Home » Modeling » TMF (Xtext) » Xpand Project Problems
Xpand Project Problems [message #60540] Fri, 17 July 2009 21:39 Go to next message
I tried the new Xpand project wizard with "create a sample" checked.
There seems to be nothing wrong with the ecore, xtend, xpand, and check
files.
However I receive the following error messages on running the mwe:
Jul 18, 2009 11:28:50 AM org.eclipse.emf.mwe.core.WorkflowRunner prepare
INFO:
INFO: EMF Modeling Workflow Engine 0.7.1, Build v200907170432
INFO: (c) 2005-2009 openarchitectureware.org and contributors
INFO:
INFO: running workflow: C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe
INFO:
Jul 18, 2009 11:28:50 AM org.eclipse.emf.mwe.core.WorkflowRunner logIssues
SEVERE: [ERROR]: Class not found:
'org.eclipse.mwe.emf.StandaloneSetup'(Element: bean bean
class='org.eclipse.mwe.emf.StandaloneSetup' in C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:7;
Reported by: -UNKNOWN-)
SEVERE: [ERROR]: No getter or adder method for property 'platformUri' in
clazz 'java.lang.Object' found.(Element: platformUri='..' in C:/Documents
and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:8;
SEVERE: [ERROR]: Class not found: 'org.eclipse.mwe.emf.Reader'(Element:
bean component class='org.eclipse.mwe.emf.Reader' in C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:12;
SEVERE: [ERROR]: No getter or adder method for property 'uri' in clazz
'org.eclipse.emf.mwe.core.WorkflowComponent' found.(Element:
uri='platform:/resource/my.generator.project/src/Model.xmi' in
C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:13;
SEVERE: [ERROR]: No getter or adder method for property 'modelSlot' in
clazz 'org.eclipse.emf.mwe.core.WorkflowComponent' found.(Element:
modelSlot='model' in C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:14;
'org.eclipse.m2t.type.emf.EmfRegistryMetaModel'(Element: bean metaModel
class='org.eclipse.m2t.type.emf.EmfRegistryMetaModel' id='mm' in
C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:20;
'org.eclipse.xtend.xpand2.Generator'(Element: bean component
class='org.eclipse.xtend.xpand2.Generator' in C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:26;
SEVERE: [ERROR]: No setter or adder method for property 'metaModel' in
clazz 'org.eclipse.emf.mwe.core.WorkflowComponent' found(Element:
<metaModel idRef='mm'/> in C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:27;
SEVERE: [ERROR]: No getter or adder method for property 'expand' in clazz
expand='template::Template::main FOR model' in C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:29;
SEVERE: [ERROR]: No getter or adder method for property 'outlet' in clazz
'org.eclipse.emf.mwe.core.WorkflowComponent' found. Forgot to
customize?(Element: bean outlet in C:/Documents and
Settings/Administrator/ws_ssjemf1/my.generator.project/src/w orkflow/generator.mwe:30;
SEVERE: Workflow interrupted because of configuration errors.
xtext generator project works fine.
Is there a problem with the generated MWE file?
<?xml version="1.0"?>
<workflow>
<property name="model" value="my.generator.project/src/Model.xmi" />
<property name="src-gen" value="src-gen" />
<!-- set up EMF for standalone execution -->
<bean class="org.eclipse.mwe.emf.StandaloneSetup" >
<platformUri value=".."/>
</bean>
<!-- load model and store it in slot 'model' -->
<component class="org.eclipse.mwe.emf.Reader">
<uri value="platform:/resource/${model}" />
<modelSlot value="model" />
</component>
<!-- check model -->
<component class="org.eclipse.xtend.check.CheckComponent">
<metaModel id="mm"
class="org.eclipse.m2t.type.emf.EmfRegistryMetaModel"/>
<checkFile value="metamodel::Checks" />
<emfAllChildrenSlot value="model" />
</component>
<!-- generate code -->
<component class="org.eclipse.xtend.xpand2.Generator">
<metaModel idRef="mm"/>
<expand
value="template::Template::main FOR model" />
<outlet path="${src-gen}" >
<postprocessor class="org.eclipse.xtend.xpand2.output.JavaBeautifier" />
</outlet>
</component>
</workflow>
Re: Xpand Project Problems [message #60554 is a reply to message #60540] Sat, 18 July 2009 06:15 Go to previous messageGo to next message
Hi Porter,
please doublecheck any class name in your mwe file.
For example org.eclipse.mwe.emf.StandaloneSetup resides in another
package and should be org.eclipse.emf.mwe.utils.StandaloneSetup.
This is only an example, other class names are likely to be wrong too.
Have a look for Class not found in the log output.
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 18.07.2009 3:39 Uhr, schrieb Porter Ricks:
> files.
> INFO:
> INFO:
> INFO: Jul 18, 2009 11:28:50 AM org.eclipse.emf.mwe.core.WorkflowRunner
> logIssues
> C:/Documents and
> C:/Documents and
> C:/Documents and
> clazz 'org.eclipse.emf.mwe.core.WorkflowComponent' found. Forgot to
> <workflow>
> </bean>
> </component>
> <metaModel id="mm"
> </component>
> <expand
> </outlet>
> </component>
> </workflow>
Re: Xpand Project Problems [message #60839 is a reply to message #60554] Sat, 18 July 2009 07:55 Go to previous messageGo to next message
Sebastian
Thanks for your help. The Standalone setup looked odd to me too since it
referred to a different plugin than the equivalent in the Xtext sample
project.
The MWE file I'm talking about is automatically generated by the Xpand
project wizard.
I realised after posting I should have posted to the M2T newsgroup and
I'll follow up there.
Porter.
Re: Xpand Project Problems [message #60846 is a reply to message #60839] Sat, 18 July 2009 08:11 Go to previous messageGo to next message
Hi Porter,
this is a bug. Please file a ticket for M2T Xpand. Thanks.
Sebastian
Am 18.07.2009 13:55 Uhr, schrieb Porter:
> Sebastian
> project.
> project wizard.
> Thanks
> Porter.
Re: Xpand Project Problems [message #488319 is a reply to message #60846] Mon, 28 September 2009 01:01 Go to previous message
I have the same problem - the xpand example wont work.
My eclipse package is "eclipse-modeling-galileo-SR1-incubation-win32".
After the following workaround you will be able to run the workflow:
1. Add some bundle dependencies:
Require-Bundle: org.eclipse.xpand,
org.eclipse.xtend,
org.eclipse.xtend.typesystem.emf,
org.eclipse.emf.mwe.utils;bundle-version="0.7.2",
org.eclipse.emf.ecore.xmi;bundle-version="2.5.0",
org.eclipse.jface.text;bundle-version="3.5.1",
org.antlr.runtime;bundle-version="3.0.0",
com.ibm.icu;bundle-version="4.0.1",
org.eclipse.core.runtime;bundle-version="3.5.0",
org.eclipse.jdt.core;bundle-version="3.5.1"
2. Replace some lines in workflow.mwe:
* <bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" >
* <component class="org.eclipse.emf.mwe.utils.Reader">
* <metaModel id="mm" class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
* <component class="org.eclipse.xpand2.Generator">
* <postprocessor class="org.eclipse.xpand2.output.JavaBeautifier" />
The whole workflow.mwe file is attached to this message...
Thomas
Previous Topic:Xtext different results for different alternative ordering
Next Topic:Antlr versionitis?
Current Time: Fri Jul 25 02:30:16 EDT 2025
Powered by FUDForum. Page generated in 0.28205 seconds
