codegen - merging problem [message #60468] |
Thu, 09 November 2006 15:43  |
Originally posted by: zazo7.wp.pl
I would like to merge two files using EMF's JMerge. What is the right
way to initialize JControlModel object? When trying to run code below I
get NullPointerException due to fact that 'facadeHelper' is empty.
JControlModel jControlModel = new JControlModel();
//FIXME: facadeHelper is null
jControlModel.initialize(null, config.getMergeXmlFullUri());
JMerger jMerger = new JMerger(jControlModel);
jMerger.setSourceCompilationUnit(jMerger
.createCompilationUnitForContents(emitterResult));
jMerger.setTargetCompilationUnit(jMerger
.createCompilationUnitForInputStream(targetFile
.getContents(true)));
String oldContents = jMerger.getTargetCompilationUnit().getContents();
jMerger.merge();
I've been looking for some examples how to solve this. The only one I've
found looks like this:
String uri =
Platform.getPlugin(PLUGIN_ID).getDescriptor().getInstallURL( ).toString();
uri += "templates/merge.xml";
JMerger jmerger = new JMerger();
JControlModel controlModel = new JControlModel( uri );
jmerger.setControlModel( controlModel );
However, I belive, this one refers to the older version of EMF :/
Thanks for any help.
Tomasz
Re: codegen - merging problem [message #60488 is a reply to message #60468] |
Thu, 09 November 2006 16:03  |
--------------070903060701090901010501
Content-Type: text/plain; charset=UTF-8; format=flowed
Tomasz,
In org.eclipse.emf.codegen.merge.java.JMerger there's code like this:
* Utilitiy for headless operations.
* @param mergeXML
* @param sourceURI
* @param targetURI
* @return the merged content
public String execute(Monitor monitor, String[] arguments)
String mergeXML = arguments[0];
String sourceURI = arguments[1];
String targetURI = arguments[2];
String facadeHelperClass = arguments.length > 3 ? arguments[3] :
DEFAULT_FACADE_HELPER_CLASS;
// Create the options model.
controlModel = new JControlModel();
controlModel.initialize(CodeGenUtil.instantiateFacadeHelper( facadeHelperClass),
mergeXML);
We're just fine tuning the AST-based merger
" org.eclipse.emf.codegen.merge.java.facade.ast.ASTFacadeHelpe r " which
will support merging Java 5.0 syntax, so you could try that as an
argument for the facade helper as well (if you are using 2.3M3 which
will be available later today and you want to be a guinea pig).
Tomasz Zarna wrote:
> jMerger.merge();
> String uri =
> Regards
> Tomasz
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Tomasz,<br>
<br>
In org.eclipse.emf.codegen.merge.java.JMerger there's code like this:<br>
<blockquote><small> /**</small><br>
<small> * Utilitiy for headless operations.</small><br>
<small> * </small><br>
<small> * @param mergeXML</small><br>
<small> * @param sourceURI</small><br>
<small> * @param targetURI</small><br>
<small> * @return the merged content</small><br>
<small> */</small><br>
<small> public String execute(Monitor monitor, String[] arguments)</small><br>
<small> {</small><br>
<small> String mergeXML = arguments[0];</small><br>
<small> String sourceURI = arguments[1];</small><br>
<small> String targetURI = arguments[2];</small><br>
<small> String facadeHelperClass = arguments.length > 3 ?
arguments[3] : DEFAULT_FACADE_HELPER_CLASS;</small><br>
<small> </small><br>
<small> // Create the options model.</small><br>
<small> //</small><br>
<small> controlModel = new JControlModel();</small><br>
<small>
mergeXML);</small><br>
</blockquote>
will be available later today and you want to be a guinea pig).<br>
<br>
<br>
Tomasz Zarna wrote:
<blockquote cite="midej03sl$v41$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
jMerger.merge();
<br>
<br>
<br>
<br>
<br>
I've
<br>
<br>
<br>
<br>
String uri =
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Tomasz
<br>
</blockquote>
<br>
</body>
</html>
--------------070903060701090901010501--
Re: codegen - merging problem [message #595356 is a reply to message #60468] |
Tomasz,
* @param mergeXML
* @param sourceURI
* @param targetURI
mergeXML);
Tomasz Zarna wrote:
> jMerger.merge();
> String uri =
> Regards
> Tomasz
<html>
<head>
<title></title>
</head>
Tomasz,<br>
<br>
<small>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
jMerger.merge();
<br>
<br>
<br>
<br>
<br>
I've
<br>
<br>
<br>
<br>
String uri =
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Tomasz
<br>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.04790 seconds
