Home » Archived » BIRT » Viewer Confusion
Viewer Confusion [message #60059] Wed, 20 July 2005 03:06 Go to next message
Originally posted by: attley.gmail.com
I am confused as to whether or not I need to deploy the Birt Viewer as a
separate app to my Websphere app server. I want to be able to run reports
from a url, birt/frameset?__ etc.
Or as someone else said, can I:
whe@actuate.com wrote:
... or simply copy the BIRT viewer into your web application.
The documentation says to copy Report Viewer/birt and place in TOMCAT
webbapps, does anyone know where to copy the files to in Webspere.
I created a new project and moved all of the files under WebContent and
then deployed the viewer, in my admin console it says that it's deployed.
When I go to localhost:9080/projectname/index.jsp it says, the webpage
comes up and says congratulations birt viewer successfully installed.
However when I click the example link I get an error 500 about a
ScriptableObject method, something about Mozilla and javascript (I'm
posting from home and can't remember exact error)
I know this is long but I'm desperate to implement this and my company is
looking for BIRT as a viable reporting solution.
Thanks much everyone,
Simon
Re: Viewer Confusion [message #60322 is a reply to message #60059] Wed, 20 July 2005 16:44 Go to previous messageGo to next message
Simon,
You probably have to deploy the viewer as a war file on WAS. And use WAS
setting:
Classloader Mode: parent_last
War Classloader policy: appliction
So far we have test the WAS 5.1. Let us know if you see more problem.
Jun Zhai
Re: Viewer Confusion [message #60367 is a reply to message #60322] Wed, 20 July 2005 18:45 Go to previous messageGo to next message
Jun,
Thanks for your help - I successfully deployed the Birt Viewer to my
WebSphere Application Server 6.0.0.0.
The below configuration was essential, prior to doing this it did not work.
Simon
Re: Viewer Confusion [message #60390 is a reply to message #60367] Wed, 20 July 2005 21:17 Go to previous message
Great. New version will resolve this issue from within our code and avoid
this type of deployment difficulties.
Jun Zhai
Previous Topic:no chart elements on palette...
Next Topic:Viewer and Run Servlet
Current Time: Sun Jul 13 01:36:40 EDT 2025
Powered by FUDForum. Page generated in 0.03615 seconds
