Home » Eclipse Projects » Remote Application Platform (RAP) » sort table does not work on demo application when table is VIRTUAL
sort table does not work on demo application when table is VIRTUAL [message #60545] Mon, 19 November 2007 13:09 Go to next message
I would like to know if for u the sort of rows works in a VIRTUAL
table, in an application of your own or in the demo application.
Val
Re: sort table does not work on demo application when table is VIRTUAL [message #60888 is a reply to message #60545] Mon, 19 November 2007 17:16 Go to previous messageGo to next message
with VIRTUAL, you have to reorder your data source (i.e SQL) and redisplay
the data.
When using static loading of data, use comperators as shown in the Demo.
Andrej
Re: sort table does not work on demo application when table is VIRTUAL [message #60983 is a reply to message #60888] Tue, 20 November 2007 04:09 Go to previous messageGo to next message
> redisplay the data.
> Andrej
Thanks for the answer, I have reordered my data from sql.
However, after sorting I refresh the data with tableViewer.refresh();
but still the table contains stale data and only when selecting a row
from the table the new data is show on all visual rows of the table.
Then when scrolling down the same thing old data is shown and only
when selecting some row it is refreshed.
I keep my data in a cache in pages of 40 elements but I clear the
cache when doing the sort and I can see that the update method of the
ILazyContentProvider fills up with new data which however is not show
until selecting some row.
Val
Re: sort table does not work on demo application when table is VIRTUAL [message #63991 is a reply to message #60983] Mon, 03 December 2007 10:31 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
sorry for the late reply. I just added sorting for the VIRTUAL
TableViewer in the ControlsDemo (tab TableViewer) the way I think it
should be done - and it works. There are no stale rows or similar.
You could check out the code from CVS HEAD and have a look what's
different from your implementation. The actual sorting is done in
CTableViewer#sort, line ~382.
If you still think there is a bug feel free to file a BugZilla entry.
Rüdiger
Val wrote:
>> redisplay the data.
>> Andrej
> Hi
> Thanks
> Val
Re: sort table does not work on demo application when table is VIRTUAL [message #64086 is a reply to message #63991] Mon, 03 December 2007 12:34 Go to previous message
using RAP 1.0.1 sort on virtual table viewer works better :)
However there is still a problem when the amount of data showed in the
table can not be displayed at once (is more thant the visible part of
the table)
for this I have created bug no. 211790 it contains the steps and patch
to reproduce on demo application
Val
Rüdiger Herrmann wrote:
> Cheers,
> Rüdiger
> Val wrote:
>>> redisplay the data.
>>> Andrej
>> Hi
>> Thanks
>> Val
Previous Topic:limitations of RAP compared to PDE
Next Topic:Help with org.eclipse.rap.demo.feature project
Current Time: Sat Jul 26 05:57:05 EDT 2025
Powered by FUDForum. Page generated in 0.05115 seconds
