Home » Archived » EPF » Publication
Publication [message #5357] Mon, 10 April 2006 09:52 Go to next message
Originally posted by: user.domain.com
Ive been trying to figure out how the Composer works and now I want to
Publish the information. However the framesets exhibit errors such as
Firefox can't find the file at /C:/Documents and
Settings/anderst/EPF/Publish/spscreen.htm.
Settings/anderst/EPF/Publish/applet/myruptree.htm.
Is there a setting I can use to fix this or is this a commonly know deficit?
thanks
/anders
Re: Publication [message #5397 is a reply to message #5357] Mon, 10 April 2006 13:06 Go to previous messageGo to next message
Thanks for finding this. There is a problem in publishing with the
I20060407 build. This build had a lot of changes merged in. You should
try working with the 1.0-M1 build for now. It is stable and publishing
works well. The 1.0-M2 build is scheduled for release around the end of
this week.
I opened a Bugzilla record on this one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=135926
user@domain.com wrote:
> deficit?
> thanks
> /anders
Re: Publication [message #6858 is a reply to message #5397] Tue, 11 April 2006 03:33 Go to previous messageGo to next message
ok, but I rather like the new features ;)
Is it possible to checkout the source and build the latest code by myself?
/anders
> this week.
>> deficit?
>> thanks
>> /anders
Re: Publication [message #6880 is a reply to message #6858] Tue, 11 April 2006 11:04 Go to previous messageGo to next message
You can do this yourself. In fact, the publishing problem you
experienced has been fixed in the HEAD revision of the source and will
be included in the next integration build.
You can find all the information you need to configure your environment,
get a copy of the source through anonymous CVS, and build and run here:
http://www.eclipse.org/epf/composer_dev_guide/
Open one of the beacon-XX.product files for your platform found in the
org.eclipse.epf.rcp project. There is an option to start the product
export wizard to build and package a zip. This step isn't in the guide yet.
Thanks!
> /anders
>> of this week.
>>> Hi,
>>> to Publish the information. However the framesets exhibit errors such as
>>> deficit?
>>> thanks
>>> /anders
Re: Publication [message #6904 is a reply to message #6880] Tue, 11 April 2006 13:01 Go to previous messageGo to next message
Thanks Jim,
Ive managed to do the whole checkout, compilation etc. exercise so Im on
track again.
thanks!
/anders
> Thanks!
>> myself?
>> /anders
>>> should try working with the 1.0-M1 build for now. It is stable and
>>> publishing works well. The 1.0-M2 build is scheduled for release
>>> around the end of this week.
>>>> Hi,
>>>> such as
>>>> deficit?
>>>> thanks
>>>> /anders
Re: Publication [message #7141 is a reply to message #6904] Sat, 15 April 2006 11:27 Go to previous messageGo to next message
Originally posted by: yujen.ms9.url.com.tw
use EPF Composer to publication have error, but use RMC to publication ,
it's okay.
Re: Publication [message #7165 is a reply to message #7141] Sat, 15 April 2006 13:25 Go to previous messageGo to next message
Please include the version of EPF Composer you are using when reporting
problems. Thanks.
> it's okay.
Re: Publication [message #7188 is a reply to message #7165] Mon, 17 April 2006 08:34 Go to previous messageGo to next message
Build Label: 20060209-1450
publish error pages in "Reference Workflows" "Tasks" "Guidance"
> problems. Thanks.
>> it's okay.
Re: Publication [message #7211 is a reply to message #7188] Mon, 17 April 2006 11:23 Go to previous message
I will check the latest integration build to see if the problem is still
in there, and if so, open a defect in Bugzilla on this.
Thanks.
>> reporting problems. Thanks.
>>> publication , it's okay.
Re: Publication [message #562170 is a reply to message #5357] Mon, 10 April 2006 13:06 Go to previous message
this week.
> deficit?
> thanks
> /anders
Re: Publication [message #562199 is a reply to message #5397] Tue, 11 April 2006 03:33 Go to previous message
/anders
> this week.
>> deficit?
>> thanks
>> /anders
Re: Publication [message #562224 is a reply to message #6858] Tue, 11 April 2006 11:04 Go to previous message
Thanks!
> /anders
>> of this week.
>>> Hi,
>>> deficit?
>>> thanks
>>> /anders
Re: Publication [message #562247 is a reply to message #6880] Tue, 11 April 2006 13:01 Go to previous message
Thanks Jim,
track again.
thanks!
/anders
> Thanks!
>> myself?
>> /anders
>>>> Hi,
>>>> such as
>>>> deficit?
>>>> thanks
>>>> /anders
Re: Publication [message #562494 is a reply to message #6904] Sat, 15 April 2006 11:27 Go to previous message
it's okay.
Re: Publication [message #562519 is a reply to message #7141] Sat, 15 April 2006 13:25 Go to previous message
problems. Thanks.
> it's okay.
Re: Publication [message #562543 is a reply to message #7165] Mon, 17 April 2006 08:34 Go to previous message
> problems. Thanks.
>> it's okay.
Re: Publication [message #562567 is a reply to message #7188] Mon, 17 April 2006 11:23 Go to previous message
Thanks.
Previous Topic:Terminal Server support?
Next Topic:EPF Composer 1.0-M2
Current Time: Thu Jul 17 20:32:52 EDT 2025
Powered by FUDForum. Page generated in 0.11617 seconds
