[Gantt] Workaround for scrollbars [message #60081] |
Fri, 10 October 2008 11:47 |
--------------070004050802020207070500
Hi gantt users !
I have found a workaround to re-set the scroll bar location after a refresh.
It seems that during the gantt redraw, the scrollbar's selection value
is not used to draw, so programmatically changing the scrollbar
selection will be taken into account.
The workaround simply send a fake event saying the scrollbar changed
it's selection.
+1 for a GanttComposite.refresh(boolean restoreScrollBars).
Laurent Marchal.
Content-Type: text/x-java;
name="fix.java"
Content-Disposition: inline;
filename="fix.java"
ScrollBar vScrollBar = _ganttChart.getGanttComposite().getVerticalBar();
int vScroll = vScrollBar != null ? vScrollBar.getSelection() : 0;
// do what you need
// restore scroll status
if (vScrollBar != null) {
vScrollBar.setSelection(vScroll);
//refresh the chart
_ganttChart.getGanttComposite().refresh();
// send events to force refresh
Event event = new Event();
// needed !
event.detail = 1;
vScrollBar.notifyListeners(SWT.Selection, event);
--------------070004050802020207070500--
FUDForum. Page generated in 0.04026 seconds
