Home » Eclipse Projects » Eclipse Platform » Different folder for plug-ins
Different folder for plug-ins [message #60279] Tue, 03 June 2003 09:04 Go to next message
Originally posted by: stelian.iancu.gmx.net
Hello!
Is it possible to store some external plugins and features in some other
folder than $ECLIPSE_HOME and then tell Eclipse at startup where to look
for those external plugins and features?
I saw in the help something like the -configuration parameter, but I didn't
understand how can I use it.
Stelian Iancu
Linux Registered User 287835
Be different. Think.
Re: Different folder for plug-ins [message #60480 is a reply to message #60279] Tue, 03 June 2003 09:48 Go to previous message
This comes up every second day :)
make a subdir 'links' into $ECLIPSE_HOME and put a file abc.links
(where abc is what you like. You can also add more than one file...)
in there with the content
path=[r |rw ]/absolute/path/to/another/eclipse/site
'r ' and 'rw ' are optional and will let this site be read/only or
read/writeable. Default is nothing and will default to r/w.
The 'site' will need a subdir eclipse, wherin you can add you
plugins and features folders (like $ECLIPSE_HOME)...
Also, there is a patch (I keep advertising it... :) for adding
'sites' during startup via a commandline parameter 8usefull, when
you don't have writee access to all sites: Unix systems):
http://bugs.eclipse.org/bugs/show_bug.cgi?id=36101
Jan
Previous Topic:VM Exception when starting in debug mode
Next Topic:Launching Eclipse Programmatically
Current Time: Sat Jul 26 09:06:42 EDT 2025
Powered by FUDForum. Page generated in 0.04261 seconds
