Home » Language IDEs » C / C++ IDE (CDT) » about C/C++ rebuild
about C/C++ rebuild [message #60201] Wed, 29 January 2003 11:35 Go to next message
anyone knows what the following message means?
Build Error
(CreateProcess: make -f makefile error=2)
actually, I just follow the eclipse website, try to set up environment
for c/c++ program on windows platform
I use a makefile, which is same as the that in CDT page,
but I got this message, I am not clear what the problem is.
The following is the contents of makefile:
objects = hello.o
hello : $(objects)
c:\mingw\bin\gcc -o hello $(objects) -L
C:\MinGW\lib\gcc-lib\mingw32\3.2\ -lstdc++
$(objects) : hello.cpp
c:\mingw\bin\gcc -c hello.cpp
all :
${MAKE} hello
..PHONY : clean
clean :
-del hello.exe $(objects)
Thanks!
Q
Re: about C/C++ rebuild [message #60248 is a reply to message #60201] Thu, 30 January 2003 10:57 Go to previous messageGo to next message
Originally posted by: ash371952.hotmail.com
Are you sure that make is in path?
It seems to be a message from spawner. Code 2 means ERROR_FILE_NOT_FOUND.
Actually it means two things:
1) You don't have spawner (this message you saw is a result of failing of
Runtime.exec() function. So you installed CDT incorrectly.
2) You don't have make in path
Alex Chapiro
"Qhmd" <hmdeng6@yahoo.com> wrote in message
news:3E3802B7.746B2308@yahoo.com...
> Build Error
> objects = hello.o
> hello : $(objects)
> all :
> ${MAKE} hello
> .PHONY : clean
> clean :
> Thanks!
> Q
Re: about C/C++ rebuild [message #60319 is a reply to message #60248] Thu, 30 January 2003 17:48 Go to previous messageGo to next message
I tried, c:\mingw\bin\mingw32-make, but it only works on command line.
it does not work in eclipse.
Mary
> Alex Chapiro
> > Hi,
> > Build Error
> > objects = hello.o
> > hello : $(objects)
> > all :
> > ${MAKE} hello
> > .PHONY : clean
> > clean :
> > Thanks!
> > Q
Re: about C/C++ rebuild [message #60391 is a reply to message #60319] Fri, 31 January 2003 09:01 Go to previous messageGo to next message
That's simple. Just go to project properties, C/C++ Project, then cpecify
your own build command.
news:3E39ABBE.4FA466D0@yahoo.com...
> Mary
of
> > Alex Chapiro
> > > Hi,
> > > Build Error
> > > objects = hello.o
> > > hello : $(objects)
> > > all :
> > > ${MAKE} hello
> > > .PHONY : clean
> > > clean :
> > > Thanks!
> > > Q
Re: about C/C++ rebuild [message #60998 is a reply to message #60391] Mon, 03 February 2003 19:38 Go to previous message
This will affect only one project. A less known fact:
- edit the org.eclipse.cdt.core/plugin.xml
- search for the extension-point "CBuildCommand"
- change the default command to what you have instead of
the default "make"
This should probably be in a preference page, but the
state of the default CDT builder is still fuzzy.
> > Hi,
> > Mary
> of
> > > Alex Chapiro
> > > > Hi,
> > > > Build Error
> > > > objects = hello.o
> > > > hello : $(objects)
> > > > all :
> > > > ${MAKE} hello
> > > > .PHONY : clean
> > > > clean :
> > > > Thanks!
> > > > Q
Previous Topic:Address breakpoints and watchpoints
Next Topic:Disabling thread info on each step
Current Time: Sun Jul 13 14:21:55 EDT 2025
Powered by FUDForum. Page generated in 0.08088 seconds
