Home » Archived » BIRT » Error while running BIRT Chart Examples
Error while running BIRT Chart Examples [message #60475] Thu, 21 July 2005 05:05 Go to next message
Originally posted by: nemesis.gmail.com
hi, i've been trying to run the char examples along BIRT 1.0 download
however when running the application i'm getting the following errors any
help?
[ERR]: org.eclipse.birt.chart.exception.PluginException: Unable to locate
any entries for lookup=dv.SWT; element=(name:device) in any plugin.xml
file in all of the available plugins
org.eclipse.birt.chart.exception.PluginException: Unable to locate any
entries for lookup=dv.SWT; element=(name:device) in any plugin.xml file in
org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObjec t(PluginSettings.java:636)
org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginS ettings.java:324)
org.eclipse.birt.chart.examples.api.format.ColoredByCategory . <init>(ColoredByCategory.java:107)
org.eclipse.birt.chart.examples.api.format.ColoredByCategory .main(ColoredByCategory.java:75)
java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1780)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:355)
at org.eclipse.swt.widgets.Display.<init>(Display.java:351)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:993)
org.eclipse.birt.chart.examples.api.format.ColoredByCategory .main(ColoredByCategory.java:78)
Exception in thread "main"
Re: Error while running BIRT Chart Examples [message #60566 is a reply to message #60475] Thu, 21 July 2005 20:40 Go to previous message
Greeting,
Please make sure that you had added the following VM arguments variables
into your application run configurations:
-DSTANDALONE -DBIRT_HOME=<eclipse_install_directory>
-Djava.library.path=<eclipse_install_directory>\plugins\
org.eclipse.swt.<windowing_system>_<eclipse_version_number >\os\<operating_system>\<processor_architecture>
E.g. For Windows, it could be
plugins\org.eclipse.swt.win32_3.0.1\os\win32\x86 inside the Eclipse
installation directory.
For Mac OS X, it could be
plugins\org.eclipse.swt.carbon_3.0.0\os\macosx\ppc
Cheers.
Nina
Previous Topic:Avoid pdf file
Next Topic:Navigation
Current Time: Thu Jul 17 19:02:28 EDT 2025
Powered by FUDForum. Page generated in 0.03202 seconds
