Home » Archived » XML Schema Definition (XSD) » CWM and XSD
CWM and XSD [message #60550] Wed, 04 May 2005 05:33 Go to next message
Originally posted by: dony.qqqqsss.com
I have generated a xsd file from a dtd, but there are some problems.
In the xsd file there is an element tag definition like this:
<xsd:element name="CWM:ModelElement.taggedValue">
but the file is not right.
The error message is :
Value "CWM:ModelElement.taggedValue" of attribute 'name' does not match
simple type 'xs:NCName'
could somebody help me?
Re: CWM and XSD [message #60893 is a reply to message #60550] Wed, 04 May 2005 06:25 Go to previous messageGo to next message
Dony,
NCName stands for Non-colonized name and as that term implies, colons
are not allowed.
Dony wrote:
> match simple type 'xs:NCName'
> Thanks
Re: CWM and XSD [message #60916 is a reply to message #60893] Wed, 04 May 2005 08:01 Go to previous messageGo to next message
Originally posted by: dony.xxxxxxx.xx
Thanks for your quick answer...
The problem is that colons are necessary for our schema. Do you know how
we can do?
Re: CWM and XSD [message #60940 is a reply to message #60916] Wed, 04 May 2005 09:11 Go to previous messageGo to next message
Dony,
Since they absolutely aren't allowed, they cannot possibly be
necessary. I'm quite sure you are confusing wanting prefixes in your
instance documents with putting prefixes in your schema's names. Your
schema should have a target namespace and the names it uses should not
have colons; the prefix used in the instance documents will be based on
that namespace.
> how we can do?
Re: CWM and XSD [message #60989 is a reply to message #60916] Thu, 05 May 2005 12:04 Go to previous message
Dony,
It sounds like the tool you used to convert your DTD to XSD is faulty and
produces invalid schemas. I'd suggest getting a differt tool for converting
your DTD.
Dave Carlson
"Dony" <dony@xxxxxxx.xx> wrote in message
news:bf6e486122d146eb76b3fc053ebc395f$1@www.eclipse.org...
> we can do?
Re: CWM and XSD [message #595387 is a reply to message #60550] Wed, 04 May 2005 06:25 Go to previous message
Dony,
are not allowed.
Dony wrote:
> Thanks
Re: CWM and XSD [message #595398 is a reply to message #60893] Wed, 04 May 2005 08:01 Go to previous message
we can do?
Re: CWM and XSD [message #595400 is a reply to message #60916] Wed, 04 May 2005 09:11 Go to previous message
Dony,
that namespace.
> how we can do?
Re: CWM and XSD [message #595418 is a reply to message #60916] Thu, 05 May 2005 12:04 Go to previous message
Dony,
your DTD.
Dave Carlson
> we can do?
Previous Topic:CWM and XSD
Next Topic:2 suggestions for XSD
Current Time: Tue Jul 22 09:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.26728 seconds
