Home » Language IDEs » ServerTools (WTP) » Navigation in JSP with M2
Navigation in JSP with M2 [message #60109] Tue, 04 January 2005 12:10 Go to next message
Originally posted by: chabert.fimasys.fr
first, I'd like to wish you all an happy new year 2005, and especially
to the WTP team who did a fantastic job !
My question is about navigation in jsp files:
on java scriplets, navigation is working well with java class (by using
F3 for example to open declaration), and with the check 'Support
hyperlink style navigation for "Open Declaration"' checked !
But, the navigation seems to be unable to handle navigation toward
explicit files, such as other jsp pages.
For example, I have the following tag:
<jsp:include page="my_page.jsp" flush="true"/>
and when I try to navigate on "my_page.jsp", I got the message
"Current text selection does not resolve to a file".
But my file exists and the path is correct.
Is it a bug, a feature request or have I a problem with my environnement ?
I'm working under linux Debian, with Eclipse 3.1M4, WTP1.0M2.
I tried with jsp files inside an Eclipse Web Project.
Thx
Sylvain
Re: Navigation in JSP with M2 [message #60355 is a reply to message #60109] Tue, 04 January 2005 14:13 Go to previous messageGo to next message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
Your scenario should work (it works for me). I tried on a windows XP, and
linux suse, and both worked. Do you have any problems with plain html
tags as well? for example, try <a href="my_page.jsp" /> does that work?
Sylvain Chabert wrote:
> Hello,
> Thx
> Sylvain
Re: Navigation in JSP with M2 [message #60845 is a reply to message #60109] Tue, 04 January 2005 16:21 Go to previous messageGo to next message
Hi Sylvian,
the same is for me (WinXP, 3.0.1 or 3.1 M4, WTP 1.0M2) - sometimes it
works, sometimes don't (I can't understand why).
Anyway, try the AnyEdit plugin - there is a similar functionality for
*any* editor, and it works.
http://andrei.gmxhome.de/anyedit/index.html
Kind regards,
Andrei Loskutov
Am Tue, 04 Jan 2005 18:10:13 +0100 hat Sylvain Chabert
<chabert@fimasys.fr> geschrieben:
> Hello,
> Thx
> Sylvain
Re: Navigation in JSP with M2 [message #61011 is a reply to message #60845] Wed, 05 January 2005 05:39 Go to previous messageGo to next message
thx both for your answers.
I made a test case with a Web project, and the navigation is indeed
working fine on jsp include (my previous test case was wrong, putting
the linked page on a bad path...).
But on my main project (java project), it is not working. The simple
html href works, but not the jsp include.
Also, I tried the AnyEdit plugin, and its "Open file under cursor"
functionnality works !
So, I guess that with the wtp, the navigation functionnality has a
context problem with my project that is java project and not a web
project. But my linked file path is good, because I have a summray
of the annotations belonging to the linked file. In other words, the
scriplet compilation mechanism seems to find the jsp file, but
not the navigation mechanism. So, is it a configuration/environnment
problem, or a bug of the navigation mechanism ?
Sylvain
PS: Andrei, your plugin AnyEdit is fine. Why have you put a "To lower
case" and "To upper case" functionnalities as they already exist
natively in Eclipse (Ctrl+Alt+X and Ctrl+Alt+Y) ?
I don't see any difference.
Andrei Loskutov wrote:
> Hi Sylvian,
> Kind regards,
> Andrei Loskutov
>> Hello,
>> especially to the WTP team who did a fantastic job !
>> using F3 for example to open declaration), and with the check
>> 'Support hyperlink style navigation for "Open Declaration"' checked !
>> environnement ?
>> Thx
>> Sylvain
Re: Navigation in JSP with M2 [message #61694 is a reply to message #61011] Wed, 05 January 2005 14:31 Go to previous messageGo to next message
Am Wed, 05 Jan 2005 11:39:34 +0100 hat Sylvain Chabert
> Sylvain
Hmm... Simply because I have missed it in Eclipse 3.0 (my mistake ;)) and
it was too simple to implement it ;)
Re: Navigation in JSP with M2 [message #62205 is a reply to message #61011] Thu, 06 January 2005 09:52 Go to previous message
I found out there is already a bug reported about it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71224
> Hello,
> Sylvain
>> Hi Sylvian,
>> Kind regards,
>> Andrei Loskutov
>>> Hello,
>>> environnement ?
>>> Thx
>>> Sylvain
Previous Topic:Validation JSP
Next Topic:XML Editor code completion failures with attributes in xsd schema
Current Time: Sun Jul 13 11:02:08 EDT 2025
Powered by FUDForum. Page generated in 0.04603 seconds
