Home » Eclipse Projects » Equinox » How should one use a ServletContextListener when running under serverside OSGI?
How should one use a ServletContextListener when running under serverside OSGI? [message #59873] Mon, 06 February 2006 14:29 Go to next message
I am wondering how to accomplish the equivalent of a
ServletContextListener when running under serverside OSGI? The context
listener class needs to be visible in the web container to avoid a class
not found exception. However when running under serverside OSGI the
listener class will likely have dependencies on classes that reside in
plug-in jars managed by OSGI. I have such a situation. The listener class
can't be in an OSGI plug-in and it dependencies can't NOT be in an OSGI
plugin. Thanks.
Jim D'Anjou
Re: How should one use a ServletContextListener when running under serverside OSGI? [message #59902 is a reply to message #59873] Mon, 06 February 2006 16:03 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi Jim,
With the current bridge (and the current OSGi HttpService) you can't.
What's required here is a new spec.
An API to support this stuff (listeners and filters) dynamically is
definitely still a work in progress. I'm experimenting with re-alignment
with something resembling a java-binding of the Servlet API deployment
descriptor. For implementation, which is perhaps what you're asking, I've
been thinking that a similar approach to the ServletBridge could be used to
bridge and "simulate" the various listeners (and filters) although I haven't
had a chance to experiment yet.
-Simon
A new specification
----- Original Message -----
Newsgroups: eclipse.technology.equinox
Sent: Monday, February 06, 2006 2:29 PM
Subject: How should one use a ServletContextListener when running under
serverside OSGI?
> plugin. Thanks.
> Jim D'Anjou
Re: How should one use a ServletContextListener when running under serverside OS [message #59921 is a reply to message #59902] Mon, 06 February 2006 17:16 Go to previous messageGo to next message
I was not surprised at your reply, Simon. I would have been elated if you
had this worked out. We might be able to delegate to the servlet bundle's
Activator.start (and stop) methods though though they don't quite run in
the same sequence of a context listener's event event notification.
Jim
Re: How should one use a ServletContextListener when running under serverside OSGI? [message #59946 is a reply to message #59902] Mon, 06 February 2006 21:29 Go to previous messageGo to next message
Has thought been given to simply creating a new service that is not OSGi
blessed, but does something like embed Tomcat? I'm really interested in
using the equinox technology on the server-side, but am I wrong in
thinking that it is a little under baked at this moment in time?
Binyan
Simon Kaegi wrote:
> Hi Jim,
> -Simon
> A new specification
> From: "Jim D'Anjou" <danjou@us.ibm.com>
> serverside OSGI?
>>plugin. Thanks.
>>Jim D'Anjou
Re: How should one use a ServletContextListener when running under serverside OSGI? [message #59970 is a reply to message #59946] Tue, 07 February 2006 07:48 Go to previous message
we have been experimenting with using Wicket with OSGi and got quite
encouraging results. not sure it fits you but I think it might work out
nicely.
http://wiki.ops4j.org/dokuwiki/doku.php?id=pax:wicket
/peter
> Binyan
> Simon Kaegi wrote:
>> Hi Jim,
>> I've
>> used to
>> haven't
>> -Simon
>> A new specification
>> ----- Original Message ----- From: "Jim D'Anjou" <danjou@us.ibm.com>
>> serverside OSGI?
>>> class
>>> plugin. Thanks.
>>> Jim D'Anjou
Previous Topic:How do you set dependencies on services?
Next Topic:use with tapestry/hivemind
Current Time: Tue Jul 22 22:11:10 EDT 2025
Powered by FUDForum. Page generated in 0.05859 seconds
