Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Performance Problem with Teneo 200610261350 / Jpox 1.1.3
Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #60282] Wed, 08 November 2006 07:58 Go to next message
Good news upfront:
with 200610261350 and Jpox 1.1.3 I am able to persist
my model to postgres again. I'll try Oracle this week.
However, the performance dropped to unacceptable levels.
My 53MB XML/EMF file took around 90secs with JPOX 1.1.0rc1. to persist,
and now I am well above 25 minutes with the same hardware setup.
Turning on debugging reveals numerous calls to
EContainerRepairControl(). Is this the reason
for my performance problem ? Is there a way around that ?
Any more debugging information I should supply ?
Yours,
Steffen
Trying to persist /vol/tools/E77L_ColHalle_1 1.mzData
22762 [main] DEBUG org.eclipse.emf.teneo.EContainerRepairControl -
Repairing container relations of children of:
de.ipb.msbi.Mzdata.impl.DataTypeImpl
22766 [main] DEBUG org.eclipse.emf.teneo.EContainerRepairControl -
de.ipb.msbi.Mzdata.impl.PeakListBinaryTypeImpl
22767 [main] DEBUG org.eclipse.emf.teneo.EContainerRepairControl -
Repairing reference data to child de.ipb.msbi.Mzdata.DataType
23627 [main] DEBUG org.eclipse.emf.teneo.EContainerRepairControl -
23628 [main] DEBUG org.eclipse.emf.teneo.EContainerRepairControl -
24354 [main] DEBUG
org.eclipse.emf.teneo.mapping.elist.PersistableFeatureMap - Created
persistable featuremap FeatureMap of member group owned by
de.ipb.msbi.Mzdata.impl.AcquisitionTypeImpl with delegate list
java.util.ArrayList
24359 [main] DEBUG org.eclipse.emf.teneo.jpox.elist.FeatureMapWrapper -
Creating feature map wrapper for
org.eclipse.emf.teneo.jpox.elist.GenericFeatureMapEntry
24362 [main] DEBUG org.eclipse.emf.teneo.EContainerRepairControl -
Repairing reference cvParam to child de.ipb.msbi.Mzdata.CvParamType
Repairing reference userParam to child de.ipb.msbi.Mzdata.UserParamType
24362 [main] DEBUG org.eclipse.emf.teneo.mapping.elist.PersistableEList
- Created persistable list EList of type:
org.eclipse.emf.teneo.jpox.elist.EListWrapper of member acquisition
owned by de.ipb.msbi.Mzdata.impl.AcqSpecificationTypeImpl with delegate
list java.util.ArrayList
24363 [main] DEBUG org.eclipse.emf.teneo.EContainerRepairControl -
Repairing reference acquisition to child de.ipb.msbi.Mzdata.AcquisitionType
Old, known good configuration:
Trying to get PersistenceManager...
0 [main] INFO org.elver.store.jpox.emf.JpoxHelper - Registering a
jpox resource factory for all uri's with jpox as the protocol/extension
3 [main] INFO org.elver.store.jpox.emf.JpoxHelper - Registering a
jpox resource factory for all uri's with ejdo as the protocol/extension
jpox resource dao factory for all uri's with jpoxdao as the
protocol/extension
8 [main] INFO org.elver.store.jpox.emf.JpoxHelper - Registering
EListMapping, EListWrapper at the jpox manager for handling elists
FeatureMapMapping, FeatureMapWrapper at the jpox manager for handling
FeatureMap
EObjectMapping at the jpox manager for handling EObjects/AnyType
XMLCalendarMapping at the jpox manager for handling EObjects/AnyType
9 [main] INFO org.elver.store.jpox.emf.JpoxHelper - Registering
XMLDurationMapping at the jpox manager for handling EObjects/AnyType
1156 [main] INFO JPOX.JDO - PersistenceManagerFactory - Vendor: JPOX
Version: 1.1.0-rc-1
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #60310 is a reply to message #60282] Wed, 08 November 2006 08:33 Go to previous messageGo to next message
The repaircontrol is done for each item added to the internal cache of jpox and when a resource is
loaded from the database. The repair is called for each object (and its children).
Does the cpu show very much database activity? Or is java the main process?
To prevent the calls to repaircontainer:
As you are persisting (saving) the calls to repaircontrol are probably from the cache. Teneo uses
its own cache implementation to do the repaircontrol. See the constructor in the JpoxDataStore:
properties.setProperty(PMFConfiguration.CACHE_LEVEL_1_TYPE_P ROPERTY,
"org.eclipse.emf.teneo.jpox.cache.EMFWeakRefCache");
What you can try is set the standard jpox weakrefcache (org.jpox.cache.WeakRefCache) instead of the
teneo. You can set this in the properties of the jpoxdatastore,
If this helps then the repair control is the reason for the performance degrade.
gr. Martin
Steffen Neumann wrote:
> Good news upfront:
> Yours,
> Steffen
> 24354 [main] DEBUG
> java.util.ArrayList
> protocol/extension
> FeatureMap
> Version: 1.1.0-rc-1
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #60357 is a reply to message #60310] Wed, 08 November 2006 11:47 Go to previous messageGo to next message
The CPU load seems to be distributed 30:60 and 50:50 between java/postmaster.
I found this in the log:
1771 [main] WARN JPOX.JDO - Property PMFConfiguration.CACHE_LEVEL_1_TYPE_PROPERTY unknown - will be ignored
Since 1.1.3 they are named differently:
Up to JPOX 1.1.2 org.jpox.cache.WeakRefCache | org.jpox.cache.SoftRefCache | org.jpox.cache.HardRefCache | your class name
From JPOX 1.1.3 weak | soft | hard | {your-plugin-name}
So now I am using
org.jpox.cache.level1.type=weak
This got rid of the repair calls, but runtime is still inacceptable
(still running since 10 mins) I still get for the elements added a large number of (this time)
47933 [main] DEBUG org.eclipse.emf.teneo.mapping.elist.PersistableEList - Created persistable list EList of type: org.eclipse.emf.teneo.jpox.elist.EListWrapper of member comments owned by de.ipb.msbi.Mzdata.impl.SpectrumDescTypeImpl with delegate list java.util.ArrayList
49102 [main] DEBUG org.eclipse.emf.teneo.mapping.elist.PersistableEList - Created persistable list EList of type: org.eclipse.emf.teneo.jpox.elist.EListWrapper of member supDesc owned by de.ipb.msbi.Mzdata.impl.SpectrumType1Impl with delegate list java.util.ArrayList
49103 [main] DEBUG org.eclipse.emf.teneo.mapping.elist.PersistableFeatureMap - Created persistable featuremap FeatureMap of member group owned by de.ipb.msbi.Mzdata.impl.SpectrumType1Impl with delegate list java.util.ArrayList
49103 [main] DEBUG org.eclipse.emf.teneo.jpox.elist.FeatureMapWrapper - Creating feature map wrapper for org.eclipse.emf.teneo.jpox.elist.GenericFeatureMapEntry
49863 [main] DEBUG org.eclipse.emf.teneo.mapping.elist.PersistableFeatureMap - Created persistable featuremap FeatureMap of member group owned by de.ipb.msbi.Mzdata.impl.AcquisitionTypeImpl with delegate list java.util.ArrayList
49863 [main] DEBUG org.eclipse.emf.teneo.jpox.elist.FeatureMapWrapper - Creating feature map wrapper for org.eclipse.emf.teneo.jpox.elist.GenericFeatureMapEntry
49864 [main] DEBUG org.eclipse.emf.teneo.mapping.elist.PersistableEList - Created persistable list EList of type: org.eclipse.emf.teneo.jpox.elist.EListWrapper of member acquisition owned by de.ipb.msbi.Mzdata.impl.AcqSpecificationTypeImpl with delegate list java.util.ArrayList
50250 [main] DEBUG org.eclipse.emf.teneo.mapping.elist.PersistableFeatureMap - Created persistable featuremap FeatureMap of member group owned by de.ipb.msbi.Mzdata.impl.SpectrumInstrumentTypeImpl with delegate list java.util.ArrayList
So I in the mapping strategy between elver and teneo something changed.
Any ideas ?
Yours,
Steffen
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #60380 is a reply to message #60357] Wed, 08 November 2006 14:51 Go to previous messageGo to next message
Hi Steffen,
Were do you write the log (debug) messages to? To a file?
gr. Martin
>> process?
> java/postmaster.
> So now I am using
> 47933 [main] DEBUG
> java.util.ArrayList
> 49102 [main] DEBUG
> java.util.ArrayList
> 49103 [main] DEBUG
> java.util.ArrayList
> 49103 [main] DEBUG
> 49863 [main] DEBUG
> java.util.ArrayList
> 49863 [main] DEBUG
> 49864 [main] DEBUG
> 50250 [main] DEBUG
> java.util.ArrayList
> Any ideas ?
> Yours,
> Steffen
The Netherlands
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #60403 is a reply to message #60380] Thu, 09 November 2006 04:54 Go to previous messageGo to next message
Martin Taal wrote:
> Hi Steffen,
No, it goes to the Eclipse Console. But things remain slow
even if I set the Debuglevel to Info only.
I also tried dropping & recreating the DB
and recreating package.jdo as , to no avail.
More profiling ideas ?
Yours,
Steffen
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #60426 is a reply to message #60403] Thu, 09 November 2006 08:31 Go to previous messageGo to next message
Hi Steffen,
Performance issues are always tricky. It can be db locking, transaction log size, java heap size....
Can you try mysql?
What does the import logic look like? Do you use the JpoxDataStore import method?
Can you package so that I can easily test it myself?
gr. Martin
> Martin Taal wrote:
>> Hi Steffen,
> Yours,
> Steffen
The Netherlands
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #60448 is a reply to message #60426] Thu, 09 November 2006 11:10 Go to previous messageGo to next message
Martin Taal wrote:
> Can you try mysql?
Yup, same result. Still not finished after 15 mins.
> import method?
No, plain PersistenceManager()
docroot = (DocumentRoot) object;
mzdata = docroot.getMzData();
tx.begin();
pm.makePersistent(mzdata);
tx.commit();
Hmpf. That'd expose some bad coding style.
OK, I cleaned up a bit, and send you an URL via PM.
Yours,
Steffen
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #61424 is a reply to message #60426] Wed, 15 November 2006 04:25 Go to previous message
Martin Taal wrote:
> Hi Steffen,
So after some conversation off-list, we're back (and in the archives).
On Di, 2006-11-14 at 18:00 +0100, Martin Taal wrote:
Hi Steffen,
> I found it (I think/hope). The DataType has a member Value which is a
> byte array. As a default Teneo will persist an array in a join table. As
> this makes it possible to query using that information. In case of the
> byte array this resulted in a separate table (DATATYPEIMPL_VALUE) with a
> record for each byte in each instance of DataType.value.
A lot, given around 40+x MB of bytes.
> So solve this:
> You can force the system to persist everything in the DataType table in
> one field by setting the @Lob annotation on the Value EAttribute of
> DataType.
> To test it quickly you can also manually change the package.jdo, you
> need to look for a tag:
> <field name="value" persistence-modifier="persistent">
> <array/>
> <join/>
> <element/>
> </field>
> This needs to be changed to (just delete join and element):
> <array/>
> </field>
> The database needs to be recreated for this change to get effect.
> In addition you can set this (just when importing):
> org.jpox.persistenceByReachabilityAtCommit=false
> and in log4j.properties:
> log4j.category.JPOX=OFF
Done, and it helps. I am down to ~2 Minutes to persist the large 53MB
with both postgres and MySQL.
So the short answer is that by adding annotation to eCore,
I can trade performance for features (here: individually
adressing bytes in a base64 blob).
I still have a no-go with oracle, but this seems to be
a known deficiency of JPOX, related to versions of client/server;
I'll keep you posted...
69128 [main] INFO JPOX.RDBMS - ================ DatabaseAdapter ==================
69129 [main] INFO JPOX.RDBMS - Adapter : org.jpox.store.rdbms.adapter.OracleAdapter
69129 [main] INFO JPOX.RDBMS - Datastore : name="Oracle" version="Oracle9i Release 9.0.1.1.1 - Production
JServer Release 9.0.1.1.1 - Production" (major=9, minor=0, revision=1)
69129 [main] INFO JPOX.RDBMS - Driver : name="Oracle JDBC driver" version="9.2.0.3.0" (major=9, minor=2)
72679 [main] INFO JPOX.RDBMS - Creating table SEQUENCE_TABLE
javax.jdo.JDOFatalInternalException: Somehow org.jpox.store.rdbms.mapping.oracle.OracleBlobRDBMSMapping.s etObject() was called, which should have been impossible!
Thanks for the help,
yours,
Steffen
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #595267 is a reply to message #60282] Wed, 08 November 2006 08:33 Go to previous message
gr. Martin
> Good news upfront:
> Yours,
> Steffen
> 24354 [main] DEBUG
> java.util.ArrayList
> protocol/extension
> FeatureMap
> Version: 1.1.0-rc-1
The Netherlands
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #595292 is a reply to message #60310] Wed, 08 November 2006 11:47 Go to previous message
So now I am using
Any ideas ?
Yours,
Steffen
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #595297 is a reply to message #60357] Wed, 08 November 2006 14:51 Go to previous message
Hi Steffen,
gr. Martin
>> process?
> java/postmaster.
> So now I am using
> 47933 [main] DEBUG
> java.util.ArrayList
> 49102 [main] DEBUG
> java.util.ArrayList
> 49103 [main] DEBUG
> java.util.ArrayList
> 49103 [main] DEBUG
> 49863 [main] DEBUG
> java.util.ArrayList
> 49863 [main] DEBUG
> 49864 [main] DEBUG
> 50250 [main] DEBUG
> java.util.ArrayList
> Any ideas ?
> Yours,
> Steffen
The Netherlands
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #595309 is a reply to message #60380] Thu, 09 November 2006 04:54 Go to previous message
Martin Taal wrote:
> Hi Steffen,
Yours,
Steffen
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #595319 is a reply to message #60403] Thu, 09 November 2006 08:31 Go to previous message
Hi Steffen,
Can you try mysql?
gr. Martin
> Martin Taal wrote:
>> Hi Steffen,
> Yours,
> Steffen
The Netherlands
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #595330 is a reply to message #60426] Thu, 09 November 2006 11:10 Go to previous message
Martin Taal wrote:
> Can you try mysql?
> import method?
tx.begin();
tx.commit();
Yours,
Steffen
Re: Performance Problem with Teneo 200610261350 / Jpox 1.1.3 [message #595661 is a reply to message #60426] Wed, 15 November 2006 04:25 Go to previous message
Martin Taal wrote:
> Hi Steffen,
Hi Steffen,
> So solve this:
> DataType.
> <array/>
> <join/>
> <element/>
> </field>
> <array/>
> </field>
yours,
Steffen
Previous Topic:Client/Server App with EMF and Teneo
Next Topic:How to declare type of empty collection in OCL?
Current Time: Sat Jul 26 09:22:38 EDT 2025
Powered by FUDForum. Page generated in 0.07793 seconds
