eclipse suddenly crashed? [message #60360] |
Sun, 01 May 2005 21:48  |
Originally posted by: cwalnutx.163.com
hi,all
i re-installed jdk1.4.2_01 to d:\j2sdk\
and unzipped eclispe3.0 to d:\eclipse\
when i start eclipse.exe, it seems
everything is ok. but after about 20
seconds,eclipse crashed without any sign.
and a messagebox says:
JVM terminated. Exit code=1
c:\WINDOWS\system32\javaw.exe
-cp D:\eclipse\startup.jar org.eclipse.core.auncher.Main
-os win32
-ws win32
-arch x86
-showsplash d:\eclipse\eclipse.exe -showsplash 600
-exitdata d:\eclipse\eclipse.exe -exitdata d74_60
-vm c:\windows\system32\javaw.exe
-vmargs
-cp d:\eclipse\startup.jar org.eclipse.core.aluncher.Main
i also try to start eclipse with arg:eclipse -vm d:\j2sdk\jre\javaw.exe
but the same problem occured.
i have re-install jdk and eclipse for many times with different version
i am very frustrated now.
can anyone help me out.
Thanks!
Re: eclipse suddenly crashed? [message #60762 is a reply to message #60744] |
Tue, 03 May 2005 03:31   |
hi,Csaba
i have try the parameter that you posted
but the problem remained
i found the log file, it says as follow.
sometimes when eclipse starting, javaw.exe crashed.
its very weird, i haven't met this problem before
i re-installed winxp.
!SESSION 五月 03, 2005 15:19:12.26
eclipse.buildId=I200406251208
java.version=1.4.2_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
!ENTRY org.eclipse.osgi 五月 03, 2005 15:19:12.26
!MESSAGE Application error
!STACK 1
java.lang.VerifyError: (class: org/eclipse/ui/internal/ViewFactory$1,
method: run signature: ()V) Inconsistent stack height 2 != 1919942655
org.eclipse.ui.internal.ViewFactory.busyRestoreView(ViewFact ory.java:259)
at org.eclipse.ui.internal.ViewFactory$2.run(ViewFactory.java:5 16)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.ViewFactory.restoreView(ViewFactory. java:514)
org.eclipse.ui.internal.ViewFactory$ViewReference.getPart(Vi ewFactory.java:102)
org.eclipse.ui.internal.WorkbenchPage$1.propertyChange(Workb enchPage.java:132)
at org.eclipse.ui.internal.LayoutPart.setVisible(LayoutPart.jav a:268)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 7)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:56 4)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:122)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n.selectPart(DefaultPartPresentation.java:1111)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:946)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:10 20)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:383)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:367)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:432)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:155)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:722)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2020)
org.eclipse.ui.internal.WorkbenchWindow$4.run(WorkbenchWindo w.java:1858)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1845)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:498)
org.eclipse.ui.internal.WorkbenchWindow$3.run(WorkbenchWindo w.java:1076)
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:1073)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:992)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:174)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:658)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:819)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY org.eclipse.osgi 五月 03, 2005 15:19:12.86
!MESSAGE The class "org.eclipse.ui.internal.progress.NewProgressViewer"
cannot be loaded because the system is shutting down and the plug-in
"org.eclipse.ui.workbench" has already been stopped.
!STACK 0
java.lang.ClassNotFoundException: The class
"org.eclipse.ui.internal.progress.NewProgressViewer" cannot be loaded
org.eclipse.core.runtime.adaptor.EclipseClassLoader.shouldAc tivateFor(EclipseClassLoader.java:147)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:62)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
org.eclipse.ui.internal.progress.FinishedJobs.keep(FinishedJ obs.java:93)
org.eclipse.ui.internal.progress.FinishedJobs$1.removeJob(Fi nishedJobs.java:73)
org.eclipse.ui.internal.progress.ProgressManager.removeJobIn fo(ProgressManager.java:577)
org.eclipse.ui.internal.progress.ProgressManager$1.done(Prog ressManager.java:384)
org.eclipse.core.internal.jobs.JobListeners$3.notify(JobList eners.java:43)
org.eclipse.core.internal.jobs.JobListeners.doNotify(JobList eners.java:102)
at org.eclipse.core.internal.jobs.JobListeners.done(JobListener s.java:186)
at org.eclipse.core.internal.jobs.JobManager.cancel(JobManager. java:197)
at org.eclipse.core.internal.jobs.InternalJob.cancel(InternalJo b.java:138)
at org.eclipse.core.runtime.jobs.Job.cancel(Job.java:183)
org.eclipse.core.internal.events.BuildManager.shutdown(Build Manager.java:810)
org.eclipse.core.internal.resources.Workspace.shutdown(Works pace.java:1767)
at org.eclipse.core.internal.resources.Workspace.close(Workspac e.java:316)
org.eclipse.core.resources.ResourcesPlugin.shutdown(Resource sPlugin.java:324)
org.eclipse.core.internal.compatibility.PluginActivator.stop (PluginActivator.java:74)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:990)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:502)
org.eclipse.osgi.framework.internal.core.AbstractBundle.stop (AbstractBundle.java:437)
org.eclipse.core.runtime.adaptor.BundleStopper.basicStopBund les(BundleStopper.java:75)
org.eclipse.core.runtime.adaptor.BundleStopper.stopBundles(B undleStopper.java:62)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSto pping(EclipseAdaptor.java:551)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:457)
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.java:182)
at java.lang.Thread.run(Thread.java:534)
!ENTRY org.eclipse.core.runtime 4 2 五月 03, 2005 15:19:12.96
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/ui/internal/progress/NewProgressViewer
Re: eclipse suddenly crashed? [message #60769 is a reply to message #60762] |
Tue, 03 May 2005 09:09   |
Originally posted by: hcs33.egon.gyaloglo.hu
I did not see such exceptions before so I cannot help much more.
One final though: you can produce crashes in a brand new workspace as well?
Also - if you can - you should try Eclipse version 3.0.2 and jdk 1.4.2_08
because those are the last available stable versions and there are a couple
of bug fixes in them.
HTH,
Csaba
WaVe wrote:
> hi,Csaba
> !STACK 1
> at
> at
02)
> at
2)
> at
Part.java:122)
> at
> at
a:946)
> at
va:432)
> at
5)
> at
> at
> at
845)
> at
8)
> at
> at
> at
> at
figurer.java:174)
> at
a:658)
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> !STACK 0
> at
> at
assLoader.java:62)
> at
oader.java:371)
> at
..java:402)
> at
> at
> at
73)
> at
er.java:577)
> at
:384)
> at
> at
> at
> at
> at
> at
..java:74)
> at
xtImpl.java:994)
> at java.security.AccessController.doPrivileged(Native Method)
> at
tImpl.java:990)
> at
va:502)
> at
java:437)
> at
r.java:75)
> at
a:62)
> at
ptor.java:551)
> at
57)
> at
a:182)
> !STACK 0
> at
> at
73)
> at
er.java:577)
> at
:384)
> at
> at
> at
> at
> at
> at
..java:74)
> at
xtImpl.java:994)
> at
tImpl.java:990)
> at
va:502)
> at
java:437)
> at
r.java:75)
> at
a:62)
> at
ptor.java:551)
> at
57)
> at
a:182)
Re: eclipse suddenly crashed? [message #60809 is a reply to message #60793] |
Thu, 05 May 2005 08:15  |
Sorry, i have deleted eclipse and workspace from my disk.
Thanks you very much anyway.
Now i am using JCreator to study SWT.
It's much smaller and faster than eclipse and
it works well.
^_^
WaVe
FUDForum. Page generated in 0.29643 seconds
