Home » Modeling » TMF (Xtext) » Check Editor is not aware of metamodel
Check Editor is not aware of metamodel [message #60138] Fri, 17 July 2009 12:56 Go to next message
Hi there,
I try to edit a Check language file with the nice editor that provides
syntax highlighting, etc.
Although I import a metamodel simply by the line
import modelname;
in the Check-file, the editor does not seem to be aware of my metamodel.
It does not provide any content-assist and auto-completion.
Is there anything I have to do manually to register the metamodel such
that the Check editor gets aare of it?
Hauke
Re: Check Editor is not aware of metamodel [message #60209 is a reply to message #60138] Fri, 17 July 2009 14:07 Go to previous messageGo to next message
Hi Hauke,
I've tried to use the editor and it works fine. Usually there is no need
for any customization.
Did you generate your language?
Does your runtime dsl project contain the metamodel file or does it
reside in a dependent plugin?
Did you enable the Xtend/Xpand Nature for your project?
Did you activate the EMF Metamodel for your project in the preferences?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 17.07.2009 18:56 Uhr, schrieb Hauke Fuhrmann:
> Hi there,
> import modelname;
> Hauke
Re: Check Editor is not aware of metamodel [message #60300 is a reply to message #60209] Fri, 17 July 2009 15:05 Go to previous message
Hi Sebastian,
I have the ecore/genmodel file together with the chk file in the same
project. The model code generated is in another project. The Xtext stuff
is also in another project.
When opening the Check file Eclipse asked me if I wanted to add the
XTend nature and I agreed. In the project properties "EMF MEtamodel" is
enabled.
Hauke
Sebastian Zarnekow schrieb:
> Hi Hauke,
> Sebastian
Previous Topic:[Announce] TMF XTEXT 0.7.1 is available
Next Topic:Unsatisfied dependency on interim update site
Current Time: Sat Jul 26 09:17:12 EDT 2025
Powered by FUDForum. Page generated in 0.04824 seconds
