Home » Archived » M2M (model-to-model transformation) » [ATL] atlcommandline
[ATL] atlcommandline [message #60051] Fri, 31 August 2007 04:14 Go to next message
--------------000901000307030400020600
I attempt to run the Families2Persons Example outside Eclipse. I'm using
the ATL Command-Line tool done by Dennis Wagelaar.
When launching the program outside of Eclipse, transformation works and
the output model is generated, but an error is displayed :
java.lang.IllegalStateException: Workspace is
closed.java.lang.IllegalStateException: Workspace is closed.
org.eclipse.core.resources.ResourcesPlugin.getWorkspace(Reso urcesPlugin.java:326)Usage:
<this program> --trans <transformation url> [--in <id>=<model>
<id>=<metamodel> <MDR|EMF>] [--out <id>=<model> <id>=<metamodel>
<MDR|EMF>] [--lib <id>=<library url>] [--superimpose <transformation
url>] --next --trans ...
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:144)
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:61)
at org.atl.commandline.Main.run(Main.java:325)
at org.atl.commandline.Main.main(Main.java:92)
Did someone ever has this problem ?
Thanks in advance,
William
Content-Type: text/x-vcard; charset=utf-8;
name="william.piers.vcf"
Content-Disposition: attachment;
filename="william.piers.vcf"
begin:vcard
fn:William Piers
n:Piers;William
org:Obeo
adr:2 rue Robert Schumann;;lot 24;NANTES;;44408;France
email;internet:william.piers@obeo.fr
title:MDA Consultant
tel;work:+33 (0)2 51 13 51 82
tel;cell:+33 (0)6 20 31 75 98
url:http://www.obeo.fr
version:2.1
end:vcard
--------------000901000307030400020600--
Re: [ATL] atlcommandline [message #60074 is a reply to message #60051] Fri, 31 August 2007 10:13 Go to previous messageGo to next message
I have different line numbers than you specify in your stacktrace. Can
you verify that you have the latest Main.java (from SVN) as well as the
latest ATL? Please also send the parameters you give to Main.java.
Dennis
William Piers schreef:
> Hello,
> at
> at
> at
> Thanks in advance,
> William
Re: [ATL] atlcommandline [message #60097 is a reply to message #60074] Fri, 31 August 2007 10:50 Go to previous messageGo to next message
--------------080405020709030705080402
Thanks for the answer.
Dennis Wagelaar a
Re: [ATL] atlcommandline [message #60263 is a reply to message #60097] Mon, 03 September 2007 07:16 Go to previous messageGo to next message
Ah, I think I found the problem:
IFile file = ResourcesPlugin.getWorkspace().getRoot().getFile(
new Path(uri.path()));
file.setDerived(true);
EMF can work outside the workspace with URIs, but now ATL tries to set
all generated files as derived. ATL should only do that when the Eclipse
workspace is available.
Please copy & paste this entire conversation into bugzilla ;-).
Dennis
P.S. If I'm correct about this problem, your model should still be
saved. Please check if this is true.
> Hello,
> I think I use the latest version, but when I copy the stack trace I may
> have added some System.out.println somewhere in order to debug...
> The exact trace is :
> at
> at
> at
> at org.atl.commandline.Main.run(Main.java:324)
> at org.atl.commandline.Main.main(Main.java:91)
> Are line numbers correct ?
> And the Main I use is this one :
> http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML1CaseStudies/uml 1cs-atlcommandline/src/org/atl/commandline/Main.java?view=ma rkup
>> as well as the latest ATL?
> In order to use the latest ATL and Eclipse version I had to update some
> libraries which where not available at the location indicated in the
> copydep.xml file. So I need to build vm.jar and emf4atl.jar myself using
> ATL latest source code.
> So I think libraries are OK.
> Here is the command I use for launching :
> --trans file:/D:/test/Families2Persons.asm --in
> IN=file:/D:/test/sample-Families.ecore
> Families=file:/D:/test/Families.ecore EMF --out
> OUT=file:/D:/test/sample-Persons.ecore
> Persons=file:/D:/test/Persons.ecore EMF
> NOTE :
> I did a little modification to the original Main.java file, at line 112
> : I replaced
> URI absURI = URI.createURI(uri).resolve(cwd);
> by
> URI absURI = URI.createURI(uri);//.resolve(cwd);
> Because when launching, I had this error :
> java.lang.IllegalArgumentException: resolve against non-hierarchical or
> relative base
> at org.eclipse.emf.common.util.URI.resolve(URI.java:1940)
> at org.eclipse.emf.common.util.URI.resolve(URI.java:1913)
> at org.atl.commandline.Main.loadModel(Main.java:112)
> at org.atl.commandline.Main.addInputModel(Main.java:219)
> at org.atl.commandline.Main.parseArgs(Main.java:160)
> at org.atl.commandline.Main.main(Main.java:89)
> But this modification has no effect on the "saveModel" part, which seems
> to be problematic in my bug.
> Thanks in advance,
> William
>> Dennis
>>> Hello,
>>> using the ATL Command-Line tool done by Dennis Wagelaar.
>>> and the output model is generated, but an error is displayed :
>>> at
>>> at
>>> at
>>> Thanks in advance,
>>> William
Re: [ATL] atlcommandline [message #60358 is a reply to message #60263] Mon, 03 September 2007 08:31 Go to previous messageGo to next message
--------------070006000904040305090703
OK thanks.
Indeed the file is saved. I reported the bug.
William Piers
Dennis Wagelaar a
Re: [ATL] atlcommandline [message #60406 is a reply to message #60358] Tue, 04 September 2007 08:43 Go to previous message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi William,
I already had this kind of problem in the past and I implemented a new
"save" method which allows specifying if the model you want to save is
inside or outside the workspace. This method has been integrated into
the AtlEMFModelHandler class.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=197797
Hugo
P.S. I also post this text as a new comment in Bugzilla
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=202069)
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Previous Topic:[ATL] Splitting ASMModel
Next Topic:[QVT] Are oml output models write-only by spec?
Current Time: Sun Jul 06 14:34:01 EDT 2025
Powered by FUDForum. Page generated in 0.04153 seconds
