| Is it a bug? Help me please [message #60084] |
Wed, 18 June 2003 04:44  |
Hello, I've a little problem using Eclipse. If i create 2 file like these
inside a package named "ptest":
File1:
package ptest;
class Myclass1 {
public int testInt = 5;
class Myclass2 {
public String testString = "Hi";
FileMain:
package ptest;
public class FileMain {
Myclass2 a = new Myclass2(); // Here Eclipse underlines Myclass2
System.out.println(a.testString);
Eclipse compiles correctly (the program runs), but underlines in red
"Myclass2" FileMain.
The code is perfectly legal since the first classes (Myclass1 and Myclass2)
have package visibility and if i use for example JBuilder, it works
correctly and doesn't underline nothing. The result is that i cannot work
with Eclipse, since in my program i've a lot of classes (around 600) and i
grouped some of them by functionality in various files, but Eclipse doesn't
recognize the type of the variables i declared and all the advanced features
don't work.
Is this a bug? Is there some workaround for this?
Thank you for your answers.
Bitblaster
| Re: Is it a bug? Help me please [message #60183 is a reply to message #60084] |
Wed, 18 June 2003 07:37   |
------=_NextPart_000_0238_01C335A7.21A0C220
Content-Type: text/plain;
charset="windows-1251"
Hi=20
I've reproduced your situation on Eclipse 2.1 (200303272130) and the =
line is really marked as error.
Funny thing is that the file FileMain isn't marked as "errorneus" in the =
package explorer, the file gets compiled (I have a .class file) and even =
I was able to run it.=20
I tryed to compile the same source outside of eclipse and it compiled =
fine with JDK 1.3+
however compilation with JDK 1.2.2 and 1.1.8 failed with:
FileMain.java:20: class ptest.Myclass2 is defined in Myclass1.java. =
Because it is used outside of its source file, it should be defined in a =
file called "Myclass2.java".
The default setting for eclispe is to maintain the .class files JDK 1.1 =
compatible. Unfortunately setting the compatibility level to 1.4 shows =
no effect - the line is still makred as error - so this looks like an =
eclipse bug.
Best regards=20
Vasil
"Bitblaster" <bitblasters@yahoo.it> wrote in message =
news:bcp8p7$5eu$1@rogue.oti.com...
> Hello, I've a little problem using Eclipse. If i create 2 file like =
these
>=20
> File1:
> package ptest;
>=20
> class Myclass1 {
> public int testInt =3D 5;
>=20
> class Myclass2 {
> public String testString =3D "Hi";
>=20
> FileMain:
> package ptest;
>=20
> public static void main(String[] args) {
> Myclass2 a =3D new Myclass2(); // Here Eclipse underlines =
Myclass2
>=20
> The code is perfectly legal since the first classes (Myclass1 and =
Myclass2)
> correctly and doesn't underline nothing. The result is that i cannot =
work
> with Eclipse, since in my program i've a lot of classes (around 600) =
and i
> grouped some of them by functionality in various files, but Eclipse =
doesn't
> recognize the type of the variables i declared and all the advanced =
features
> don't work.
>=20
> Bitblaster
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Dwindows-1251">
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#c0c0c0 background=3D"">
<DIV>Hi </DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV>I've reproduced your situation on Eclipse 2.1 (200303272130) and =
the line=20
is really marked as error.</DIV>
<DIV><FONT size=3D2><FONT size=3D3>Funny thing is that the =
file FileMain isn't=20
marked as "errorneus" in the package explorer, the file gets =
compiled=20
(I have a .class file) and even I was able to run it. =
</FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT size=3D2></FONT></FONT> </DIV>
<DIV><FONT size=3D2><FONT size=3D3>I tryed to compile the same source =
outside of=20
eclipse and it compiled fine with JDK 1.3+</FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT size=3D3></FONT></FONT> </DIV>
<DIV><FONT size=3D2><FONT size=3D3>however compilation with JDK 1.2.2 =
and 1.1.8=20
failed with:</FONT></DIV>
<DIV><BR>FileMain.java:20: class ptest.Myclass2 is defined in =
Myclass1.java.=20
file=20
called=20
"Myclass2.java".<BR>  =
;   ;=20
System.out.println(a.testString);</DIV>
<DIV><BR><FONT size=3D3>The default setting for eclispe is to maintain =
the .class=20
files JDK 1.1 compatible. Unfortunately setting the compatibility level=20
to 1.4 shows no effect - the line is still makred as error - so =
this looks=20
like an eclipse bug.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D3>Best regards </FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D3>Vasil</FONT></DIV>
<DIV><BR><BR>"Bitblaster" <bitblasters@yahoo.it> wrote in message=20
news:bcp8p7$5eu$1@rogue.oti.com...<BR>> Hello, I've a little problem =
using=20
Eclipse. If i create 2 file like these<BR>> inside a package named=20
"ptest":<BR>> <BR>> File1:<BR>> ------------------<BR>> =
package=20
ptest;<BR>> <BR>> class Myclass1 {<BR>> =
public=20
int testInt =3D 5;<BR>> }<BR>> <BR>> class Myclass2=20
{<BR>> public String testString =3D =
"Hi";<BR>>=20
}<BR>> ----------------------------------------<BR>> <BR>>=20
FileMain:<BR>> ------------------<BR>> package ptest;<BR>> =
<BR>>=20
public class FileMain {<BR>> public static =
void=20
main(String[] args) =
{<BR> > &a mp;nbsp; =20
Myclass2 a =3D new Myclass2(); // Here Eclipse underlines=20
Myclass2<BR> > &a mp;nbsp; =20
System.out.println(a.testString);<BR>> =
}<BR>>=20
}<BR>> ----------------------------------------<BR>> <BR>> =
Eclipse=20
compiles correctly (the program runs), but underlines in red<BR>> =
"Myclass2"=20
FileMain.<BR>> The code is perfectly legal since the first classes =
(Myclass1=20
and Myclass2)<BR>> have package visibility and if i use for example =
JBuilder,=20
it works<BR>> correctly and doesn't underline nothing. The result is =
that i=20
cannot work<BR>> with Eclipse, since in my program i've a lot of =
classes=20
(around 600) and i<BR>> grouped some of them by functionality in =
various=20
files, but Eclipse doesn't<BR>> recognize the type of the variables i =
declared and all the advanced features<BR>> don't work.<BR>> Is =
this a=20
bug? Is there some workaround for this?<BR>> Thank you for your=20
answers.<BR>> <BR>> Bitblaster<BR>> <BR>>=20
</FONT></DIV></BODY></HTML>
------=_NextPart_000_0238_01C335A7.21A0C220--
| Re: Is it a bug? Help me please [message #60535 is a reply to message #60183] |
Wed, 18 June 2003 10:00   |
------=_NextPart_000_0015_01C335B2.B93D02A0
Ok, thank you very much for your time, i'll wait for the next version of =
Eclipse, but it looks strange to me that i'm the only who asked for this =
bug (i installed Eclipse for the first time only 2 days ago).
Bye!
Bit
"Vasil Panushev" <v_panushev@prosyst.bg> ha scritto nel messaggio =
news:bcpitm$epo$1@rogue.oti.com...
Hi=20
Funny thing is that the file FileMain isn't marked as "errorneus" in =
the package explorer, the file gets compiled (I have a .class file) and =
even I was able to run it.=20
fine with JDK 1.3+
The default setting for eclispe is to maintain the .class files JDK =
1.1 compatible. Unfortunately setting the compatibility level to 1.4 =
shows no effect - the line is still makred as error - so this looks like =
an eclipse bug.
Best regards=20
Vasil
these
>=20
> File1:
> package ptest;
>=20
> class Myclass1 {
>=20
> class Myclass2 {
>=20
> FileMain:
> package ptest;
>=20
Myclass2
>=20
Myclass2)
work
and i
doesn't
features
> don't work.
>=20
> Bitblaster
>=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2800.1141" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Ok, thank you very much for your time, =
i'll wait=20
for the next version of Eclipse, but it looks strange to me =
that i'm=20
the only who asked for this bug (i installed Eclipse for the =
first=20
time only 2 days ago).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Bye!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Bit</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Vasil Panushev" <<A=20
href=3D"mailto:v_panushev@prosyst.bg">v_panushev@prosyst.bg</A>> ha =
scritto=20
nel messaggio <A=20
href=3D"news:bcpitm$epo$1@rogue.oti.com">news:bcpitm$epo$1@rogue.oti.com<=
/A>...</DIV>
<DIV>Hi </DIV>
the line=20
file FileMain=20
isn't marked as "errorneus" in the package explorer, the =
file gets=20
compiled (I have a .class file) and even I was able to run it.=20
outside of=20
and 1.1.8=20
Myclass1.java.=20
Because it is used outside of its source file, it should be defined in =
a file=20
called=20
;   ;=20
the=20
.class files JDK 1.1 compatible. Unfortunately setting the =
this=20
looks like an eclipse bug.</FONT></DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV><BR><BR>"Bitblaster" <bitblasters@yahoo.it> wrote in =
message=20
news:bcp8p7$5eu$1@rogue.oti.com...<BR>> Hello, I've a little =
problem using=20
package=20
ptest;<BR>> <BR>> class Myclass1 =
{<BR>> =20
public int testInt =3D 5;<BR>> }<BR>> <BR>> class Myclass2=20
"Hi";<BR>>=20
<BR>>=20
void=20
}<BR>>=20
Eclipse=20
compiles correctly (the program runs), but underlines in red<BR>>=20
"Myclass2" FileMain.<BR>> The code is perfectly legal since the =
first=20
classes (Myclass1 and Myclass2)<BR>> have package visibility and if =
i use=20
for example JBuilder, it works<BR>> correctly and doesn't underline =
nothing. The result is that i cannot work<BR>> with Eclipse, since =
in my=20
program i've a lot of classes (around 600) and i<BR>> grouped some =
of them=20
by functionality in various files, but Eclipse doesn't<BR>> =
recognize the=20
type of the variables i declared and all the advanced features<BR>> =
don't=20
work.<BR>> Is this a bug? Is there some workaround for =
this?<BR>> Thank=20
you for your answers.<BR>> <BR>> Bitblaster<BR>> <BR>>=20
</FONT></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0015_01C335B2.B93D02A0--
| Re: Workaround found [message #61540 is a reply to message #61505] |
Thu, 19 June 2003 03:49  |
I wrote emule, i mean Eclipse obviously ;-)
"Bitblaster" <bitblasters@yahoo.it> ha scritto nel messaggio
news:bcrpss$7mf$1@rogue.oti.com...
So i bypassed the problem by adding the output folder as a class folder in
the libraries, so that emule (stupidly) sees that there there is one file
for each class and no longer underlines the class names.
FUDForum. Page generated in 0.05123 seconds
