Home » Newcomers » Newcomers » Still Can't Run SWT App
Still Can't Run SWT App [message #59999] Fri, 29 April 2005 20:14 Go to next message
Originally posted by: jaschulz.wiseware.com
I raised this question a week or so ago. I tried everything everybody
suggested, but nothing worked.
I uninstalled Eclipse, and both the JDK and the JRE. I downloaded the
latest versions of everything:
Eclipse Version: 3.0.2 Build id: 200503110845
jdk1.5.0_03
jre1.5.0_03
I have:
-Djava.library.path="C:\eclipse\plugins\org.eclipse.swt.win32_3.0.2\os\win32\x86 "
in the VM asrguments for the project.
I copied the entire contents of:
c:\eclipse\plugins\org.eclipse.swt.win32_3.0.2\os\win32\x86
to:
c:\windows\system32
and still, I get:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-win32-3064 in java.library.path
This is making me crazy! Can't anyone tell me what I am doing wrong?
JAS
Re: Still Can't Run SWT App [message #60099 is a reply to message #59999] Sat, 30 April 2005 12:43 Go to previous messageGo to next message
> jdk1.5.0_03
> jre1.5.0_03
> I have:
> to:
> c:\windows\system32
> and still, I get:
> Thanks
> JAS
You need to get the swt-win32-3064.dll file and put it in your system32
directory. It is contained in the swt zip file. You do not need to copy
the entire plugin directory to the system32 directory just the two
dll's. Do a dir in your system32 directory and see if the two dll's are
there.
Re: Still Can't Run SWT App [message #60147 is a reply to message #60099] Sat, 30 April 2005 22:32 Go to previous messageGo to next message
>> jdk1.5.0_03
>> jre1.5.0_03
>> I have:
>> to:
>> c:\windows\system32
>> and still, I get:
>> Thanks
>> JAS
> there.
Maybe I wasn't as clear as I thought. When I said: "I copied the entire
contents of:
to:
c:\windows\system32
I meant literally that. I did not copy the entire plugins folder,
merely the one I specified above. The contents of that folder are:
javaw.exe.manifest
swt-awt-win32-3064.dll
swt-win32-3064.dll
So, in fact, I have already done what you suggest, but it simply doesn't
fix the problem.
This just doesn't make any sense to me.
Any other ideas?
JAS
Re: Still Can't Run SWT App [message #60218 is a reply to message #60147] Sun, 01 May 2005 10:26 Go to previous messageGo to next message
> Any other ideas?
> JAS
Can't you simply print out System.getProperties("java.library.path") and dump the dll in
one of the dir there?
/adam
Re: Still Can't Run SWT App [message #60266 is a reply to message #60218] Sun, 01 May 2005 16:16 Go to previous messageGo to next message
Adam,
Sure, I can make a dummy app to do that, and it does print out the
library path that I set in the JVM arguments. But, of course, my dummy
app doesn't use SWT, and my SWT app won't compile, so I can't test the
library path in it.
So, I am still stuck.
JAS
Adam Kiezun wrote:
>> Any other ideas?
>> JAS
> dump the dll in one of the dir there?
> /adam
Re: Still Can't Run SWT App [message #60289 is a reply to message #60266] Sun, 01 May 2005 17:04 Go to previous messageGo to next message
and it doesn't work even if you copy the dll to the jdk's or jre's bin directory (where
the awt.dll etc. is)?
basically, locate the awt.dll and put the swt dlls there. i remember i used that as a
workaround once.
it must be something completely silly. just taking forever to find. i understand the pain.
there must be something competely bizzare with your install.
/adam
> Adam,
> library path in it.
> JAS
> Adam Kiezun wrote:
>>> Any other ideas?
>>> JAS
>> and dump the dll in one of the dir there?
>> /adam
Re: Still Can't Run SWT App [message #60745 is a reply to message #60289] Mon, 02 May 2005 08:24 Go to previous messageGo to next message
Adam,
Well, at least that got me a new error, to wit:
Exception in thread "main" java.lang.ClassCastException:
org.eclipse.swt.layout.GridData at
org.eclipse.swt.layout.RowLayout.computeSize(RowLayout.java: 201)at
org.eclipse.swt.layout.RowLayout.layoutHorizontal(RowLayout. java:248)at
org.eclipse.swt.layout.RowLayout.computeSize(RowLayout.java: 190)at
org.eclipse.swt.widgets.Composite.computeSize(Composite.java :157)at
org.eclipse.swt.widgets.Control.pack(Control.java:1390) at
org.eclipse.swt.widgets.Control.pack(Control.java:1364) at
temperatureConverter.TemperatureConverter.<init>(TemperatureConverter.java:52)at
temperatureConverter.TemperatureConverter.main(TemperatureCo nverter.java:91)
Frankly, I don't understand this error, but it seems at least odd to me
that it should include two references to:
one numbered 1390 and one numbered 1394.
Any ideas?
JAS
> bin directory (where the awt.dll etc. is)? basically, locate the
> workaround once.
> understand the pain. there must be something competely bizzare with
> your install. /adam
>> Adam,
>> dummy app doesn't use SWT, and my SWT app won't compile, so I
>> can't test the library path in it.
>> JAS
>> Adam Kiezun wrote:
>>>> Any other ideas?
>>>> JAS
>>> System.getProperties("java.library.path") and dump the dll in one
>>> of the dir there?
>>> /adam
Re: Still Can't Run SWT App [message #60747 is a reply to message #60745] Mon, 02 May 2005 08:58 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
From the exception it seems that you use a RowLayout in TemperatureConverter
and one of its widgets you set a GridData instance using the setLayoutData
method. If this is the case it is incorrect usage because for RowLayout you
have to use RowData instances to provide layout data.
HTH,
Csaba
> Adam,
2)at
> Any ideas?
> JAS
>> workaround once.
>> your install. /adam
>>> Adam,
>>> JAS
>>> Adam Kiezun wrote:
>>>>> Any other ideas?
>>>>> JAS
>>>> of the dir there?
>>>> /adam
Re: Still Can't Run SWT App [message #60748 is a reply to message #60745] Mon, 02 May 2005 09:53 Go to previous messageGo to next message
recursion? :)
/adam
ps. so you're on the right track now. the dll loads!
Re: Still Can't Run SWT App [message #60750 is a reply to message #60747] Mon, 02 May 2005 10:59 Go to previous messageGo to next message
Thanks. Yes, that was it. The book from which I was working had a
serious typo (i.e. using RowLayout instead of GridLayout).
JAS
Horváth, Csaba wrote:
> HTH,
> Csaba
>>Adam,
> 2)at
>>Any ideas?
>>JAS
>>>workaround once.
>>>your install. /adam
>>>>Adam,
>>>>JAS
>>>>Adam Kiezun wrote:
>>>>>>Any other ideas?
>>>>>>JAS
>>>>>of the dir there?
>>>>>/adam
Re: Still Can't Run SWT App [message #60751 is a reply to message #60748] Mon, 02 May 2005 11:01 Go to previous message
Yes, thanks. I am making some progress, but it certainly is troubling
that the -D argument won't allow the app to locate the .dlls. That
can't be the way Eclipse is supposed to work.
JAS
> recursion? :)
> /adam
Previous Topic:Exported JARs & classpaths
Next Topic:"Missing code implementation in the compiler" Error Message
Current Time: Sun Aug 31 15:12:11 EDT 2025
Powered by FUDForum. Page generated in 0.10228 seconds
