Home » Eclipse Projects » Remote Application Platform (RAP) » DateChooser
DateChooser [message #5354] Mon, 12 March 2007 05:35 Go to next message
Originally posted by: roberto.sanchez.autonomind.com
Hello, I need a DateChooser (or Calendar) in my app. There is a
DataChooser in qooxdoo Controls, you can see it in:
http://demo.qooxdoo.org/current/sample/html/example/DateChoo ser_1.html
AFAIK RAP Widget controls are based in qooxdoo Controls (see
http://wiki.eclipse.org/index.php/WidgetToolkit), Is there any way to
use "new" qooxdoo controls in RAP ? How ?
Thanks in advance.
Roberto.
Re: DateChooser [message #5685 is a reply to message #5354] Mon, 12 March 2007 17:48 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
Hi Roberto,
It is possible to integrate existing qooxdoo widgets (and other
JavaScript) into RAP. There is a brief description on how to do that in
principle in our EclipseCon tutorial (p23-p25):
slides: http://eclipsezilla.eclipsecon.org/attachment.cgi?id=468
A few explanations:
You need to implement
- a Java class representing the widget (e.g. Calendar)
- a Java class that maps the widget API to the client side JavaScript
(this is called a LifeCylcleAdapter - LCA), creating the widget and
receiving values from and transmitting values to the client side
- in case you need additional functionality on the client side you also
need to provide a JavaScript file
Maybe you should start by having a look at the GMap component project:
http://eclipsezilla.eclipsecon.org/attachment.cgi?id=515
This integrates an external JS, but gives a simple example of how to
create your custom widget.
Another good example is the Group widget, the GroupLCA and the Group.js
that you find in the RAP org.eclipse.rap.rwt project. If you want to
transmit data from the client-side to the server side (which neither
GMap nor Group do) you need to implement the readData method in the LCA,
see the SpinnerLCA as an example.
It is not easy, but it can be done ;-)
Hope that helps,
Jochen
> Thanks in advance.
> Roberto.
Re: DateChooser [message #5811 is a reply to message #5685] Tue, 13 March 2007 03:24 Go to previous message
Thank you very much Jochen! Very useful info. :-)
I'm going try it ASAP.
I'll send feedback of my progress to the newsgroup.
Cheers.
Roberto
Jochen Krause wrote:
> Hi Roberto,
> A few explanations:
> Hope that helps,
> Jochen
>> Thanks in advance.
>> Roberto.
Previous Topic:RAP Book
Next Topic:RAP in tomcat
Current Time: Mon Jul 14 08:45:31 EDT 2025
Powered by FUDForum. Page generated in 0.03869 seconds
