Home » Language IDEs » Java Development Tools (JDT) » How to createa a new CVS Project in Eclipse
How to createa a new CVS Project in Eclipse [message #60253] Wed, 18 June 2003 08:07 Go to next message
Everytime I try to share a "new" project with eclipse I receive the error
message:
The server reported an error while performing the "cvs update" command.
"PROJECT": cvs server: cannot open directory
C:/Apps/CVS/ROOT/PROJECT: No such file or directory
"PROJECT": cvs server: cannot find module `PROJECT' - ignored
Has anyone else seen this? Is there a way to create the project in eclipse
without first having to create the project in cvs?
Re: How to createa a new CVS Project in Eclipse [message #61033 is a reply to message #60253] Wed, 18 June 2003 10:56 Go to previous messageGo to next message
Originally posted by: ahumphr.ZAPgmx.net
> message:
> eclipse without first having to create the project in cvs?
Are you perhaps updating rather than commiting?
The sequence to follow is right click on the project, select "team"/"share
project", choose a repository, choose a module name, press finish. Then
perform an "team"/"commit" to actually store the files.
Is that what you did? Or did you create the project in CVS using another
tool? That isn't normally required.
Aidan Mark
http://www.aidan-mark.com
Re: How to createa a new CVS Project in Eclipse [message #61055 is a reply to message #61033] Wed, 18 June 2003 11:30 Go to previous messageGo to next message
The sequence of steps I followed was:
1) Create a new project in eclipse
2) Team/Share Project
3) Choose repository and module
4) Clicked finish and thats when I received the errors listed below.
Is it perhaps some configuration setting with cvs that is preventing me to
do this?
"Aidan Mark" <ahumphr@ZAPgmx.net> wrote in message
news:bcpudh$r9n$1@rogue.oti.com...
error
> > message:
> Aidan Mark
Re: How to createa a new CVS Project in Eclipse [message #63771 is a reply to message #60253] Fri, 20 June 2003 21:14 Go to previous message
Hi Jeremy -
Are you using CVSNT? I had a problem like this when I tried it. The
workaround I found was to create the CVS module directory manually then
share the project again in Eclipse. Eclipse will tell you that the
project already exists and ask if you want to synchronize with the
existing project, answer yes and select HEAD as the branch to
synchronize with. Should be hunky dory from there.
It bears mentioning that CVSNT is not officially supportedby Eclipse
however, and while it seemed to work OK for me in limited testing, you
might be better off using Cygwin if you must use Windows. It's harder to
set up initially, (basically it's a Unix emulation layer for Windows)
but probably worth it if you're doing serious development.
@D
David Gallardo
Co-author, Eclipse in Action
Author, Java Oracle Database Development
> message:
Previous Topic:Package Explorer Directory Structute
Next Topic:[ANN] Eclipse Checkstyle Plug-in v3.1.1 released
Current Time: Sun Jul 27 08:47:56 EDT 2025
Powered by FUDForum. Page generated in 0.03756 seconds
