Home » Language IDEs » C / C++ IDE (CDT) » CDT editor steals back file associations
CDT editor steals back file associations [message #59876] |
Mon, 27 January 2003 13:54  |
Just sort of digging for a debug step here.....
Is there something intentional or otherwise that would cause the behavior
of file associations getting stolen from a different editor plug-in and
replaced back to the CDT editor?
Note this only happens if I leave the file opened when ending (so it
needs to be restored with workspace).
Steps
- Window->Preferences->File Associations
Changed these extensions to use the other editor
.c, .cc, .cpp, .cxx, .h, .hh, .hpp, .jsp, .java, .txt, Makefile
Double checked the associations were correct.
- Leave the other editor open on a file
- End and restart WSAD
If no editor is open on the file when ending WSAD,
then this bug will not occur.
- Bringing back WSAD, the other editor is correctly restored.
- If that part is closed and reopened, the CDT default C editor for
that part will be used.
Looking back at the file associations, most of them are back to
their CDT default editors.
These get reset back to CDT: .c, .cpp, .h, .hh, .hpp, .jsp, .java
- If there is no instance of the other editor open when ending WSAD (so it
doesn't get restored, the file associations seem to remain correct).
Except for .jsp and .java, all of these extensions are handled by CDT, and
I wonder if there's code in place at CDT startup to make the associations
that
perhaps shouldn't be there?
Perhaps some sort of 'ordering' issue with plug-ins?
Any other ideas?
Thanks!
"The stuff we call "software" is not like anything that human society
is used to thinking about. Software is something like a machine, and
something like mathematics, and something like language, and
something like thought, and art, and information...
but software is not in fact any of those other things."
Bruce Sterling - The Hacker Crackdown
Fred A. Kulack - IBM eServer iSeries ERP, Java DB2 access, Jdbc, JTA, etc...
IBM in Rochester, MN (Phone: 507.253.5982 T/L 553-5982)
mailto:kulack@us.ibm.com Personal: mailto:kulack@magnaspeed.net
AOL Instant Messenger: Home:FKulack Work:FKulackWrk
Re: CDT editor steals back file associations [message #59953 is a reply to message #59876] |
Tue, 28 January 2003 10:40   |
HI,
Just a quick question RE: WSAD. It was my understanding that the currently
released versions all use the "old" CDT. Could you post your WSAD version
and CDT version if possible?
-Judy
You said that you are using
"Fred A. Kulack" <kulack@us.ibm.com> wrote in message
news:b13u72$gu9$1@rogue.oti.com...
| Steps
it
| that
| Any other ideas?
| Thanks!
etc...
Re: CDT editor steals back file associations [message #60032 is a reply to message #59953] |
Tue, 28 January 2003 17:48   |
Sure. Sorry I didn't include that.
The new WSAD is eclipse 2.0.2 based so that means new CDT, right?
WSAD 5.0.0 (build id: 20021125_2118)
Eclipse platform version 2.0.2.1 (build id: 200211071448)
CDT 1.0.1 F2 build org.eclipse.cdt-200301080308-win32_1.0.1.bin.dist.zip
Interestingly enough, I no longer see the F2 build in the stable build
section from
the CDT downloads page but the 'latest GA release' shows the same date as
the
F2 build was.
They're the same build or should I put the GA CDT 1.0.1 on?
"Judy N. Green" <jgreen@qnx.com> wrote in message
news:b1672b$lm$1@rogue.oti.com...
> HI,
> Thanks
> -Judy
behavior
> | Steps
(so
> it
and
associations
> | that
> | Any other ideas?
> | Thanks!
> etc...
Re: CDT editor steals back file associations [message #60225 is a reply to message #59876] |
Wed, 29 January 2003 17:23   |
Anyone have a pointer on where I would look in the Eclipse or CDT code to
see
if I can figure out why my file assocations aren't kept?
Any pointers no matter how insignificant would be helpful.
Thanks.
> Steps
it
> that
> Any other ideas?
> Thanks!
etc...
Re: CDT editor steals back file associations [message #61161 is a reply to message #60515] |
Tue, 04 February 2003 12:20  |
Does anyone have any comments about my original post as far
as pointing me to code that I can look at/debug in any way?
Thanks!
= = = = = = = Here's a slightly word-smithed version of my post.
I'm testing a new editor plugin and file associations aren't always
"sticking" correctly...
of file associations getting stolen from a different editor plug-ins and
replaced back to the CDT, Java, JSP editors?
Which is Eclipse platform version 2.0.2.1 (build id: 200211071448)
I'm just sort of digging for a debug step I can take here.....
Note this only happens if I leave the file opened when ending WSAD
(so it needs to be restored with workspace).
When that happens, all of the specific file assocations mentioned
below get reset (not just the one that was opened).
Steps
their default editors.
These get reset back: .c, .cpp, .h, .hh, .hpp, .jsp, .java
it doesn't get restored, the file associations seem to remain correct).
I wonder if there's code in place at CDT/JDT/plug-in startup to make the
associations that perhaps shouldn't be there?
Any other ideas?
Thanks!
Current Time: Sat Jul 26 14:41:22 EDT 2025
Powered by FUDForum. Page generated in 0.34563 seconds
