Home » Modeling » GMF (Graphical Modeling Framework) » Trouble with modeling.
Trouble with modeling. [message #60591] Mon, 09 October 2006 07:52 Go to next message
Hey,
I've created an emf editor that I want to turn into a graphical editor
using GMF. The editor was created with annotated java and looks as
expected in the ecore diagram, an abstract data item with two other data
item, all related with 'comtains'.
EMF worked fine, but when I went to build this in GMF, using the abstract
to be the diagram element, I could only add nodes and could not specify
the containment relations I thought I could.
Q:
Do I have to specify all relations for a GMF as dataitems? If I have two
dataitems and there is a relation between them, will this relation not be
an edge in a GMF Editor?
dataitems in ecore diagram = nodes and edges?
Cheers
Re: Trouble with modeling. [message #60594 is a reply to message #60591] Mon, 09 October 2006 08:23 Go to previous messageGo to next message
You could model containment relationship both using 'child node (node inside
node)' and 'link' notation.
Artem
"Gaff" <conorgaff@hotmail.com> wrote in message
news:be2e8b9aa40ee2b97194befcf3239add$1@www.eclipse.org...
> Hey,
> Q:
> Cheers
Re: Trouble with modeling. [message #60595 is a reply to message #60594] Mon, 09 October 2006 09:10 Go to previous messageGo to next message
Is what you're saying that if I have dataitem A and dataitem B, both of
which are to be represented as a nodes in GMF, that I only have to specify
that these are related to each other with link and child (not using a
dataitem) for there to be edge representation between them in the GMF?
Does there not have to be a dataitem for the relationship so it can be
mapped to the abstract dataitem (the diagram link/the canvas) and
therefore be added to the Canvas in the GMF Editor?
Re: Trouble with modeling. [message #60597 is a reply to message #60595] Mon, 09 October 2006 09:23 Go to previous messageGo to next message
If you got
class A {
ref B refB;
and
class B {
you can define two node mappings (for A and B) and one link mapping, using
'refB' as a link meta feature. This gives you 3 entries in the palette and
allows you to create both nodes and link between them.
news:b171ef5656ef8497a60ba2cfe2ebf1bd$1@www.eclipse.org...
Re: Trouble with modeling. [message #60601 is a reply to message #60597] Mon, 09 October 2006 10:30 Go to previous messageGo to next message
With you on the fact that a link mapping is created and the idea of 'ref',
but if I'm creating this in annotated java and I want to reference
(EReference) to another dataitem don't I just use java.util.List, which is
what I did before and resulted in just nodes and no links.
If I have this annotated code, what would the 'ref' be?
(trying this now, just getting errors from something else I think)
public interface A {
* Return the info about A.
* @return A info
* @model
String getAinfo();
* Return the the link to B.
* @return B ref
* @model
B refB(); //is this line enough for a link between A and B to appear?
public interface B {
* Return the info about B.
* @return B info
* @model
String getBinfo();
Re: Trouble with modeling. [message #60610 is a reply to message #60601] Mon, 09 October 2006 14:23 Go to previous messageGo to next message
Had a go at this bu it didn't work. Still getting just the nodes with no
edge so I'b e able to join them. Tried adding in the link 'manualy' but
then have the gmfmap not validating (kind of thought that would happen),
below is the process I used to try and add a link for the graph/tool/map.
I can see the EOperation refB within the A EClass of ecore, but this
doesn't translate to the other models. What am I missing?
From A node to B node
gmfgraph: added a polyline connection to the Figure Gallery
added a Connection to Canvas with figure as the polyline connection above
gmftool: added a creation tool for Connect
gmfmap: added a link mapping with these settings:
Element (the abstract )
Source Feature EReference A
Target Feature EReference B
Diagram Link Connection(above)
Tool Tool(above)
... can't validate as can't set the containment feature the same as (the
abstract). Assume this is because I haven't set a connection dataitem in
ecore.
Re: Trouble with modeling. [message #60611 is a reply to message #60610] Mon, 09 October 2006 14:50 Go to previous message
--------------090408020509030900010603
Gaff,
I've not followed this whole thread closely, but the @model method refB
will be mapped to an EOperation whereas naming it *get*RefB() would map
it to an EReference.
> no edge so I'b e able to join them. Tried adding in the link 'manualy'
> but then have the gmfmap not validating (kind of thought that would
> happen), below is the process I used to try and add a link for the
> graph/tool/map. I can see the EOperation refB within the A EClass of
> ecore, but this doesn't translate to the other models. What am I missing?
> connection above
> Tool Tool(above)
> (the abstract). Assume this is because I haven't set a connection
> dataitem in ecore.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Gaff,<br>
<br>
will be mapped to an EOperation whereas naming it <b>get</b>RefB()
would map it to an EReference.<br>
<br>
<br>
Gaff wrote:
<blockquote cite="midd80691a797d372577238ebd588fd7545$1@www.eclipse.org"
type="cite">Had a go at this bu it didn't work. Still getting just the
nodes with no edge so I'b e able to join them. Tried adding in the link
'manualy' but then have the gmfmap not validating (kind of thought that
would happen), below is the process I used to try and add a link for
the graph/tool/map. I can see the EOperation refB within the A EClass
of ecore, but this doesn't translate to the other models. What am I
missing?
<br>
<br>
<br>
<br>
<br>
<br>
gmfgraph:
Previous Topic:gmf tutorial problem (step: graphical definition)
Next Topic:gentleware announces GMF based tool
Current Time: Sat Jul 12 11:18:45 EDT 2025
Powered by FUDForum. Page generated in 0.24634 seconds
