Home » Eclipse Projects » Mylyn » Trac problems with certificates
Trac problems with certificates [message #60054] Thu, 16 October 2008 05:38 Go to next message
Originally posted by: alexander.lex.gmx.at
I have problems connecting to a trac server that uses a certificate.
When I try to download eg a task, then I get the following error message:
The certificate is not trusted because the issuer certificate is unknown.
(Error code: sec_error_unknown_issuer)
I had a similar issue with firefox, but this has been resolved somehow. The
certificate is certainly valid and the issuer is known to both firefox and
opera.
The certificiate is a Cybertrust Educational, a somewhat related discussion
is here:
http://www.nabble.com/About-the-Cybertrust-Educational-CA-ce rtificate-td19513129.html
I used to ignore the warnings in Firefox (which does not seem to be possible
in Mylyn) but don't get any warnings in Firefox any more (and I have not
added an exception in Firefox)
What can I do to make mylyn work with that trac repository?
Alex
Re: Trac problems with certificates [message #60078 is a reply to message #60054] Thu, 16 October 2008 14:12 Go to previous messageGo to next message
Try following the steps outlined here:
http://wiki.eclipse.org/Mylyn/FAQ#Why_do_I_get_an_error_when _accessing_secured_web_sites.3F
I am not sure if this still works with current versions of the internal
browser.
Steffen
Alexander Lex wrote:
> The certificate is certainly valid and the issuer is known to both firefox
> and opera.
> discussion is here:
> possible in Mylyn) but don't get any warnings in Firefox any more (and I
> have not added an exception in Firefox)
> Alex
Re: Trac problems with certificates [message #60126 is a reply to message #60078] Fri, 17 October 2008 05:33 Go to previous messageGo to next message
Great! Worked perfectly!
Thx!
Alex
> browser.
> Steffen
>> firefox and opera.
>> discussion is here:
>> Thanks,
>> Alex
Re: Trac problems with certificates [message #60887 is a reply to message #60078] Mon, 27 October 2008 12:25 Go to previous messageGo to next message
> browser.
It works for me, but the Wiki page could be updated in two ways:
1. change mozilla to firefox (i think that firefox is used more these
days) or provide a note that this part of the command could be changed
2. as people are likely to view the page in firefox, issuing the command
will open a new window in the same browser instance and not load a new
profile. In order to achieve this, -no-remote has to be added to the
command line.
Jorrit
Re: Trac problems with certificates [message #60932 is a reply to message #60887] Mon, 27 October 2008 13:39 Go to previous messageGo to next message
Great points! Please go ahead and make these changes. It's a wiki
afterall :).
Steffen
>> browser.
> command line.
> Jorrit
Re: Trac problems with certificates [message #60957 is a reply to message #60932] Tue, 28 October 2008 04:53 Go to previous message
> afterall :).
> Steffen
I couldn't find the registration button, but I just had to look a little
more.
I have added it.
Jorrit
Re: Trac problems with certificates [message #594251 is a reply to message #60054] Thu, 16 October 2008 14:12 Go to previous message
browser.
Steffen
> and opera.
> discussion is here:
> Alex
Re: Trac problems with certificates [message #594270 is a reply to message #60078] Fri, 17 October 2008 05:33 Go to previous message
Thx!
Alex
> browser.
> Steffen
>> firefox and opera.
>> discussion is here:
>> Thanks,
>> Alex
Re: Trac problems with certificates [message #594519 is a reply to message #60078] Mon, 27 October 2008 12:25 Go to previous message
> browser.
command line.
Jorrit
Re: Trac problems with certificates [message #594536 is a reply to message #60887] Mon, 27 October 2008 13:39 Go to previous message
afterall :).
Steffen
>> browser.
> command line.
> Jorrit
Re: Trac problems with certificates [message #594541 is a reply to message #60932] Tue, 28 October 2008 04:53 Go to previous message
> afterall :).
> Steffen
more.
I have added it.
Jorrit
Previous Topic:Unhandled event loop exception
Next Topic:Mylyn Trac connector mappings for priority and severity fields
Current Time: Mon Jul 21 21:54:20 EDT 2025
Powered by FUDForum. Page generated in 0.50559 seconds
