Home » Eclipse Projects » Eclipse Platform » Help wanted: setup jre for eclipse help
Help wanted: setup jre for eclipse help [message #59935] Tue, 03 June 2003 00:45 Go to next message
For reasons I don't want to install JDK with the installer, instead, I just
install on one machine and use batch files to share the installation and
setup environment on other machines (This avoid different versions competing
for the browser plugin place and step on each other's toes). This served me
well untill I used a batch file to setup environment and run Eclipse under
windows... The help is broken.
Apache Tomcat/4.0.6 - HTTP Status 500 - Internal Server Error
type Exception report
message Internal Server Error
description The server encountered an internal error (Internal Server Error)
that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP
at org.apache.jasper.servlet.JspServlet.loadJSP(JspServlet.java :580)
org.apache.jasper.servlet.JspServlet$JspServletWrapper.loadI fNecessary(JspSe
rvlet.java:176)
org.apache.jasper.servlet.JspServlet$JspServletWrapper.servi ce(JspServlet.ja
va:188)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:381)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :473)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(Application
FilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterCh
ain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.ja
va:243)
org.apache.catalina.core.StandardPipeline.invokeNext(Standar dPipeline.java:5
66)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:472)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:943)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.ja
va:190)
66)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:2
46)
64)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2347)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180
66)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.
java:170)
64)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:170
64)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java
:174)
66)
org.apache.catalina.connector.http.HttpProcessor.process(Htt pProcessor.java:
1027)
org.apache.catalina.connector.http.HttpProcessor.run(HttpPro cessor.java:1125
at java.lang.Thread.run(Thread.java:536)
I thought about it and suspect that it is due to the fact that jre was not
in my system environment thus servlet compilation failed. Is there anyway I
can fix it? I assume unix/linux user would have solved the issue long ago.
Luke
Re: Help wanted: setup jre for eclipse help [message #64153 is a reply to message #59935] Thu, 05 June 2003 12:54 Go to previous messageGo to next message
JSPs in Eclipse are precompiled and you should not get the error you are
getting. If you edit the JSP in help webapp, it requires JDT for
compilation, so you need to run Eclipse SDK, not the platform. I do not see
how placing JDK on another machine can have any influence, but you have not
posted your bat files, so it is difficult to speculate.
Konrad Kolosowski
"Liyu Liu" <liyul@hotmail.com> wrote in message
news:bbh8vs$q5p$1@rogue.oti.com...
just
competing
me
Error)
> exception
> at
> rvlet.java:176)
> at
> va:188)
> at
> at
> at
> at
> ain.java:193)
> at
> va:243)
> at
> 66)
> at
> at
> va:190)
> at
> 66)
> at
> 46)
> at
> 64)
> at
> at
> at
> at
> 66)
> at
> java:170)
> at
> 64)
> at
> at
> 64)
> at
> at
> :174)
> at
> 66)
> at
> at
> 1027)
> at
I
> Luke
Re: Help wanted: setup jre for eclipse help [message #64983 is a reply to message #64153] Fri, 06 June 2003 01:18 Go to previous message
Konrad:
Thank you for look into this.
I simply copied the jdk1.4.0 to my local machine and tried again. Eclipse is
installed under
C:\Program Files\eclipse-SDK-2.1-win32\eclipse
as should laid out in the downloaded zip file.
A batch file "C:\Program Files\eclipse-SDK-2.1-win32\startup.bat" is used to
launch Eclipse and the startup directory is "C:\Program
Files\eclipse-SDK-2.1-win32". The content of the batch file is
SET JAVA_HOME=C:\java\jdk1.4.0
SET JRE_HOME=%JAVA_HOME%\jre
SET
CLASSPATH=.;%JRE_HOME%\lib\rt.jar;%JRE_HOME%\lib\i18n.jar;%J AVA_HOME%\tools.
jar
SET PATH=%JAVA_HOME%\bin;%JRE_HOME%\bin;%PATH%
SET SWT_HOME=
java -cp .\eclipse\startup.jar org.eclipse.core.launcher.Main -os win32 -ws
win32 -arch x86 -showsplash 600
REM -data "%USERPROFILE%\My Documents\Eclipse"
pause
I also double-checked the settings under Windows | Preference, under Java |
Installed JREs, it is Standard VM, jdk1.4.0 at C:\java\jdk1.4.0 and the
javadoc API is under file:/C:/java/jdk1.4.0/docs/api/, which was in a
compressed folder.
The help brought me to http://127.0.0.1:1545/help/index.jsp (I used ie
rather than embedded browser to find out, the port number may change in
different sessions), which shows the error message listed in my last email.
I didn't edit the help files, either. The Help | Welcome menus work, but
Tips and tricks and Help Contents fails every time.
I have local administrator's privilege on the machine (XP home).
Luke
"Konrad Kolosowski" <konradk@ca.ibm.com> wrote in message
news:bbnsl4$c56$1@rogue.oti.com...
see
not
> Konrad Kolosowski
> just
> competing
> me
under
> Error)
> > exception
> > at
> > rvlet.java:176)
> > at
> > va:188)
> > at
> > at
> > at
> > at
> > ain.java:193)
> > at
> > va:243)
> > at
> > 66)
> > at
> > at
> > va:190)
> > at
> > 66)
> > at
> > 46)
> > at
> > 64)
> > at
> > at
> > at
> > at
> > 66)
> > at
> > java:170)
> > at
> > 64)
> > at
> > at
> > 64)
> > at
> > at
> > :174)
> > at
> > 66)
> > at
> > at
> > 1027)
> > at
not
anyway
> I
ago.
> > Thanks,
> > Luke
Previous Topic:cvs failure
Next Topic:Branches in CVS Repositories view
Current Time: Tue Jul 22 13:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.03632 seconds
