Selection problem [message #60212] |
Thu, 30 January 2003 14:03  |
------=_NextPart_000_000C_01C2C8AB.5CE9E370
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_000D_01C2C8AB.5CE9E370"
------=_NextPart_001_000D_01C2C8AB.5CE9E370
Content-Type: text/plain;
charset="koi8-r"
I've encountered a problem with editpart selection, briefly it's =
impossible to select small editpart (red point on the screenshot below) =
by one click if it has several connections attached - I always select =
one from connections. I tried to play with layers order, but it doesn't =
help - connection layer has to be upper one, otherwise connections are =
invisible.=20
--=20
WBR Kir
Content-Type: text/html;
charset="koi8-r"
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dkoi8-r">
<META content=3D"MSHTML 5.50.4134.600" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3D"Arial Cyr" size=3D2></FONT><FONT face=3D"Arial Cyr" =
size=3D2>I've=20
encountered a problem with editpart selection, briefly it's impossible =
to select=20
small editpart (red point on the screenshot below) by one click if it =
has=20
several connections attached - I always select one from connections. I =
tried to=20
play with layers order, but it doesn't help - connection layer has to be =
upper=20
one, otherwise connections are invisible. </FONT></DIV>
<DIV><FONT face=3D"Arial CYR" size=3D2></FONT> </DIV>
<DIV><IMG alt=3D"" hspace=3D0 =
src=3D"cid:000701c2c892$3797f080$2a6d5050@desktop"=20
align=3Dbaseline border=3D0></DIV>
<DIV><BR><FONT face=3D"Arial Cyr" size=3D2>-- <BR>WBR =
Kir</FONT></DIV></BODY></HTML>
------=_NextPart_001_000D_01C2C8AB.5CE9E370--
Content-Type: image/bmp;
name="tt16.bmp"
Content-ID: <000701c2c892$3797f080$2a6d5050@desktop>
Qk32oQAAAAAAAHYAAAAoAAAADwEAADABAAABAAQAAAAAAIChAAB0EgAAdBIA AAAAAAAAAAAAAAAA
AAAAgAAAgAAAAICAAIAAAACAAIAAgIAAAICAgADAwMAAAAD/AAD/AAAA//8A /wAAAP8A/wD//wAA
////AP////////////////////////////////////////////////////// ////////////////
//////////////////////////////////D///////////////////////// ////////////////
////////////AP////////////////////////////////////////////// ////////////////
/////////////////////////////wD///////////////////////////// ///w////////////
/////////////////////////////////////////wD///////////////// ////////////////
//////////////////////////////////////////////////////////8A ////////////////
////////////////8P////////////////////////////////////////// //////////8A////
////////////AP////////////////////////////////D///////////// ////////////////
////////////////////////AP////////////////////////////////// ////////////////
/////////////////////////////////////////wD///////////////// ///////////////w
/////////////////////////////////////////////////////wD///// ////////////////
//////////////////////////////////////////////////////////// //////////8A////
////////////////////////////8P////////////////////////////// ////////////////
//////8A//////////////////////////////////////////////////// ////////////////
////////////////////////AP////////////////////////////////D/ ////////////////
////////////////////////////////////AP////////////////////// ////////////////
///////////w//////////////////////////////////////////////// /////wD/////////
//////8A////////////////////////////////8P////////////////// ////////////////
//////////////////8A//////////////////////////////////////// ////////////////
////////////////////////////////////AP////////////////////// //////////D/////
////////////////////////////////////////////////AP////////// ////////////////
//////////////////////////////////////////////////////////// /////wD/////////
///////////////////////w//////////////////////////////////// ////////////////
/wD///////////////////////////////////////////////////////// ////////////////
//////////////////8A////////////////////////////////8P////// ////////////////
//////////////////////////////8A//////////////////////////// ////////////////
//////D///////////////////////////////////////////////////// AP//////////////
/wD////////////////////////////////w//////////////////////// ////////////////
/////////////wD///////////////////////////////////////////// ////////////////
//////////////////////////////8A//////////////////////////// ////8P//////////
//////////////////////////////////////////8A//////////////// ////////////////
//////////////////////////////////////////////////////////// AP//////////////
//////////////////D///////////////////////////////////////// ////////////AP//
/////////////wD////////////////////////////////w//////////// ////////////////
/////////////////////////wD///////////////////////////////// ////AAAP////////
8P////////////////////////////////////////////////////8A//// ////////////////
/////////////////wAAAP////////////////////////////////////// ////////////AP//
//////////////////////////////D///////////////////////////// ////////////////
////////AP////////////////////////////////////AP//AP//////// ////////////////
/////////////////////////wD////////////////////////////////w ////////////////
/////////////////////////////////////wAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
D//wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA//// ////////////////
////////////8P////////////////////////////////////////////// //////8AAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAA//8AAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAP////////////////////////////////D///////////////// ////////////////
//////////////////////////////////////////////////////////AP //AP////////////
//////////////////////////////////////////////////////////// ///////////w////
////////////AAAA//////////////////////////////////////////// ////////////////
////////////////////////8P////////////////////////////////// ////////////////
/////////////////////////////////////////wAAD/////////////// ////////////////
//////////////////////////////////////////////////////D///// ////////////////
//////////////////////////////////////////////////////////// ///////////wD///
///////w//////////////////////////////////////////////////// ////////////////
////////////////////////8AD///////////////////////////////// ////////////////
////////////////////////////////////8P////////////////////// ////////////////
//////////////////////////////////////////////////////AA//// ////////////////
//////////////////////////////////////////////////////////// //////D/////////
//////8AAA////////////////////////////////////////////////// ////////////////
///////////////////w//////////////////////////////////////// ////////////////
////////////////////////////////////AAAP//////////////////// ////////////////
////////////////////////////////////////////////8P////////// ////////////////
//////////////////////////////////////////////////////////// ////8AAPAP//////
//D///////////////////////////////////////////////////////// ////////////////
//////////////////AADwD///////////////////////////////////// ////////////////
///////////////////////////////w//////////////////////////// ////////////////
//////////////////////////////////////////////8A8A8A//////// ////////////////
//////////////////////////////////////////////////////////// 8P//////////////
//AP//////////////////////////////////////////////////////// ////////////////
//////////////D///////////////////////////////////////////// ////////////////
///////////////////////////////wD/////////////////////////// ////////////////
///////////////////////////////////////////w//////////////// ////////////////
//////////////////////////////////////////////////////////// 8A//////////////
//////////////////////////////////////////////////////////// ////////////8P//
//////////////AP//////////////////////////////////////////// ////////////////
//////////////////////////D///////////////////////////////// ////////////////
///////////////////////////////////////////wD/////////////// ////////////////
///////////////////////////////////////////////////////w//// ////////////////
//////////////////////////////////////////////////////////// ////////////8A//
////////8P////////////////////////////////////////////////// ////////////////
//////////////////////////AP//////////////////////////////// ////////////////
//////////////////////////////////////D///////////////////// ////////////////
///////////////////////////////////////////////////////wD/// ////////////////
//////////////////////////////////////////////////////////// ///////w////////
////////8A////////////////////////////////////////////////// ////////////////
////////////////////8P////////////////////////////////////// ////////////////
//////////////////////////////////////AP//////////////////// ////////////////
//////////////////////////////////////////////////D///////// ////////////////
//////////////////////////////////////////////////////////// ///////wD///////
///w//////////////////////////////////////////////////////// ////////////////
////////////////////8A////////////////////////////////////// ////////////////
////////////////////////////////8P////////////////////////// ////////////////
//////////////////////////////////////////////////AP//////// ////////////////
//////////////////////////////////////////////////////////// //D/////////////
///wD/////////////////////////////////////////////////////// ////////////////
///////////////w//////////////////////////////////////////// ////////////////
////////////////////////////////8A////////////////////////// ////////////////
////////////////////////////////////////////8P////////////// ////////////////
//////////////////////////////////////////////////////////// //AP////////////
//////////////////////////////////////////////////////////// //////////////D/
///////////////wD/////////////////////////////////////////// ////////////////
///////////////////////////w//////////////////////////////// ////////////////
////////////////////////////////////////////8A////////////// ////////////////
////////////////////////////////////////////////////////8P// ////////////////
//////////////////////////////////////////////////////////// //////////////AP
//////////D///////////////////////////////////////////////// ////////////////
///////////////////////////wD/////////////////////////////// ////////////////
///////////////////////////////////////w//////////////////// ////////////////
////////////////////////////////////////////////////////8A// ////////////////
//////////////////////////////////////////////////////////// ////////8P//////
//////////AP//////////////////////////////////////////////// ////////////////
//////////////////////D///////////////////////////////////// ////////////////
///////////////////////////////////////wD/////////////////// ////////////////
///////////////////////////////////////////////////w//////// ////////////////
//////////////////////////////////////////////////////////// ////////8A//////
////8P////////////////////////////////////////////////////// ////////////////
//////////////////////AP//////////////////////////////////// ////////////////
///////////////////////////////////////////////////wD/////// ////////////////
//////////////////////////////////////////////////////////// ///w////////////
////8A////////////////////////////////////////////////////// ////////////////
////////////////8P////////////////////////////////////////// ////////////////
//////////////////////////////////AP//////////////////////// ////////////////
//////////////////////////////////////////////D///////////// ////////////////
//////////////////////////////////////////////////////////// ///wD///////////
//////////////////////////////////////////////////////////// ///////////////w
////////////////8A////////////////////////////////////////// ////////////////
//////////////////////////////////////////////AP//////////// ////////////////
//////////////////////////////////////////////////////////D/ ////////////////
D/////////////////////////////////////////////////////////// ////////////////
///////////w//////////////////////////////////////////////// ////////////////
////////////////////////////8A////////////////////////////// ////////////////
////////////////////////////////////////8P////////////////// ////////////////
//////////////////////////////////////////////////////////AP ////////////////
//////////////////////////////////////////////////////////// //////////D/////
///////////wD/////////////////////////////////////////////// ////////////////
////////////////////////////////////////8A////////////////// ////////////////
////////////////////////////////////////////////////8P////// ////////////////
//////////////////////////////////////////////////////////// //////////AP////
//////D///////////////////////////////////////////////////// ////////////////
///////////////////////wD/////////////////////////////////// ////////////////
///////////////////////////////////w//////////////////////// ////////////////
////////////////////////////////////////////////////8A////// ////////////////
//////////////////////////////////////////////////////////// ////8P//////////
//////AP//////////////////////////////////////////////////// ////////////////
//////////////////D///////////////////////////////////////// ////////////////
///////////////////////////////////wD/////////////////////// ////////////////
///////////////////////////////////////////////w//////////// ////////////////
//////////////////////////////////////////////////////////// ////8A//////////
8P////////////////////////////////////////////////////////// ////////////////
//////////////////AP//////////////////////////////////////// ////////////////
///////////////////////////////////////////////wD/////////// ////////////////
///////////////////////////////////////////////////////////w ////////////////
8A////////////////////////////////////////////////////////// ////////////////
////////////8P////////////////////////////////////////////// ////////////////
//////////////////////////////AP//////////////////////////// ////////////////
//////////////////////////////////////////D///////////////// ////////////////
///////////////////////////////////////////////////////////w D///////////////
////////////8A////////////////////////////////////////////// ////////////////
//////////////////////////////////////////AP//////////////// ////////////////
////////////////////////8A////////////////////////////////// ////////////////
//////////////////////////////////////////////////////AP//// ////////////////
///////wD/////////////////////////////////////////////////// ////////////////
////////////////////////////////////8A////////////////////// ////////////////
//////////////////////////////////////////////////////////// //////AP////////
///////////////////wD/////////////////////////////////////// ////////////////
////////////////////////////////////////////////8A////////// ////////////////
///wD/////////////////////////////////////////////////////// //////////8AAAAA
AAAAAAAAAAAAAA/w//////////////////////////////////////////// ////////////////
////////////////////////AAAAAAAAAAAAAAAAAAAP8P////////////// ////////////////
/////////////////////////////////////////////////////wD///// //////////////D/
//////8A///////////////////w//////////////////////////////// ////////////////
////////////////////////////////////AP//////////////////8P// ////////////////
//////////////////8A///////////////////w//////////////////// ////////////////
////////////////////////////////////////////////AP////////// ////////8P//////
/wD///////////////////D///////////////////////////////////// ////////////////
//////////////////////////////8A///////////////////w//////// ////////////////
/////////////wD///////////////////D///////////////////////// ////////////////
//////////////////////////////////////////8A//////////////// ///w////////////
////8A////////////////////////////////////////////////////// ////////////AP//
/////////////////////////wD///////////////////D///////////// ////////////////
//////////////////////////////////////////////////////8A//// ///////////////w
////////AP//////////////////8P////////////////////////////// ////////////////
////////////////////////////////////AAAP//////////////////D/ ////////////////
D/////////////////////////////////////////////////////////// /////wAAAP//////
//////////////////AP//AP////////////////8AAAAAAAAAAAAAAA//// ////////////////
//////////////////////////////////////////AAAAAAD//wD/////// //////////AAAAAA
AAAAAAAAAP////////////////////////////////////////////////// ////////////////
///////////wD/////////////////////////////////////////////// ///////////wAAAA
AA//8A/////////////////w/////////////wD///////////////////// ////////////////
///////////////////////wAAAAAAAP//AP////////////////8P////// //////8A////////
/////////////////////////////////////////////////wAAAAAAAA// AAAA////////////
//////D/////////////AP////////////////////////////////////// ////////////////
AAAAAAD/AAD//wAAD//////////////////w/////////////wD///////// ////////////////
//////////////////////////AAAAAAD////wD/////AP////////////// ////8P//////////
//8A//////////////////////////////////////////////////////// ////////////////
//////AP////////////////////////////////////////////AAAAAAAP /////////////wD/
//////////////////D/////////////AP////////////////////////// ////////////////
//8AAAAAAP////////////////8A///////////////////w//////////// /wD/////////////
////////////////////////////8AAAAAAP////////////////////AP// ////////////////
8P////////////8A//////////////////////////////////////////// ////////////////
//////////////////AP///////////////////////////////////wAAAA AA//////////////
/////////wD///////////////////D/////////////AP////////////// ////////////////
/////////////////////////////////////////////wDwDwD///////// ////////////////
/////wAAAAAA//////////////////////////8A///////////////////w /////////////wD/
AA8A///////////////////////////wAAAAAAD///////////////////// ////////AP//////
////////////8P////////////8A//////////////////////////////// ////////////////
////////////////////////////8AAPAP////////////////////////AA AAAAD///////////
/////////////////////wD///////////////////D/////////////AP// ////////////////
//////////////////////////////////////////////////////////8A AA//////////////
////////AAAAAAD///////////////////////////////////8A//////// ///////////w////
/////////wD///////////////////////////////////////////////// ////////////////
////////////AAAP//////////////////8AAAAAAP////////////////// ////////////////
////AP//////////////////8P////////////8A//////////////////// ////////////////
//////////////////////////////////////////AA//////////////// 8AAAAAAP////////
/////////////////////////////////wD///////////////////D///// ////////AP//////
//////////////////////////////////////////////////////////// ///////////wAP//
//////////8AAAAAAA////////////////////////////////////////// //8A////////////
///////w/////////////wD///////////////////////////////////// ////////////////
////////////////////////kAmf//8AD////wAAAAAA//////////////// ////////////////
////////////////AP//////////////////8P////////////8A//////// ////////////////
/////////////////////////////////////////////////////5mZmf/w AA/wAAAAAA//////
/////////////////////////////////////////////wD///////////// //////D/////////
8AAP//mZmZmQAAAAAAAAD/////////////////////////////////////// //////////////8A
///////////////////w/////////////wD///////////////////////// ////////////////
//////////////////////////////AAAAAJmZmZAAAAAAD///////////// ////////////////
////////////////////////////AP//////////////////8P////////// //8A////////////
//////////////////////////////////////////////////////////// AAAACZmZmQAAAAD/
/////////////////////////////////////////////////////////wD/ ////////////////
//D/////////////AP////////////////////////////////////////// ////////////////
//////////AAAAAAAAmZmZkAAAAA//////////////////////////////// ////////////////
//////////8A///////////////////w/////////////wD///////////// ////////////////
///////////////////////////////////wAAAAAAAAAA//mZmZ//////// ////////////////
////////////////////////////////////////AP////////////////// 8P////////////8A
//////////////////////////////////////////////////////////// /wAAAAAAAP//AAD/
/5mZn/////////////////////////////////////////////////////// /////////wD/////
//////////////D/////////////AP////////////////////////////// ////////////////
//////////8AAAAAAAD//////wD///////////////////////////////// ////////////////
//////////////////////8A///////////////////w/////////////wD/ ////////////////
////////////////////////////////////AAAAAAAAD/////////////// ////////////////
////////////////////////////////////////////////////AP////// ////////////8P//
//////////8A//////////////////////////////////////////////// //AAAAAAAA//////
/////wD///////////////////D/////////////AP////////////////// ////////////////
///////////wAAAAAAAP//////////////////////////////////////// ////////////////
//////////////////////////////////8A///////////////////w//// /////////wD/////
/////////////////////////////////////wAAAAAAAP////////////// ////////////////
//////////////////////////////////////////////////////////// ////AP//////////
////////8P////////////8A//////////////////////////////////// //8AAAAAAAD/////
/////////////////wD///////////////////D/////////////AP////// ////////////////
////////////AAAAAAAAD/////////////////////////////////////// ////////////////
//////////////////////////////////////////////8A//////////// ///////w////////
/////wD///////////////////////////////AAAAAAAA////////////// ////////////////
AP//////////////////8P////////////8A//////////////////////// ///wAAAAAAAP////
/////////////////////////////wD///////////////////D///////// ////AP//////////
/////////////wAAAAAAAP////////////////////////////////////// ////////////////
///w/////////////wD///////////////////8AAAAAAAD///////////// ////////////////
////////////AP//////////////////8P////////////8A//////////// ////AAAAAAAAD///
/////////////////////////////////////////wD///////////////// //D///////////8A
AA///wAP//////AAAAAAAA////////////////////////////////////// ////////////////
///////////////w////////////AAAA//AAD//wAAAAAAAP//////////// ////////////////
////////////////////////AP//////////////////8P//////////8A// 8AAADwAAAAAAAP//
//////////AP//AAAAAAAAD///////////////////////////////////// ////////////////
//////8A///////////////////w///////////wD//wAAAAD/////////// ////////////////
////////////////////////////////////AP//////////////////8P// ////////8A//8AAA
AAD///////////////////////////////////////////////////////// ////////////////
//////////D///////////8AAAD/8AAA//////////////////////////// ////////////////
//////////////////8A///////////////////w////////////AAAP//// ////////////////
/wD///////////////////D/////////////AP////////////////////// ////////////////
//////////////////////////////8A///////////////////w//////// /////wD/////////
////8P////////////8A//////////////////////////////////////// ////////////////
/////////////wD///////////////////D/////////////AP////////// ////////////////
//////////////////////////////////////////////////////////// ////////////AP//
////////////////8P////////////8A//////////////////////////// ////////////////
/////////////////////////wD///////////////////D///////////// AP//////////////
////////AP//////////////////8P////////////8A//////////////// ////////////////
/////////////////////////////////////wD///////////////////D/ ////////////AP//
//////////////////////////////////////////////////////////// //////8A////////
///////////w/////////////wD///////////////////////////////// ////////////////
////////////////////AP//////////////////8P////////////8A//// ////////////////
/////////////////////////////////////////////////wD///////// //////////D/////
////////AP////////////////////////////////////////////////// ////////////////
//8A///////////////////w/////////////wD///////////////////// ////////////////
////////////////////////////////AP//////////////////8P////// //////8A////////
//////////////////////////////////////////////////////////// /wAAAAAAAAAAAAAA
AAAAD/D/////////////AP////////////////////////////////////// ////////////////
//////////////8AAAAAAAAAAAAAAAAAAA/w/////////////wD///////// ////////////////
///////////////////////////////////////////////w//////////// /wD/////////////
//////////////////////////////D/////////////AP////////////// ////////////////
///////////////////////////////////////////////////////////w /////////////wD/
//////////////////////////////////////////D/////////////AP// ////////////////
////////////////////////8P////////////8A//////////////////// ////////////////
//////////////////////////////////////////////////////D///// ////////AP//////
////////////////////////////////////8P////////////8A//////// ////////////////
////////////////////////////////////////////////8P////////// //8A////////////
///////////////////////////////wAAAAAAAAAAAAAAD///////////// ////////////////
//////////////////////////////////////////////////////////// 8AAAAAAAAAAAAAAA
//////////////////////////////A=
FUDForum. Page generated in 0.06752 seconds
