Home » Archived » BIRT » no chart elements on palette...
no chart elements on palette... [message #60083] Wed, 20 July 2005 03:25 Go to next message
Originally posted by: artekzx.REMOVEo2.pl
....even when I open the example report TopSellingProducts.rptdesign there is
no chart element on the palette and nothing on the report (no chart
elements - grid, table, etc. looks ok)
(the sample report generates ok - the chart is visible)
I use build birt-report-framework-1_0.zip
I've also tried 1.0.1M1 but it looks the same
what might be the problem?
thanks
Arthur
Re: no chart elements on palette... [message #60107 is a reply to message #60083] Wed, 20 July 2005 03:50 Go to previous messageGo to next message
Arthur,
What version of Eclipse are you using? What OS version?
Can you make sure all the chart plugins are loaded, there are six of them
(you can see that in the About dialog, click on plugins button, chart
plugins start with BIRT Chart...)
Can you check for errors in your eclipse log file inside the workspace
directory?
David
"Metal" <artekzx@REMOVEo2.pl> wrote in message
news:dbku95$nk0$1@news.eclipse.org...
> is
> thanks
> Arthur
Re: no chart elements on palette... [message #60178 is a reply to message #60107] Wed, 20 July 2005 08:42 Go to previous messageGo to next message
Thanks David for quick response,
I'm using eclpse version 3.0.2
Windows 2000 SP4
in the about dialog there is exactly 6 plugins with names begining with
"BIRT Chart..."
the rest of birt plugins: 17 - "BIRT..." and one "Business
Intelligence........"
I started again "clean" eclipse and opened the sample report (problem still
exists)
then a checked workspace dir and there is no .log file (in all subdirs also)
so I suppose the have been no exceptions...
any ideas ?
Re: no chart elements on palette... [message #60224 is a reply to message #60178] Wed, 20 July 2005 09:34 Go to previous messageGo to next message
This looks good, there is probably something you missed in the installation
procedure. Please check
http://www.eclipse.org/birt/index.php?page=build/install.htm l for details on
how to install.
David
news:dblgru$fcl$1@news.eclipse.org...
> Windows 2000 SP4
> "BIRT Chart..."
> still
> exists)
> also)
> any ideas ?
Re: no chart elements on palette... [message #60274 is a reply to message #60224] Wed, 20 July 2005 13:41 Go to previous message
thanks, I missed EMF
I thought it was already in plugins dir... but it was not :)
Previous Topic:birt: detail rows with different column layout ?
Next Topic:Viewer Confusion
Current Time: Sun Jul 27 18:06:26 EDT 2025
Powered by FUDForum. Page generated in 0.03919 seconds
