Home » Eclipse Projects » Nebula » setFocusItem on Disposed GridItem
setFocusItem on Disposed GridItem [message #59825] Wed, 08 October 2008 11:54 Go to next message
I am trying to get tabbing to work in a GridTreeViewer.
When I tab though the grid is trying to set focus on a disposed GridItem,
and I get the following stack trace:
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.nebula.widgets.grid.Grid.setFocusItem(Grid.java: 8000)
org.eclipse.nebula.jface.gridviewer.GridViewerEditor.updateF ocusCell(GridViewerEditor.java:91)
org.eclipse.jface.viewers.ColumnViewerEditor.activateCellEdi tor(ColumnViewerEditor.java:166)
org.eclipse.jface.viewers.ColumnViewerEditor.handleEditorAct ivationEvent(ColumnViewerEditor.java:377)
org.eclipse.jface.viewers.ColumnViewer.triggerEditorActivati onEvent(ColumnViewer.java:670)
org.eclipse.jface.viewers.ColumnViewerEditor.processTraverse Event(ColumnViewerEditor.java:490)
org.eclipse.jface.viewers.ColumnViewerEditor$4.keyTraversed( ColumnViewerEditor.java:219)
I am initializing with the follow settings:
GridViewerEditor.create(this, actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR |
ColumnViewerEditor.TABBING_VERTICAL|
ColumnViewerEditor.KEYBOARD_ACTIVATION);
Does anyone have any ideas what I might be doing wrong?
Re: setFocusItem on Disposed GridItem [message #59851 is a reply to message #59825] Wed, 08 October 2008 13:10 Go to previous messageGo to next message
There's a bug in the GridViewerRow implementation IIRC. It's on my
schedule since a long time but I didn't manage to fix it.
Tom
> GridItem, and I get the following stack trace:
> at
> at
> at
> at
> at
> at
> Thanks
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: setFocusItem on Disposed GridItem [message #59875 is a reply to message #59851] Thu, 09 October 2008 04:27 Go to previous messageGo to next message
is there any possible workaround?
Re: setFocusItem on Disposed GridItem [message #59943 is a reply to message #59875] Thu, 09 October 2008 09:23 Go to previous messageGo to next message
hello,
use below code..
cell will be activated on tab traverse.might be useful
ColumnViewerEditorActivationStrategy actSupport = new
ColumnViewerEditorActivationStrategy(
gridTableViewer) {
protected boolean isEditorActivationEvent(
ColumnViewerEditorActivationEvent event) {
return event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType ==
ColumnViewerEditorActivationEvent.MOUSE_CLICK_SELECTION
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED
&& event.keyCode == SWT.F2)
|| event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC;
GridViewerEditor.create(gridViewer, actSupport,
Raghava
Re: setFocusItem on Disposed GridItem [message #59967 is a reply to message #59943] Thu, 09 October 2008 11:17 Go to previous messageGo to next message
thanks, however that is pretty much what I am doing. The tab works
sometimes, but if I explicitly select into a cell and then tab, then I get
the error as described.
Re: setFocusItem on Disposed GridItem [message #59989 is a reply to message #59967] Thu, 09 October 2008 11:22 Go to previous messageGo to next message
by the way I copied your snippet exactly and did a test and i still get
the error.
Re: setFocusItem on Disposed GridItem [message #60010 is a reply to message #59989] Fri, 10 October 2008 05:09 Go to previous messageGo to next message
As said there's a bug in the GridViewerRow implementation. Could you
please file a bug and attach a snippet I can run without modifications?
Tom
> the error.
Re: setFocusItem on Disposed GridItem [message #60057 is a reply to message #60010] Fri, 10 October 2008 10:21 Go to previous message
will do, thanks.
Re: setFocusItem on Disposed GridItem [message #592480 is a reply to message #59825] Wed, 08 October 2008 13:10 Go to previous message
Tom
> at
> at
> at
> at
> at
> at
> Thanks
Re: setFocusItem on Disposed GridItem [message #592487 is a reply to message #59851] Thu, 09 October 2008 04:27 Go to previous message
Re: setFocusItem on Disposed GridItem [message #592507 is a reply to message #59875] Thu, 09 October 2008 09:23 Go to previous message
hello,
use below code..
gridTableViewer) {
|| event.eventType ==
Raghava
Re: setFocusItem on Disposed GridItem [message #592513 is a reply to message #59943] Thu, 09 October 2008 11:17 Go to previous message
Re: setFocusItem on Disposed GridItem [message #592521 is a reply to message #59967] Thu, 09 October 2008 11:22 Go to previous message
the error.
Re: setFocusItem on Disposed GridItem [message #592525 is a reply to message #59989] Fri, 10 October 2008 05:09 Go to previous message
Tom
> the error.
Re: setFocusItem on Disposed GridItem [message #592544 is a reply to message #60010] Fri, 10 October 2008 10:21 Go to previous message
will do, thanks.
Previous Topic:setFocusItem on Disposed GridItem
Next Topic:[Gantt] Workaround for scrollbars
Current Time: Thu Jul 17 19:34:44 EDT 2025
Powered by FUDForum. Page generated in 0.45601 seconds
