Home » Eclipse Projects » Equinox » Conveying OSGI runtime options to serverside OSGI
Conveying OSGI runtime options to serverside OSGI [message #60342] Tue, 07 February 2006 16:32 Go to next message
Can OSGI runtime properties be conveyed to OSGI running under the server?
Are there any limitations? In particular, I am interested in
osgi.resolverMode property to allow a server to run in strict mode or not
when there is a desire to enforce class access restriction rules.
Can I presume that they can be conveyed to a server with as -D vmarg when
the server is started? Is there any opportunity to convey them just to the
web container running OSGI? Also in a OSGI start/redeploy console command
(sp_start, sp_redeploy) so that the properties are localized to the web
Thanks!
Jim D'Anjou
Re: Conveying OSGI runtime options to serverside OSGI [message #60366 is a reply to message #60342] Tue, 07 February 2006 16:51 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi Jim,
You can see an example of sending runtime properties on the servlet.bridge
HEAD.
This is using the new FrameworkProperties so they are per web container.
For now, you can use -Dxxx however these will be for all OSGi instances in
the process.
I think having an init param or something similar to set runtime properties
is a good idea.
Can you open an enhancement request.
-Simon
"Jim D'Anjou" <danjou@us.ibm.com> wrote in message
news:7d48b0ef29506d9f727bdc21fefed2d8$1@www.eclipse.org...
> Thanks!
> Jim D'Anjou
Re: Conveying OSGI runtime options to serverside OSGI [message #61110 is a reply to message #60366] Thu, 09 February 2006 21:54 Go to previous messageGo to next message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Here we should introduce a startup path that allows the set of framework
properties to be passed in.
Jeff
"Simon Kaegi" <skaegi@sympatico.ca> wrote in message
news:dsb4qf$hnk$1@utils.eclipse.org...
> Hi Jim,
> HEAD.
> the process.
properties
> is a good idea.
> -Simon
server?
not
when
the
command
> > Thanks!
> > Jim D'Anjou
Re: Conveying OSGI runtime options to serverside OSGI [message #61132 is a reply to message #61110] Thu, 09 February 2006 22:10 Go to previous message
I'd really like this if there's time as the FrameworkProperties are in an
internal package.
I'll open an enhancement request.
-Simon
"Jeff McAffer" <jeff_nospam_mcaffer@ca.ibm.com> wrote in message
news:dsgv8e$otl$1@utils.eclipse.org...
> Jeff
> > Hi Jim,
servlet.bridge
> > HEAD.
in
> > the process.
> properties
> > is a good idea.
> > -Simon
> server?
> not
> when
> the
> command
web
> > > Thanks!
> > > Jim D'Anjou
Previous Topic:sp_redeploy creates class cast exceptions for session attributes
Next Topic:Declarative services
Current Time: Mon Jul 14 06:51:38 EDT 2025
Powered by FUDForum. Page generated in 0.05241 seconds
