Home » Archived » M2M (model-to-model transformation) » [ATL] .asm not generated after install of ATL 2.0RC2
[ATL] .asm not generated after install of ATL 2.0RC2 [message #59926] Thu, 30 August 2007 07:28 Go to next message
Originally posted by: botterwe.uni-koblenz.de
Hi all,
PROBLEM
As documented on
http://www.eclipse.org/m2m/atl/download/
I installed ATL 2.0RC2 from the update site at
download.eclipse.org/modeling/m2m/atl/updates/2.0.0
When I edit and save an .atl file I would expect that the corresponding
..asm file is generated automatically. However, this does not happen.
SOME IDEAS
For earlier versions of ATL one had to install additional resources
(ANTLR and mdr-standalone.zip). Is this also required for the install
via update site? Where do I have to put the files?
Thanks for any hints,
Goetz
Re: [ATL] .asm not generated after install of ATL 2.0RC2 [message #59954 is a reply to message #59926] Thu, 30 August 2007 07:44 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Goetz Botterweck a écrit :
> Hi all,
Hi Goetz,
> PROBLEM
> As documented on
Is the project containing the file an ATL one (i.e. a project which is
of the "ATL" nature)? If not, it is normal that the .asm file is not
generated.
You can also check if the "Project->Build Automatically" option (from
the menu bar) has been selected.
> SOME IDEAS
No, with the latest version of ATL you don't have to add the ANTLR jar
which is now already included (and the mdr-standalone archive is
required only if you want to use the mdr4atl driver).
> Goetz
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] .asm not generated after install of ATL 2.0RC2 [message #59977 is a reply to message #59926] Thu, 30 August 2007 08:03 Go to previous messageGo to next message
> Hi all,
> PROBLEM
> As documented on
Are you under the "ATL perspective" ?
Vincent
Re: [ATL] .asm not generated after install of ATL 2.0RC2 [message #60001 is a reply to message #59954] Thu, 30 August 2007 08:46 Go to previous message
> generated.
Yes, that was the problem. After recreating the project as an "ATL
Project" the .asm files are generated as usual.
I did not think about this earlier because I falsely suspected that it
was caused by not installed 3rd party components (ANTLR).
Thanks for the quick help.
Goetz
Previous Topic:UserInteraction in Transformationprocess
Next Topic:New ATL use case: Models Measurement
Current Time: Fri Jul 18 19:11:34 EDT 2025
Powered by FUDForum. Page generated in 0.06592 seconds
