get min or max occurs [message #60210] |
Thu, 28 April 2005 11:21  |
Originally posted by: aaudevart.genigraph.fr
I am trying to extract the min and max occurs but I don't know what
interface i need use to get the max and min occurence.
<xs:element name="child_name" type="xs:string" minOccurs="0"
maxOccurs="5"/>
Can somebody help me please?
Thanks.
Re: get min or max occurs [message #60393 is a reply to message #60348] |
Mon, 02 May 2005 07:30  |
Hi Alex,
starting with the element "toto" you get your desired information as
follows:
XSDComplexTypeDefinition ct =
(XSDComplexTypeDefinition)element.getTypeDefinition();
Now ct should be the complex type "Items". To get the particle you have to
examine the content of the type. So you have to retrieve the complex
content:
XSDComplexTypeContent content = ct.getContentType();
if (content instanceof XSDSimpleTypeDefinition) {
// The content is a simple type. So the complexType describes a
// text node with possiblly additional attributes
} else if (content instanceof XSDParticle) {
// The particle of the xs:sequence.
processParticle((XSDParticle)content);
Now you should have the particle of the first xs:sequence. In
processParticle you now further iterate over the hierarchy in the schema:
public void processParticle(XSDParticle particle) {
int minOccurs = particle.getMinOccurs();
int maxOccurs = particle.getMaxOccurs();
XSDParticleContent content = particle.getContent();
if (content instanceof XSDElementDeclaration) {
// The particle contains an element, i.e. your "item"-element or
// "productName"-element
processElement((XSDElementDeclaration)content);
} else if (content instanceof XSDModelGroup) {
// The particle contains a model group, i.e. a choice,
// a sequence, ...
processModelGroup((XSDModelGroup)content);
} else if (...) {
The first time you call processParticle you will pass a XSDModelGroup (the
xs:sequence). There you have to iterate over all the particles contained in
the sequence:
public void processModelGroup(XSDModelGroup group) {
EList particleList = group.getContents();
for (Iterator i = particleList.iterator(); i.hasNext();) {
XSDParticle particle = (XSDParticle)i.next();
processParticle(particle);
The first particle processed by processModelGroup will be your
"item"-element. So if you call processParticle again you will now have the
particle containing the "item"-element.
Some advice on how to use the XSD JavaDoc and understanding the different
interfaces of XSD:
1) As it is in the schema file: an element is an element, a complex
type is a complex type, ... And there is no way of converting between
them. Instead you have to read the correct properties of the objects.
2) At the top of each XSD interface description you will find "All Known
Subinterfaces". For example you will see that an XSDParticleContent may
be an element declaration or model group.
3) The names of interfaces and functions are closeley related to the
terminology used in the original W3C specification of XML Schema. Often
the XSD JavaDoc links to the corresponding section in the W3C
specification. So if it isn't obvious what the XSD JavaDoc tries to
tell: Have a look at the W3C spec. You find the English version at
http://www.w3.org/TR/xmlschema-1/ and a French version at
http://xmlfr.org/w3c/TR/xmlschema-1/.
Cheers
Klaas
Re: get min or max occurs [message #595214 is a reply to message #60210] |
Thu, 28 April 2005 11:31  |
Alex,
A local element declaration or element reference gives rise to both an
XSDParticle and an XSDElementDeclaration and you should look for the min
and max on the particle.
Alex wrote:
> maxOccurs="5"/>
> Thanks.
Re: get min or max occurs [message #595225 is a reply to message #60234] |
Thu, 28 April 2005 11:59  |
I find a method which return a XSDParticle :
XSDSimpleTypeDefinition aSimpleType
XSDParticle particle = aSimpleType.getComplexType();
but the particule is always null.
May be it isn't the right method.
Here is my xsd code:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified">
<xs:element name="persons">
<xs:complexType>
<xs:sequence>
<xs:element name="person" maxOccurs="unbounded">
<xs:complexType>
<xs:sequence>
<xs:element name="full_name" type="xs:string"/>
minOccurs="0" maxOccurs="5"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
Thanks.
Re: get min or max occurs [message #595235 is a reply to message #60258] |
Thu, 28 April 2005 12:33  |
Alex,
This method applied to a simple type definition will return null; a
simple type does not have complex content. When applied to a complex
type, it will return the particle, as long as the type doesn't have
empty content or simple content, in which cases there is no particle.
> <xs:complexType>
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> Thanks.
Re: get min or max occurs [message #595249 is a reply to message #60280] |
Fri, 29 April 2005 03:29  |
In my case, I've got a simple type so how can i extract the min and max
occurs?
I understand that this : <xs:element name="full_name" type="xs:string"/>
is a simple type and this is a complex type : <xs:element name="full_name"
type="bobi"/>.
Is it exact?
Re: get min or max occurs [message #595259 is a reply to message #60304] |
Fri, 29 April 2005 07:13  |
Alex,
A simple type doesn't have min and max occurs. Both things you show
are element declarations. So I'm quite confused...
In your earlier example you had an element called "persons" with an
anonymous complex type, so given the element declaration for "persons"
you could do xsdElementDeclaration.getType().getComplexType() to get the
root particular of the element's type; you'll get null unless it is a
complex type with complex content. Walking this particle tree will get
you to the "person" element nested in that type.
Alex wrote:
> max occurs?
> type="xs:string"/> is a simple type and this is a complex type :
> <xs:element name="full_name" type="bobi"/>.
> Is it exact?
> Thanks
Re: get min or max occurs [message #595270 is a reply to message #60327] |
Mon, 02 May 2005 04:55  |
Two possibilities, may be i don't understand what you explain to me or it
isn't working!
So if i want to extract the cardinality of "item" which are 0 and 5.
<xs:element name="toto" type="Items"/>
<xs:complexType name="Items">
<xs:sequence>
<xs:element name="item" minOccurs="0" maxOccurs="5">
<xs:complexType>
<xs:sequence>
<xs:element name="productName" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:schema>
I do that :
aComplexType is a XSDComplexTypeDefinition
So :
XSDParticle particle = aComplexType.getComplexType();
int min = particle.getMinOccurs()
int max = particle.getMaxOccurs()
But the problem is that min and max are always equals to 1 and 1.
Thanks for your help
Re: get min or max occurs [message #595283 is a reply to message #60348] |
Mon, 02 May 2005 06:29  |
Alex,
You'll find the the top level particle of a complex type has a term that
is a sequence and that this sequence contains the particles you are
interested in. I.e., stop and think about how it would work if you have
two elements rather than just one in your complex type.
Alex wrote:
> it isn't working!
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> I do that :
> So :
Re: get min or max occurs [message #595293 is a reply to message #60348] |
Hi Alex,
follows:
content:
// a sequence, ...
} else if (...) {
the sequence:
interfaces of XSD:
Cheers
Klaas
FUDForum. Page generated in 0.09732 seconds
