Trouble with modeling. [message #60591] |
Mon, 09 October 2006 07:52  |
Hey,
I've created an emf editor that I want to turn into a graphical editor
using GMF. The editor was created with annotated java and looks as
expected in the ecore diagram, an abstract data item with two other data
item, all related with 'comtains'.
EMF worked fine, but when I went to build this in GMF, using the abstract
to be the diagram element, I could only add nodes and could not specify
the containment relations I thought I could.
Q:
Do I have to specify all relations for a GMF as dataitems? If I have two
dataitems and there is a relation between them, will this relation not be
an edge in a GMF Editor?
dataitems in ecore diagram = nodes and edges?
Cheers
Re: Trouble with modeling. [message #60611 is a reply to message #60610] |
Mon, 09 October 2006 14:50  |
--------------090408020509030900010603
Gaff,
I've not followed this whole thread closely, but the @model method refB
will be mapped to an EOperation whereas naming it *get*RefB() would map
it to an EReference.
Gaff wrote:
> Had a go at this bu it didn't work. Still getting just the nodes with
> no edge so I'b e able to join them. Tried adding in the link 'manualy'
> but then have the gmfmap not validating (kind of thought that would
> happen), below is the process I used to try and add a link for the
> graph/tool/map. I can see the EOperation refB within the A EClass of
> ecore, but this doesn't translate to the other models. What am I missing?
> From A node to B node
> gmfgraph: added a polyline connection to the Figure Gallery
> added a Connection to Canvas with figure as the polyline
> connection above
> gmftool: added a creation tool for Connect
> gmfmap: added a link mapping with these settings:
> Element (the abstract )
> Source Feature EReference A
> Target Feature EReference B
> Diagram Link Connection(above)
> Tool Tool(above)
> .. can't validate as can't set the containment feature the same as
> (the abstract). Assume this is because I haven't set a connection
> dataitem in ecore.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Gaff,<br>
<br>
will be mapped to an EOperation whereas naming it <b>get</b>RefB()
would map it to an EReference.<br>
<br>
<br>
Gaff wrote:
<blockquote cite="midd80691a797d372577238ebd588fd7545$1@www.eclipse.org"
type="cite">Had a go at this bu it didn't work. Still getting just the
nodes with no edge so I'b e able to join them. Tried adding in the link
'manualy' but then have the gmfmap not validating (kind of thought that
would happen), below is the process I used to try and add a link for
the graph/tool/map. I can see the EOperation refB within the A EClass
of ecore, but this doesn't translate to the other models. What am I
missing?
<br>
<br>
<br>
<br>
<br>
<br>
gmfgraph:
FUDForum. Page generated in 0.13641 seconds
