Home » Eclipse Projects » Plugin Development Environment (PDE) » Issue in building feature by fetching it from repository
Issue in building feature by fetching it from repository [message #60091] Thu, 07 May 2009 07:40 Go to next message
Concerning Eclipse 3.4.1
I am trying to build my feature by fetching it from repository.
I followed the following path in Eclipse Help Contents - Plug-in
Development Environment Guide > Tasks > PDE Build Advanced Topics >
Fetching from Repositories
I made a map file which contains entries for all my features and plugins,
except eclipse plugins such as org.apache.xerces, org.apache.xml.resolver,
etc.
Hence I am getting an error as 'Missing expected directory
org.apache.xerces...'
I dont get it, how am I supposed to fetch these plugins from CVS when its
not even present there ?
Nitin Bohara
Re: Issue in building feature by fetching it from repository [message #60160 is a reply to message #60091] Thu, 07 May 2009 09:25 Go to previous messageGo to next message
Originally posted by: mickael.istria.openwide.fr
Hello Nitin,
If you want to includes org.apache.x* bundles in your feature, then you
have to fetch them from Orbit. See
http://wiki.eclipse.org/Easy_Bake_Builds_with_Orbit_Bundles for more
details.
If necessary, you can ask the Orbit newsgroup (eclipse.tools.orbit)
HTH
Mickael
> plugins, except eclipse plugins such as org.apache.xerces,
> org.apache.xml.resolver, etc.
> its not even present there ?
> Nitin Bohara
Re: Issue in building feature by fetching it from repository [message #60230 is a reply to message #60160] Fri, 08 May 2009 00:14 Go to previous messageGo to next message
Thanks Mickael,
I'll try this out.
Re: Issue in building feature by fetching it from repository [message #60422 is a reply to message #60160] Mon, 11 May 2009 04:13 Go to previous message
I tried this but its not working, reason being the server on which the
build is to be performed does not have access to internet and hence can
not fetch the plugin bundles from Orbit.
Is it possible for me to fetch these plugins from the directory where
eclipse is installed on my server? If yes, what should be the appropriate
entry in the .map file ?
I would really appreciate it if someone could quote an example.
Nitin Bohara
Mickael Istria wrote:
> Hello Nitin,
> details.
> HTH
> Mickael
Re: Issue in building feature by fetching it from repository [message #597016 is a reply to message #60091] Thu, 07 May 2009 09:25 Go to previous message
Hello Nitin,
details.
HTH
Mickael
> Nitin Bohara
Re: Issue in building feature by fetching it from repository [message #597045 is a reply to message #60160] Fri, 08 May 2009 00:14 Go to previous message
Thanks Mickael,
I'll try this out.
Re: Issue in building feature by fetching it from repository [message #597121 is a reply to message #60160] Mon, 11 May 2009 04:13 Go to previous message
Nitin Bohara
> Hello Nitin,
> details.
> HTH
> Mickael
Previous Topic:Resolving link paths against the target platform in Eclipse IDE
Next Topic:Specifying dependend update sites to one's own
Current Time: Thu Jul 17 20:00:38 EDT 2025
Powered by FUDForum. Page generated in 0.08822 seconds
