Home » Newcomers » Newcomers » How do I update ANT in eclipse?
How do I update ANT in eclipse? [message #59907] Fri, 29 April 2005 17:07 Go to next message
Originally posted by: nobody.tellus.orb
I read this on internet
"Previous versions of ant had a problem with the javah target under
JDK 1.4, so you must use 1.6.1 or later."
( http://www.mozilla.org/projects/blackwood/webclient/release- notes/
2_0_alpha_2-detail.html)
And since I have a problem using these lines in eclipse's ANT
</javac>
<javah destdir = "." force = "yes" verbose = "true"
classpath = ".">
<class name = "mypackage.MyClass"/>
</javah>
With the following error
BUILD FAILED: ...\build.xml:98: Error starting javah:
java.lang.ClassNotFoundException: com.sun.tools.javah.Main
I thouhgt I might need to update my version of ANT, but I don't know
how.
Is there anyone that knows what's wrong?
~ Daniel
Re: How do I update ANT in eclipse? [message #59975 is a reply to message #59907] Fri, 29 April 2005 19:13 Go to previous message
Always start by telling us which version of Eclipse you are using so I can
give you the specific instruction set
For the 3.1 stream:
Window>preferences>Ant>Runtime>Ant Home
Set it to the install of Ant you wish to use.
For an FYI:
Eclipse 3.0 ships with Ant 1.6.1
Eclipse 3.0.1 ships with Ant 1.6.2
Eclipse 3.0.2 ships with Ant 1.6.2
Eclipse 3.1 is in the process of being moved to Ant 1.6.3
HTH
Darins
"DeMarcus" <nobody@tellus.orb> wrote in message
news:d4u7u9$d67$1@news.eclipse.org...
> </javac>
> classpath = ".">
> </javah>
> how.
> Thanks
> ~ Daniel
Previous Topic:Why can't eclipse create a regular project
Next Topic:Searching, Bookmarks and External Diff
Current Time: Wed Jul 23 00:41:23 EDT 2025
Powered by FUDForum. Page generated in 0.04990 seconds
