Home » Modeling » OCL » Carriage return in OCL expressions
Carriage return in OCL expressions [message #60028] Fri, 01 August 2008 06:24 Go to next message
--------------060706000403050301090105
I was trying to create a String containing a carriage return through an
OCLExpression such as 'random string'.concat('\n') and ended up with a
java String looking as "random string\\n" so OCL automatically escaped
my "\". Indeed the String is then exactly as I wrote it ... except it
means I cannot concatenate control characters in an OCL String.
Is that the expected behavior for OCL Strings? If so, is there a known
way to have a carriage return inserted into a String via OCL?
Laurent Goubet
Obeo
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr/">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------060706000403050301090105--
Re: Carriage return in OCL expressions [message #60100 is a reply to message #60028] Fri, 01 August 2008 09:26 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Laurent,
The OCL Specification does not make any provision for handling of
control characters. What do you get if you simply embed a newline in
the string, as in
'this is
an example'
Actually, I had expected that '\n' would work. AFAIK, the grammar is
supposed to have implemented that.
Would you mind raising a bug?
Christian
laurent Goubet wrote:
> Thanks
> Laurent Goubet
> Obeo
Re: Carriage return in OCL expressions [message #60124 is a reply to message #60100] Fri, 01 August 2008 10:13 Go to previous message
--------------000501000002070201090008
Christian,
Well in my case embedding a plain new line in the String is not a
solution as the project I'm working is in its early stages and a plain
new line would have to be handled too ;).
I raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=242880 to record
this problem.
Laurent Goubet
Obeo
Christian W. Damus a
Previous Topic:Converting query result for EMF serialization?
Next Topic:String operation - trim function
Current Time: Wed Jul 16 22:04:27 EDT 2025
Powered by FUDForum. Page generated in 0.69931 seconds
