramGenModelTransformer.java: 394)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.process(DiagramGenModelTransformer.java:250)
org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer. transform(MappingTransformer.java:32)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$1.transform(TransformToGenModel.java:189)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$1.run(TransformToGenModel.java:159)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Re: Can't find genFeature for feature 'configuredElements' in class Server [message #60646 is a reply to message #60609] Wed, 11 October 2006 04:26 Go to previous messageGo to next message
Guess, you forgot to refresh your .genmodel after adding
'configuredElements' to domain model (.ecore)
"rbbnjmn" <rbbnjmn@yahoo.com> wrote in message
news:ege113$rjm$1@utils.eclipse.org...
> Thanks!
> Roy
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Can't find genFeature for feature 'configuredElements' in class Server [message #75880 is a reply to message #60646] Wed, 08 November 2006 11:03 Go to previous message
Hi there,
I have the same problem (see error message below). I reloaded and
regenerated the genmodel several times. I am also sure the the XML file
contains the class "ProductionProcessDiagram". I am tired of searching
the error... So maybe some1 knows further sources of errors.
Thx in advance!
java.lang.IllegalStateException: Can't find genClass for class
'ProductionProcessDiagram' in package production
org.eclipse.gmf.internal.bridge.genmodel.GenModelMatcher.fin dGenClass(GenModelMatcher.java:82)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.findGenClass(DiagramGenModelTransformer.java:723)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.process(DiagramGenModelTransformer.java:246)
org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer. transform(MappingTransformer.java:30)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$2.process(TransformToGenModel.java:272)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$1.run(TransformToGenModel.java:189)
>>Thanks!
>>Roy
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
Previous Topic:How can I refresh the diagram when properties change, that aer shown as labels in the diagram
Next Topic:Map-file diagram editor! Bravo!
Current Time: Tue Jul 22 00:48:30 EDT 2025
Powered by FUDForum. Page generated in 0.03325 seconds
