Home » Archived » XML Schema Definition (XSD) » Problems with generating list types
Problems with generating list types [message #60495] Tue, 03 May 2005 09:50 Go to next message
I want to create the following list type programatically:
<xs:simpleType name="myType">
<xs:restriction>
<xs:simpleType>
<xs:list itemType="xs:integer"/>
</xs:simpleType>
<xs:length value="4"/>
</xs:restriction>
</xs:simpleType>
I create the list type with the following code:
XSDSimpleTypeDefinition simpleType = XSDFactory.eINSTANCE
.createXSDSimpleTypeDefinition();
simpleType.setItemTypeDefinition(itemType);
xsdSchema.getContents().add(simpleType);
If I query simpleType.getValidFacets() I get length, maxLength, minLength,
whiteSpace, enumeration and pattern as valid facets of this type so I
presumed that I can add the length-facet directly to the new list type. But
when I serialize it to a file I get
<xs:simpleType>
<xs:list itemType="xs:integer">
</xs:list>
</xs:simpleType>
What have I done wrong? Or am I mislead by the list of valid facets and I
have to create an anonymous list type which is added as the base type of
"myType" and there it is possible to set the facets?
Cheers
Klaas
Re: Problems with generating list types [message #60519 is a reply to message #60495] Tue, 03 May 2005 10:30 Go to previous messageGo to next message
Klaas,
Your sample is a simpler version of initializeFancyListTypeDefinition
from XSDPrototypical schema. (Yes, you need to set the anonymous base
type by adding it to simpleType.getContents() in addition to setting it
as the base type.)
Klaas Dellschaft wrote:
>Hi,
> <xs:restriction>
> <xs:simpleType>
> </xs:simpleType>
> </xs:restriction>
></xs:simpleType>
><xs:simpleType>
> </xs:list>
></xs:simpleType>
>Cheers
>Klaas
Re: Problems with generating list types [message #60536 is a reply to message #60519] Wed, 04 May 2005 03:08 Go to previous messageGo to next message
> Your sample is a simpler version of initializeFancyListTypeDefinition from
> XSDPrototypical schema. (Yes, you need to set the anonymous base type by
> adding it to simpleType.getContents() in addition to setting it as the
> base type.)
OK, I will do that. But why do I get a list of valid facets for the
simpleType if it isn't allowed to attach facets to it? This prevents me from
generically allowing editing the facets of types. Instead I have to ask
whether I edit a list-, union- or atomic-type and only then I know whether I
can trust the information given by getValidFacets().
This is also a problem in the Eclipse plugin: If you create a new list type
and the right click on it -> New Child. There you will see that it allows to
add facets directly to the type which will also result in a wrong serialized
type.
Klaas
Re: Problems with generating list types [message #60965 is a reply to message #60536] Thu, 05 May 2005 07:15 Go to previous messageGo to next message
--------------030802040009090005000101
Klaas,
Asking the valid facets is really a question about what facets are
allowed in any derived class based on that type, it's not a question
about what syntactically I can do with the type definition itself. The
contents can really be one of three different things depending on the
nature of the simple type:
* Returns the value of the '<em><b>Contents</b></em>' containment
reference list.
* The list contents are of type {@link
org.eclipse.xsd.XSDSimpleTypeDefinition}.
* <!-- begin-user-doc -->
* <p>
* This concrete reference list represents the anonymous simple
type definition content of a
* <a
href="http://www.w3.org/TR/xmlschema-2/#element-restriction">restriction</a>,
* <a
href="http://www.w3.org/TR/xmlschema-2/#element-list">list</a>, or
* <a
href="http://www.w3.org/TR/xmlschema-2/#element-union">union</a>
element.
* </p>
* <!-- end-user-doc -->
* @return the value of the '<em>Contents</em>' containment
reference list.
* @see
org.eclipse.xsd.XSDPackage#getXSDSimpleTypeDefinition_Conten ts()
* @model type="org.eclipse.xsd.XSDSimpleTypeDefinition"
containment="true"
* @generated
EList getContents();
I believe that a simple test to know if it's syntactically valid to add
facets to a given simple type is to test if the variety of the base type
is the same as the variety of the type itself.
>>base type.)
>type.
>Klaas
<html>
<head>
<title></title>
</head>
Klaas,<br>
<br>
about what syntactically I can do with the type definition itself.&nbsp; The
nature of the simple type:<br>
<blockquote><small>&nbsp; /**<br>
&nbsp;&nbsp; * Returns the value of the
'&lt;em&gt;&lt;b&gt;Contents&lt;/b&g t;&lt;/em&gt;' containment
reference list.<br>
&nbsp;&nbsp; * The list contents are of type {@link
org.eclipse.xsd.XSDSimpleTypeDefinition}.<br>
&nbsp;&nbsp; * &lt;!-- begin-user-doc --&gt;<br>
&nbsp;&nbsp; * &lt;p&gt;<br>
&nbsp;&nbsp; * This concrete reference list represents the anonymous simple type
definition content of a<br>
&nbsp;&nbsp; * &lt;a
href=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/TR/xmlschema-2/#element-restriction">"http://www.w3.org/TR/xmlschema-2/#element-restriction"</a>&gt;restriction&lt;/a&gt;,<br>
href=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/TR/xmlschema-2/#element-list">"http://www.w3.org/TR/xmlschema-2/#element-list"</a>&gt;list&lt;/a&gt;,
or<br>
href=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/TR/xmlschema-2/#element-union">"http://www.w3.org/TR/xmlschema-2/#element-union"</a>&gt;union&lt;/a&gt;
element.<br>
&nbsp;&nbsp; * &lt;/p&gt;<br>
&nbsp;&nbsp; * &lt;!-- end-user-doc --&gt;<br>
&nbsp;&nbsp; * @return the value of the '&lt;em&gt;Contents&lt;/em&gt;'
containment reference list.<br>
&nbsp;&nbsp; * @see
org.eclipse.xsd.XSDPackage#getXSDSimpleTypeDefinition_Conten ts() <br>
&nbsp;&nbsp; * @model type="org.eclipse.xsd.XSDSimpleTypeDefinition"
containment="true"<br>
&nbsp;&nbsp; * @generated<br>
&nbsp;&nbsp; */<br>
&nbsp; EList getContents();</small><br>
</blockquote>
type is the same as the variety of the type itself. <br>
<br>
<br>
<blockquote cite="midd59so6$909$1@news.eclipse.org" type="cite">
<blockquote type="cite">
<pre wrap="">Your sample is a simpler version of initializeFancyListTypeDefinition from
base type.)
</pre>
</blockquote>
<pre wrap=""><!---->
and the right click on it -&gt; New Child. There you will see that it allows to
type.
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
--------------030802040009090005000101--
Re: Problems with generating list types [message #61062 is a reply to message #60965] Mon, 09 May 2005 09:01 Go to previous messageGo to next message
I think a better test would be whether getBaseTypeDefinition() returns null
or not. Only if it returns a concrete reference the current type is a
restriction of another type. The base type might be an atomic, list or union
type.
Should the XSD plugin be comfortable enough that it is impossible to create
invalid schemas or does the user have to know what he's doing? If it should
be impossible to create invalid schema instances then you have to add the
test into the plugin, too.
Cheers
Klaas
Re: Problems with generating list types [message #61085 is a reply to message #61062] Mon, 09 May 2005 09:32 Go to previous message
--------------010009010700000307060604
Klaas,
There's always a base type definition, even if it is just
anyType/anySimpleType.
Some of these scenarios are tricky to enforce because setting one thing
may invalidate something you've already set. For example, I could add a
simple type definition to the contents of a simple type definition and
then set it as the base type, item type, or member type after, so you
kind of need to know what you are doing. (The editor should do a better
job, but we don't have the resource to make the editor really nice.)
Validation should diagnose any errors in how things are set up.
>type.
>Cheers
>Klaas
<html>
<head>
</head>
Klaas,<br>
<br>
anyType/anySimpleType.<br>
<br>
may invalidate something you've already set.&nbsp; For example, I could add
a simple type definition to the contents of a simple type definition
and then set it as the base type, item type, or member type after, so
you kind of need to know what you are doing.&nbsp; (The editor should do a
better job, but we don't have the resource to make the editor really
nice.)&nbsp; Validation should diagnose any errors in how things are set up.<br>
<br>
<br>
<blockquote cite="midd5nndk$u4b$1@news.eclipse.org" type="cite">
<pre wrap="">I believe that a simple test to know if it's syntactically valid to add
</pre>
</blockquote>
type.
Cheers
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
--------------010009010700000307060604--
Re: Problems with generating list types [message #595355 is a reply to message #60495] Tue, 03 May 2005 10:30 Go to previous message
Klaas,
as the base type.)
>Hi,
> <xs:restriction>
> <xs:simpleType>
> </xs:simpleType>
> </xs:restriction>
></xs:simpleType>
><xs:simpleType>
> </xs:list>
></xs:simpleType>
>Cheers
>Klaas
Re: Problems with generating list types [message #595366 is a reply to message #60519] Wed, 04 May 2005 03:08 Go to previous message
> base type.)
type.
Klaas
Re: Problems with generating list types [message #595410 is a reply to message #60536] Thu, 05 May 2005 07:15 Go to previous message
Klaas,
reference list.
* <p>
* <a
* <a
* <a
element.
* </p>
reference list.
* @see
containment="true"
* @generated
>>base type.)
>type.
>Klaas
<html>
<head>
<title></title>
</head>
Klaas,<br>
<br>
reference list.<br>
or<br>
element.<br>
&nbsp;&nbsp; * @see
&nbsp;&nbsp; */<br>
</blockquote>
<br>
<br>
base type.)
</pre>
</blockquote>
type.
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
Re: Problems with generating list types [message #595449 is a reply to message #60965] Mon, 09 May 2005 09:01 Go to previous message
type.
Cheers
Klaas
Re: Problems with generating list types [message #595453 is a reply to message #61062] Mon, 09 May 2005 09:32 Go to previous message
Klaas,
>type.
>Cheers
>Klaas
<html>
<head>
</head>
Klaas,<br>
<br>
<br>
<br>
<br>
</pre>
</blockquote>
type.
Cheers
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:2 suggestions for XSD
Next Topic:2 suggestions for XSD
Current Time: Tue Jul 15 08:35:02 EDT 2025
Powered by FUDForum. Page generated in 0.26958 seconds
