Issue in building feature by fetching it from repository [message #60091] |
Thu, 07 May 2009 07:40  |
Concerning Eclipse 3.4.1
I am trying to build my feature by fetching it from repository.
I followed the following path in Eclipse Help Contents - Plug-in
Development Environment Guide > Tasks > PDE Build Advanced Topics >
Fetching from Repositories
I made a map file which contains entries for all my features and plugins,
except eclipse plugins such as org.apache.xerces, org.apache.xml.resolver,
etc.
Hence I am getting an error as 'Missing expected directory
org.apache.xerces...'
I dont get it, how am I supposed to fetch these plugins from CVS when its
not even present there ?
Nitin Bohara
Re: Issue in building feature by fetching it from repository [message #60422 is a reply to message #60160] |
Mon, 11 May 2009 04:13  |
I tried this but its not working, reason being the server on which the
build is to be performed does not have access to internet and hence can
not fetch the plugin bundles from Orbit.
Is it possible for me to fetch these plugins from the directory where
eclipse is installed on my server? If yes, what should be the appropriate
entry in the .map file ?
I would really appreciate it if someone could quote an example.
Nitin Bohara
Mickael Istria wrote:
> Hello Nitin,
> If you want to includes org.apache.x* bundles in your feature, then you
> have to fetch them from Orbit. See
> http://wiki.eclipse.org/Easy_Bake_Builds_with_Orbit_Bundles for more
> details.
> If necessary, you can ask the Orbit newsgroup (eclipse.tools.orbit)
> HTH
> Mickael
Re: Issue in building feature by fetching it from repository [message #597016 is a reply to message #60091] |
Thu, 07 May 2009 09:25  |
Hello Nitin,
details.
HTH
Mickael
> plugins, except eclipse plugins such as org.apache.xerces,
> org.apache.xml.resolver, etc.
> its not even present there ?
> Nitin Bohara
Re: Issue in building feature by fetching it from repository [message #597121 is a reply to message #60160] |
Nitin Bohara
> Hello Nitin,
> details.
> HTH
> Mickael
FUDForum. Page generated in 1.49198 seconds
