Home » Language IDEs » AspectJ » Fighting AJDT
Fighting AJDT [message #59795] Fri, 23 December 2005 11:47 Go to next message
Originally posted by: as851.columbia.edu
I am fighting the latest AJDT for a couple of hours now. So decided to
just make sure it is not me ... here is the aspect that just would not
let me live :-)
public abstract aspect AbstractPrettyPrintAspect {
protected abstract pointcut toStringMethod(java.lang.Object
targetObject)
around (Object targetObject) : toStringMethod(targetObject) {
String result = (String) proceed(targetObject);
if (shouldOverwrite(result,targetObject))
result = "overwrite";
return result;
is there anything wrong with it. I am getting an error form AJDT on the
line that declares the abstract pointcut. Eclipse complains "Syntax
error on token ";", Type expected after this token"
I can not see what is wrong here. The funny part is that I have an
aspect in different project that has a declaration of the pointcut that
matches one-to-one but names and it works just fine.
Any advice?
I am running:
Version: 1.3.0
Build id: 20051220093604
AspectJ version: 1.5.0
Re: Fighting AJDT [message #59822 is a reply to message #59795] Fri, 23 December 2005 11:59 Go to previous messageGo to next message
sorry for the noise, the around needs return type which I do not have on
the next line. I guess the line that AJDT was pointing to threw me off
the track.
I am good now. No need to call 911 :-)
> let me live :-)
> targetObject)
> return result;
> Any advice?
> I am running:
> Version: 1.3.0
Re: Fighting AJDT [message #59846 is a reply to message #59795] Fri, 23 December 2005 12:01 Go to previous message
Hi!
The problem comes from your around advice. It should have a return type
specified before the "around" keyword! (here String!)
So this makes:
targetObject)
String around (Object targetObject) : toStringMethod(targetObject) {
return result;
Didier.
> targetObject)
> return result;
Re: Fighting AJDT [message #591464 is a reply to message #59795] Fri, 23 December 2005 11:59 Go to previous message
the track.
> let me live :-)
> targetObject)
> return result;
> Any advice?
> I am running:
> Version: 1.3.0
Re: Fighting AJDT [message #591473 is a reply to message #59795] Fri, 23 December 2005 12:01 Go to previous message
Hi!
So this makes:
targetObject)
return result;
Didier.
> targetObject)
> return result;
Previous Topic:Fighting AJDT
Next Topic:CompilationUnit from AspectJ source file?
Current Time: Mon Nov 03 22:05:44 EST 2025
Powered by FUDForum. Page generated in 0.38666 seconds
