Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem upgrading existing automated build to use eclipse 3.5 (related to p2?)
Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #60507] Mon, 11 May 2009 07:16 Go to next message
I have an existing headless build that successfully uses the SDK and delta
pack from 3.4. I recently added dependencies on the latest ECF changes, so
I had to upgrade to 3.5. I replaced the SDK and delta pack from 3.4 with
the ones from 3.5, and I also added the ECF plugin. The build itself
succeeds, but when I run the built application, I get an error having to do
with unresolved bundles (see below), all of which are Equinox p2 bundles. I
read that this problem could indicate that my SDK and delta pack libraries
are incompatible, but I downloaded them from the same build, so that seems
unlikely.
Any ideas? I'm stumped, and I have to resort to manually building (via the
product file UI) and distributing the software for now.
Thanks!
Matt
!SESSION 2009-05-10
16:28:33.820 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_13
Command-line arguments: -os win32 -ws win32 -arch x86 -console -consoleLog
!ENTRY org.eclipse.equinox.registry 2 0 2009-05-10 16:28:35.311
!MESSAGE The extensions and extension-points from the bundle "com.etm.ws"
are ignored. The bundle is not marked as singleton.
!ENTRY org.eclipse.osgi 4 0 2009-05-10 16:28:35.632
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.etm.application" could not be
found in the registry. The applications available are:
com.etm.ui.news.application, org.eclipse.ant.core.antRunner,
org.eclipse.ecf.example.clients.chatroomrobot,
org.eclipse.ecf.example.clients.chatsorobot,
org.eclipse.ecf.example.clients.chatrobot,
org.eclipse.ecf.server.generic.Server, org.eclipse.equinox.app.error.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
!ENTRY org.eclipse.osgi 2 0 2009-05-10 16:28:35.692
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.694
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.equinox.p2.artifact.repository_1.0 .100.v20090430-2300.jar/
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 2 0 2009-05-10
16:28:35.697
!MESSAGE Missing imported package
org.eclipse.equinox.internal.p2.repository_0.0.0.
16:28:35.700
org.eclipse.equinox.internal.provisional.spi.p2.repository_0 .0.0.
16:28:35.703
org.eclipse.equinox.internal.p2.repository.helpers_0.0.0.
16:28:35.705
org.eclipse.equinox.internal.p2.persistence_0.0.0.
16:28:35.708
org.eclipse.equinox.internal.provisional.p2.repository_0.0.0 .
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.711
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.equinox.p2.engine_1.0.100.v2009043 0-0100.jar/
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.713
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.716
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.718
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.720
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.equinox.p2.metadata.repository_1.0 .100.v20090429-2126.jar/
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository 2 0 2009-05-10
16:28:35.723
16:28:35.725
16:28:35.729
16:28:35.732
16:28:35.734
!ENTRY org.eclipse.osgi 2 0 2009-05-10 16:28:35.770
!MESSAGE The following is a complete list of bundles which are not resolved,
see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.772
!MESSAGE Bundle com.etm.network_1.0.0 was not resolved.
!SUBENTRY 2 com.etm.network 2 0 2009-05-10 16:28:35.776
!MESSAGE Missing required bundle org.eclipse.ecf.example.collab_2.0.0.
!SUBENTRY 2 com.etm.network 2 0 2009-05-10 16:28:35.778
!MESSAGE Missing required bundle org.eclipse.ecf.docshare_2.1.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.780
!MESSAGE Bundle com.etm.ui_1.0.0 was not resolved.
!SUBENTRY 2 com.etm.ui 2 0 2009-05-10 16:28:35.782
!MESSAGE Missing required bundle com.etm.ui.network_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.783
!MESSAGE Bundle com.etm.ui.network_1.0.0 was not resolved.
!SUBENTRY 2 com.etm.ui.network 2 0 2009-05-10 16:28:35.785
!MESSAGE Missing required bundle com.etm.network_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.787
!MESSAGE Bundle org.eclipse.ecf.docshare_2.1.0.v20090504-0800 was not
resolved.
!SUBENTRY 2 org.eclipse.ecf.docshare 2 0 2009-05-10 16:28:35.790
!MESSAGE Missing required bundle org.eclipse.ui.editors_0.0.0.
!SUBENTRY 2 org.eclipse.ecf.docshare 2 0 2009-05-10 16:28:35.791
!MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.793
!MESSAGE Bundle org.eclipse.ecf.example.collab_2.0.0.v20090504-0800 was
not resolved.
!SUBENTRY 2 org.eclipse.ecf.example.collab 2 0 2009-05-10 16:28:35.796
!SUBENTRY 2 org.eclipse.ecf.example.collab 2 0 2009-05-10 16:28:35.798
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.800
!MESSAGE Bundle
org.eclipse.equinox.p2.artifact.repository_1.0.100.v20090430 -2300 was
not resolved.
16:28:35.802
16:28:35.805
16:28:35.807
16:28:35.810
16:28:35.813
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.816
!MESSAGE Bundle org.eclipse.equinox.p2.engine_1.0.100.v20090430-0100
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.818
org.eclipse.equinox.p2.metadata.repository_1.0.100.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.820
org.eclipse.equinox.internal.p2.metadata.repository_0.0.0.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.822
org.eclipse.equinox.internal.p2.metadata.repository.io_0.0.0 .
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.824
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.827
org.eclipse.equinox.internal.provisional.p2.artifact.reposit ory_0.0.0.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.829
org.eclipse.equinox.internal.provisional.p2.metadata.reposit ory_0.0.0.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.831
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.834
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository_0.0.0.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.836
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.838
!MESSAGE Bundle
org.eclipse.equinox.p2.metadata.repository_1.0.100.v20090429 -2126 was
not resolved.
16:28:35.841
16:28:35.843
16:28:35.846
16:28:35.849
16:28:35.851
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.854
!MESSAGE Bundle org.eclipse.ui.editors_3.5.0.v20090429-1800b was not
resolved.
!SUBENTRY 2 org.eclipse.ui.editors 2 0 2009-05-10 16:28:35.856
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.5.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.858
!MESSAGE Bundle org.eclipse.ui.ide_3.5.0.I20090429-1800 was not
resolved.
!SUBENTRY 2 org.eclipse.ui.ide 2 0 2009-05-10 16:28:35.860
org.eclipse.equinox.p2.engine_[1.0.100,2.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.862
!MESSAGE Bundle org.eclipse.ui.win32_3.2.100.v20090429-1800 [93] was not
resolved.
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2009-05-10 16:28:35.864
!MESSAGE Missing host org.eclipse.ui.ide_[3.2.0,4.0.0).
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #60533 is a reply to message #60507] Mon, 11 May 2009 08:32 Go to previous messageGo to next message
How are you including the 3.5 Delta pack? You no longer unzip it over the
SDK. We ended up using a separate folder and including this Directory in
the Target Platform.
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #60548 is a reply to message #60533] Mon, 11 May 2009 08:58 Go to previous messageGo to next message
I see. You're right on, I'm still unzipping it over the SDK. I'm having
trouble finding revised instructions for the headless build in 3.5. Can you
point me in the right direction?
" msacarny" <michael.sacarny@analog.com> wrote in message
news:c4a37a5ab66a5fb98ddc13bafd7312dd$1@www.eclipse.org...
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #60560 is a reply to message #60548] Mon, 11 May 2009 09:16 Go to previous messageGo to next message
The location of the delta-pack does not affect headless build headless
build in the same way it does the UI since headless build doesn't know
anything about the new Target Platform.
The error message implies that your product is simply missing some
required bundles. The p2 bundles' dependencies have changed since 3.4,
you appear to be missing org.eclipse.equinox.p2.repository.
Add that bundle, or simply just "Add Required Plug-ins" if you have a
plug-in based .product file.
-Andrew
> having trouble finding revised instructions for the headless build in
> 3.5. Can you point me in the right direction?
>> the SDK. We ended up using a separate folder and including this
>> Directory in the Target Platform.
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #60901 is a reply to message #60560] Mon, 11 May 2009 09:47 Go to previous message
Thanks for the prompt response. I had tried "Add Required Plug-ins", but
that didn't add org.eclipse.equinox.p2.repository. It turns out my install
doesn't have that plug-in. I actually run the automated build on a
different machine. My development eclipse is version 3.5.0 (not sure which
milestone it was from, but I installed in within the past three weeks). On
the automated build machine, I downloaded the most recent SDK and delta pack
(3.5M7). So I'm guessing the unresolved bundles changed between my
installed version and the M7 version? Is there an easy way to update my
install so it's consistent with the M7 build? Or do you recommend
downgrading the SDK and delta pack on the build machine?
-Matt
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:gu98fc$9kv$1@build.eclipse.org...
> -Andrew
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #597167 is a reply to message #60507] Mon, 11 May 2009 08:32 Go to previous message
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #597174 is a reply to message #60533] Mon, 11 May 2009 08:58 Go to previous message
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #597180 is a reply to message #60548] Mon, 11 May 2009 09:16 Go to previous message
-Andrew
Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #597185 is a reply to message #60560] Mon, 11 May 2009 09:47 Go to previous message
-Matt
> -Andrew
Previous Topic:Problem upgrading existing automated build to use eclipse 3.5 (related to p2?)
Next Topic:[target] Adding a feature
Current Time: Fri Jul 18 05:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.10001 seconds
