How should one use a ServletContextListener when running under serverside OSGI? [message #59873] |
Mon, 06 February 2006 14:29  |
I am wondering how to accomplish the equivalent of a
ServletContextListener when running under serverside OSGI? The context
listener class needs to be visible in the web container to avoid a class
not found exception. However when running under serverside OSGI the
listener class will likely have dependencies on classes that reside in
plug-in jars managed by OSGI. I have such a situation. The listener class
can't be in an OSGI plug-in and it dependencies can't NOT be in an OSGI
plugin. Thanks.
Jim D'Anjou
Re: How should one use a ServletContextListener when running under serverside OSGI? [message #59970 is a reply to message #59946] |
Tue, 07 February 2006 07:48  |
we have been experimenting with using Wicket with OSGi and got quite
encouraging results. not sure it fits you but I think it might work out
nicely.
http://wiki.ops4j.org/dokuwiki/doku.php?id=pax:wicket
/peter
Binyan wrote:
> Has thought been given to simply creating a new service that is not OSGi
> blessed, but does something like embed Tomcat? I'm really interested in
> using the equinox technology on the server-side, but am I wrong in
> thinking that it is a little under baked at this moment in time?
> Binyan
> Simon Kaegi wrote:
>> Hi Jim,
>> With the current bridge (and the current OSGi HttpService) you can't.
>> What's required here is a new spec.
>> An API to support this stuff (listeners and filters) dynamically is
>> definitely still a work in progress. I'm experimenting with re-alignment
>> with something resembling a java-binding of the Servlet API deployment
>> descriptor. For implementation, which is perhaps what you're asking,
>> I've
>> been thinking that a similar approach to the ServletBridge could be
>> used to
>> bridge and "simulate" the various listeners (and filters) although I
>> haven't
>> had a chance to experiment yet.
>> -Simon
>> A new specification
>> ----- Original Message ----- From: "Jim D'Anjou" <danjou@us.ibm.com>
>> Newsgroups: eclipse.technology.equinox
>> Sent: Monday, February 06, 2006 2:29 PM
>> Subject: How should one use a ServletContextListener when running under
>> serverside OSGI?
>>> class
>>> plugin. Thanks.
>>> Jim D'Anjou
FUDForum. Page generated in 0.06614 seconds
