Re: Problem debugging Servlets and JSPs [message #60012 is a reply to message #59992] |
Tue, 04 January 2005 09:27  |
Originally posted by: jmordax.terra.es
Chemi wrote:
> I have followed the Min-Tutorial
> ( http://www.eclipse.org/webtools/testtutorials/M2/tutorial1/w tp-tutorial-I.html)
> using Tomcat 5.0.28
> I added a breakpoint inside the servlet and the JSP and started the
> server in debug mode. The problem is that debugger complains that it
> doesn't find the source code of the servlet and the JSP.
> I understood debugging was added in M2. Right?
> What am I doing wrong so the debugeer doesn't find the source code of
> mi simple Servlet and JSP?
> Thanks in advance,
> Chemi.
Opps! After ask I was able to add the project to the lookup path. But I
understand this should be automatic. Right?
Chemi.
BTW: The Context Menu of the JSP editor when debugging doesn't offer the
Java editor options like Inspect, Display, etc.... Is it in plans?
FUDForum. Page generated in 0.03757 seconds
