Home » Eclipse Projects » GEF » How to implement the Model in GEF
How to implement the Model in GEF [message #60069] Thu, 30 January 2003 08:26 Go to next message
Originally posted by: m.spork.DELETE_THIS_SPAMBLOCKqut.edu.au
I'm trying to get my head around the Model aspect of GEF and using the
logic example to help. It appears that all model classes should have a
common parent. This seems to make sense as a lot of the code todo with
PropertyChange Listeners is common to all elements of a model. So in
the Logic example we have LogicElement as the top level model class.
In the second level of the inheritence hierachy the model seems to
split along two lines - in graph terminology LogicSubParts are "nodes"
(with inputs and outputs) and Wires are the "arcs" with target and
source nodes.
So far so good?
Here's where I get confused - LogicDiagram is a subclass of
LogicSubPart. Ok - I can understand that some aspects of LogicSubParts
implementation is relevant to LogicDiagram - namely the size and
location properties. But can a LogicDiagram have inputs and outputs
like a node? IOW - is it possible to recursively embed one
LogicDiagram in another?
I know this is only example code - just wondering if the inheritence
hierachy here makes complete sense. I want to make sure I understand
how models are meant to work in GEF before I move on to understanding
EditParts.
Murray
Re: How to implement the Model in GEF [message #60092 is a reply to message #60069] Thu, 30 January 2003 10:05 Go to previous message
GEF makes no requirements on the model, how it is implemented, or how it
notifies changes. You are free to use anything that makes sense to your
application. PropertyChange was used because most java programmers are
familiar with it, and the purpose of the example is to learn GEF, not the
model.
"Murray Spork" <m.spork@DELETE_THIS_SPAMBLOCKqut.edu.au> wrote in message
news:4i7i3vo4j1quoin8j4rs71sn9s1kjkkb3j@4ax.com...
> source nodes.
> So far so good?
> EditParts.
> Thanks
> Murray
Previous Topic:A word about examples and GEF
Next Topic:How can install the example project of GEF?
Current Time: Sun Oct 19 00:20:40 EDT 2025
Powered by FUDForum. Page generated in 0.03122 seconds
