Home » Language IDEs » ServerTools (WTP) » Problem debugging Servlets and JSPs
Problem debugging Servlets and JSPs [message #59992] Tue, 04 January 2005 09:24 Go to next message
Originally posted by: jmordax.terra.es
I have followed the Min-Tutorial
( http://www.eclipse.org/webtools/testtutorials/M2/tutorial1/w tp-tutorial-I.html)
using Tomcat 5.0.28
I added a breakpoint inside the servlet and the JSP and started the
server in debug mode. The problem is that debugger complains that it
doesn't find the source code of the servlet and the JSP.
I understood debugging was added in M2. Right?
What am I doing wrong so the debugeer doesn't find the source code of mi
simple Servlet and JSP?
Thanks in advance,
Chemi.
Re: Problem debugging Servlets and JSPs [message #60012 is a reply to message #59992] Tue, 04 January 2005 09:27 Go to previous message
> using Tomcat 5.0.28
> mi simple Servlet and JSP?
> Thanks in advance,
> Chemi.
Opps! After ask I was able to add the project to the lookup path. But I
understand this should be automatic. Right?
Chemi.
BTW: The Context Menu of the JSP editor when debugging doesn't offer the
Java editor options like Inspect, Display, etc.... Is it in plans?
Previous Topic:javax.servlet.*: attach sources
Next Topic:war validation problem
Current Time: Sun Aug 31 15:11:15 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
