Home » Archived » Test and Performance Tools Platform (TPTP) » Heap memory in use
Heap memory in use [message #60188] Mon, 27 March 2006 04:39 Go to next message
Originally posted by: kamleshu.hotmail.com
Hi there,
Is there any way in TPTP which can help me to know what is the total
amount of memory being used by my application ?
thanks in advance.
Kamlesh
Re: Heap memory in use [message #60486 is a reply to message #60188] Mon, 27 March 2006 15:05 Go to previous message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 006E57278525713E_=
Content-Type: text/plain; charset="US-ASCII"
Here's what I posted in an earlier message:
In your profile launch configuration, select the profiling tab -> Select
the memory analysis -> Edit -> Next -> select basic memory analysis ->
click on advanced -> Check 'collect instance level information' -> next ->
set your filter set -> finish -> profile.
You can click on the 'collect object references' button in the profiling
monitor to capture a snapshot of your heap at any time during profiling.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Here's what I posted in an earlier message:</font>
<br>
<br><font size=2 face="sans-serif"><br>
In your profile launch configuration, select the profiling tab -&gt; Select
the memory analysis -&gt; Edit -&gt; Next -&gt; select basic memory analysis
-&gt; click on advanced -&gt; Check 'collect instance level information'
-&gt; next -&gt; set your filter set -&gt; finish -&gt; profile.</font><font size=3>
<br>
</font>
<br><font size=2 face="sans-serif">You can click on the 'collect object
references' button in the profiling monitor to capture a snapshot of your
heap at any time during profiling. &nbsp;</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 006E57278525713E_=--
Previous Topic:runnint tests from ant script
Next Topic:Heap Usage Graph
Current Time: Fri Jul 25 21:12:07 EDT 2025
Powered by FUDForum. Page generated in 0.05647 seconds
